Home » Modeling » Epsilon » Using the EmfModel class
Using the EmfModel class [message #558486] Mon, 13 September 2010 04:47 Go to next message
I have to following problem:
I created a EmfModel object (org.eclipse.epsilon.emc.emf.EmfModel) and then try to load a model in this object.
Therefore I use the following code:
EglFileGeneratingTemplateFactory factory = new EglFileGeneratingTemplateFactory();
EmfModel emfModel = new EmfModel();
StringProperties properties = new StringProperties();
properties.put(EmfModel.PROPERTY_NAME, name);
properties.put(EmfModel.PROPERTY_METAMODEL_FILE, "file:/" + getFile(metamodel).getAbsolutePath());
properties.put(EmfModel.PROPERTY_MODEL_FILE, "file:/" + getFile(model).getAbsolutePath());
properties.put(EmfModel.PROPERTY_IS_METAMODEL_FILE_BASED, "true");
properties.put(EmfModel.PROPERTY_READONLOAD, "true");
//properties.put(EmfModel.PROPERTY_STOREONDISPOSAL, "false");
emfModel.load(properties, null);
factory.getContext().getModelRepository().addModel(emfModel) ;
I didn't receive an error message when I run my program so I think the loading of my model should work fine.
But my problem is that I'm not able to access any concrete data of the model.
Did I something completely wrong?
If necessary you can see in this thread how the model and the meta model looks like.
http://www.eclipse.org/forums/index.php?t=msg&th=175068& amp;start=0&S=2ba7d260f4a39ac0cb5f2531aa9308d8
Andreas
Re: Using the EmfModel class [message #558503 is a reply to message #558486] Mon, 13 September 2010 05:36 Go to previous messageGo to next message
Hi Andreas,
At a first glance your code looks fine. Could you please be a bit more
specific on the "I'm not able to access any concrete data" issue? Are
you 1) getting an exception when you try to access data of the model, 2)
getting back nothing at all, or 3) not sure how to access data of the
model at all?
Dimitris
Andreas wrote:
> then try to load a model in this object. Therefore I use the following
> code:
> model.
> looks like.
> Best regards,
> Andreas
Re: Using the EmfModel class [message #558517 is a reply to message #558503] Mon, 13 September 2010 06:46 Go to previous messageGo to next message
Hi Dimitris,
thanks for your quick responce.
At the moment I try to access the data from the model with the following statment:
for(EObject eo : emfModel.allContents()){
System.out.println(eo.eAllContents());
But everything I get are empty brackets like
Andreas
Re: Using the EmfModel class [message #558521 is a reply to message #558517] Mon, 13 September 2010 06:52 Go to previous messageGo to next message
Hi Andreas,
I'm a bit confused. Do you need to query your model using Java or using
one of the languages of Epsilon?
Dimitris
Andreas wrote:
> Hi Dimitris,
> statment:
> Regards,
> Andreas
Re: Using the EmfModel class [message #558524 is a reply to message #558521] Mon, 13 September 2010 07:19 Go to previous messageGo to next message
Hi Dimitris,
mainly I want to use EGL to acess the data and generate a HTML Report from them.
But at the moment I just play around and try different solution to access the data.
At the moment it seems to me, that the problem is somewhere around the loading of the model (creation of the EmfModel class).
Andreas
[Updated on: Mon, 13 September 2010 07:19] by Moderator
Re: Using the EmfModel class [message #558525 is a reply to message #558524] Mon, 13 September 2010 07:21 Go to previous messageGo to next message
Hi Andreas,
Have you perhaps had a look at the following example?
http://eclipse.org/gmt/epsilon/examples/index.php?example=or g.eclipse.epsilon.examples.standalone
Dimitris
Andreas wrote:
> HI Dimitris;
> from them. But at the moment I just play around and try different
> solution to access the data. At the moment it seems to me, that the
> EmfModel class).
> Regards,
> Andreas
Re: Using the EmfModel class [message #558528 is a reply to message #558525] Mon, 13 September 2010 07:36 Go to previous messageGo to next message
Hi Dimitris,
yes I know this example.
More or less I took the part to load my model (creation of the EmfModel class) from this example.
But how could this example solve my issue? My problem is that my object emfModel of the type EmfModel does not contain the concrete data from the model I want to read.
Andreas
Re: Using the EmfModel class [message #558564 is a reply to message #558528] Mon, 13 September 2010 10:02 Go to previous messageGo to next message
Ok now I'm able to access my model within a EGL template.
See
But I still cannot understand, why I'm not able to access the concrete data in the emfModel object.
[Updated on: Mon, 13 September 2010 10:04] by Moderator
Re: Using the EmfModel class [message #558574 is a reply to message #558564] Mon, 13 September 2010 10:33 Go to previous messageGo to next message
To access the data of the model using Java you'll need to use the
reflective EMF API (eGet(), eSet() etc.) Below is a link to a tutorial
explaining bits of this
http://www.ibm.com/developerworks/library/os-eclipse-dynamic emf/
but the definitive reference for this is the EMF book
http://amzn.to/b9pToU
Dimitris
Andreas wrote:
> Ok now I'm able to access my model within a EGL template. See
> http://www.eclipse.org/forums/index.php?t=msg&th=175068& amp;start=0&S=aa208ef9c763f612a307bff9f6567a4a
Re: Using the EmfModel class [message #558717 is a reply to message #558574] Tue, 14 September 2010 04:12 Go to previous messageGo to next message
Hi Dimitris,
thank you for the hint. I will have a look on it.
Andreas
Re: Using the EmfModel class [message #593712 is a reply to message #558503] Mon, 13 September 2010 06:46 Go to previous messageGo to next message
Hi Dimitris,
Andreas
Re: Using the EmfModel class [message #593738 is a reply to message #593712] Mon, 13 September 2010 06:52 Go to previous messageGo to next message
Hi Andreas,
Dimitris
Andreas wrote:
> Hi Dimitris,
> statment:
> Regards,
> Andreas
Re: Using the EmfModel class [message #593751 is a reply to message #558521] Mon, 13 September 2010 07:19 Go to previous messageGo to next message
HI Dimitris;
Andreas
Re: Using the EmfModel class [message #593761 is a reply to message #558524] Mon, 13 September 2010 07:21 Go to previous messageGo to next message
Hi Andreas,
Dimitris
Andreas wrote:
> HI Dimitris;
> EmfModel class).
> Regards,
> Andreas
Re: Using the EmfModel class [message #593772 is a reply to message #558525] Mon, 13 September 2010 07:36 Go to previous messageGo to next message
Hi Dimitris,
Andreas
Re: Using the EmfModel class [message #593803 is a reply to message #593772] Mon, 13 September 2010 10:02 Go to previous messageGo to next message
See
Re: Using the EmfModel class [message #593809 is a reply to message #593803] Mon, 13 September 2010 10:33 Go to previous messageGo to next message
Dimitris
Re: Using the EmfModel class [message #593876 is a reply to message #558574] Tue, 14 September 2010 04:12 Go to previous message
Hi Dimitris,
Andreas
Previous Topic:[EWL] Specify the position of an element
Next Topic:Error when adding a model to a newly created launch configuration for an evl file
Current Time: Sat Jul 26 09:31:32 EDT 2025
Powered by FUDForum. Page generated in 0.09136 seconds
