Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Reordering widgets within composite
Reordering widgets within composite [message #557909] Thu, 09 September 2010 07:59 Go to next message
Hello to everyone! I've got significant experience in Swing-based applications development, and was very surprised when I failed to do such a simple thing as dynamic changing the order of widgets within a composite in SWT.
To be more precise, I've got a composite with GridLayout. Some other widgets can be added, removed or moved up or down inside this composite by a user (i.e. when application is already running). I learned that removing is done via .dispose() method (which looked a bit strange after Swing, but it's OK), but Internet surfing didn't get me any suitable answer about reordering. As far as I understand, I can dispose and recreate components in a desired order each time, but it seems a bit ugly and is very likely to have UI performance impact.
Could you, please, tell me how I can get desired behaviour?
Thanks in advance!
Re: Reordering widgets within composite [message #558159 is a reply to message #557909] Fri, 10 September 2010 07:32 Go to previous messageGo to next message
You can redorder the controls (i.e, change the drawing order) using the methods Control.moveAbove and Control.moveBelow. Please see this snippet for an example --> Snippet
Re: Reordering widgets within composite [message #558518 is a reply to message #558159] Mon, 13 September 2010 07:06 Go to previous message
Lakshmi, thank you very much!
Previous Topic:ScrollBar.setIncrement() no effect on Linux?
Next Topic:Basic Radio button text color question
Current Time: Mon Jul 28 17:41:21 EDT 2025
Powered by FUDForum. Page generated in 0.05011 seconds
