Home » Language IDEs » Java Development Tools (JDT) » I can't install Eclipse!(I have just downloaded Eclipse JEE, and it crashes when I run it)
I can't install Eclipse! [message #558624] Mon, 13 September 2010 13:54 Go to next message
Hi! I have just downloaded "Eclipse IDE for Java EE Developers". I unzipped it, and then I executed "eclipse.exe", which I thought it was the setup file.
but then, I got this error
http://img842.imageshack.us/img842/6120/semttulodjr.png
and also this one
http://img823.imageshack.us/img823/6927/88151931.png
Can someone help me please?? I want to start developing in Java, and my teacher recommended me this Eclipse program
Re: I can't install Eclipse! [message #558955 is a reply to message #558624] Wed, 15 September 2010 02:48 Go to previous messageGo to next message
> the setup file.
That is not the setup file, it simply launches eclipse. (Eclipse does
not require any setup)
> http://img842.imageshack.us/i/semttulodjr.png/
> and also this one
> http://img823.imageshack.us/i/88151931.png/
You might want to go through
http://wiki.eclipse.org/FAQ_How_do_I_run_Eclipse%3F
Re: I can't install Eclipse! [message #559111 is a reply to message #558955] Wed, 15 September 2010 12:05 Go to previous message
Are you using 64-bit windows? As I see from the error message, you have used 64-bit eclipse.
Previous Topic:Swing Designer GUI Builder
Next Topic:problems with eclipse while programming android
Current Time: Thu Nov 06 23:58:23 EST 2025
Powered by FUDForum. Page generated in 0.06226 seconds
