Home » Eclipse Projects » Rich Client Platform (RCP) » Invalid activator after product export
icon5.gif  Invalid activator after product export [message #558561] Mon, 13 September 2010 09:58 Go to next message
we have created an RCP application that runs perfectly when started from within the IDE or exported as a plugin an started from the OSGI cli of an equinox installation that has all required plugins.
When exported as a product with the wizard it crashes shortly after showing the splashscreen and the logfiles contain the errors that you can find further down this post.
I use a 32bit JavaSE and a 32bit Eclipse 3.5.1 ond a 64bit Win7
Thx for your help Smile
!SESSION 2010-09-13 15:51:59.435 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_21
BootLoader constants: OS=${target.os}, ARCH=${target.arch}, WS=${target.ws}, NL=${target.nl}
Command-line arguments: -os ${target.os} -ws ${target.ws} -arch ${target.arch}
!ENTRY org.eclipse.osgi 4 0 2010-09-13 15:52:00.891
!MESSAGE An error occurred while automatically activating bundle org.eclipse.ui.workbench (26).
!STACK 0
org.osgi.framework.BundleException: The activator org.eclipse.ui.internal.WorkbenchPlugin for bundle org.eclipse.ui.workbench is invalid
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:157)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:751)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:352)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:280)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:408)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:449)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:211)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass (BundleLoader.java:381)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadCla ss(SingleSourcePackage.java:33)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:454)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:410)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:398)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(Unknown Source)
at java.lang.ClassLoader.defineClass(Unknown Source)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:183)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:576)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:546)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:477)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass_LockClassLoader(ClasspathManager.java:465)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:445)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:457)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(Bund leLoader.java:326)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:231)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:150)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1193)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
at org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:874)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:189)
at org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run(An yThreadAppLauncher.java:26)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/swt/SWTError
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:152)
... 56 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.swt.SWTError
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:494)
... 62 more
Root exception:
... 62 more
!ENTRY org.eclipse.osgi 4 0 2010-09-13 15:52:00.895
!MESSAGE An error occurred while automatically activating bundle de.clab.osami.clinic (3).
!STACK 0
org.osgi.framework.BundleException: The activator de.clab.osami.clinic.Activator for bundle de.clab.osami.clinic is invalid
Caused by: java.lang.NoClassDefFoundError: org/eclipse/ui/plugin/AbstractUIPlugin
... 23 more
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.ui.workbench (26).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
... 42 more
Caused by: org.osgi.framework.BundleException: The activator org.eclipse.ui.internal.WorkbenchPlugin for bundle org.eclipse.ui.workbench is invalid
... 51 more
... 56 more
... 62 more
Root exception:
... 42 more
... 51 more
... 56 more
... 62 more
!ENTRY org.eclipse.equinox.app 4 0 2010-09-13 15:52:00.897
!MESSAGE Plug-in de.clab.osami.clinic was unable to load class de.clab.osami.clinic.Application.
!STACK 0
org.eclipse.core.runtime.CoreException: Plug-in de.clab.osami.clinic was unable to load class de.clab.osami.clinic.Application.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:180)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:162)
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException: An error occurred while automatically activating bundle de.clab.osami.clinic (3).
... 6 more
Caused by: org.osgi.framework.BundleException: The activator de.clab.osami.clinic.Activator for bundle de.clab.osami.clinic is invalid
... 18 more
... 23 more
... 42 more
... 51 more
... 56 more
... 62 more
Re: Invalid activator after product export [message #558581 is a reply to message #558561] Mon, 13 September 2010 10:54 Go to previous messageGo to next message
This kind of error (ClassNotFound SWTError) often occurs because your product is starting the wrong bundles for your platform.
For example, it tries to start as a 64-bits app whereas you are on a 32-bits system.
Try to start your product with OSGi console option and type some "start org.eclipse.swt", it will tell you more about the error.
HTH,
Mickael Istria -- BonitaSoft S.A.
http://www.bonitasoft.com/products/BPM_download.php
Re: Invalid activator after product export [message #558596 is a reply to message #558561] Mon, 13 September 2010 11:47 Go to previous message
Thx for the tip.
When I started the eclipse.exe with the console option the OSGI console disappeared faster than I could react so I tried to start everything via the org.eclipse.equinox.launcher... jar and it worked flawlessly with my locally installed 32bit JRE. Doing the same with the JRE bundled with the product yielded the following error though:
>jre\bin\java.exe plugins\org.eclipse.equinox.launcher_1.0.201.R35x_v20090715. jar -console
Exception in thread "main" java.lang.NoClassDefFoundError: plugins\org/eclipse/equinox/launcher_1/0/201/R35x_v20090715/ jar
Caused by: java.lang.ClassNotFoundException: plugins\org.eclipse.equinox.launcher_1.0.201.R35x_v20090715. jar
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
Could not find the main class: plugins\org.eclipse.equinox.launcher_1.0.201.R35x_v20090715. jar. Program will exit.
Previous Topic:RCP and Usability
Next Topic:product export failed: "cannot satisfy" - which one?
Current Time: Fri Jul 25 05:28:09 EDT 2025
Powered by FUDForum. Page generated in 0.10142 seconds
