Home » Modeling » Papyrus » Installation help(Get "...contributed an invalid Menu Extension..." in the error log on start up.)
Installation help [message #558310] |
Fri, 10 September 2010 20:58  |
1) Installed eclipse-modeling-helios-incubation-win32-x86_64
2) added Papyrus through the Install Modeling Components
3) get the following in the error log every time I start eclipse
!SESSION 2010-09-10 20:18:44.328 -----------------------------------------------
eclipse.buildId=I20100608-0911
java.version=1.6.0_21
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.modeling.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.modeling.product
!ENTRY org.eclipse.ui 4 4 2010-09-10 20:18:49.510
!MESSAGE Plug-in 'org.eclipse.papyrus.diagram.common' contributed an invalid Menu Extension (Path: 'diagramMenu/filtersMenu' is invalid): org.eclipse.papyrus.diagram.common.myShowHideCompartmentActi on
!ENTRY org.eclipse.ui 4 4 2010-09-10 20:18:49.583
!MESSAGE Plug-in 'org.eclipse.papyrus.diagram.common' contributed an invalid Menu Extension (Path: 'diagramMenu/filtersMenu' is invalid): org.eclipse.papyrus.diagram.common.myShowHideContentsAction
My Configuration
*** Date: Friday, September 10, 2010 8:54:19 PM Eastern Daylight Time
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.commands=-os
win32
-ws
win32
-arch
x86_64
-showsplash
-launcher
C:\Software\eclipse\eclipse-modeling-helios-incubation-win32 -x86_64\eclipse.exe
-name
Eclipse
--launcher.library
C:\Software\eclipse\eclipse-modeling-helios-incubation-win32 -x86_64\plugins/org.eclipse.equinox.launcher.win32.win32.x86 _64_1.1.0.v20100503\eclipse_1307.dll
-startup
C:\Software\eclipse\eclipse-modeling-helios-incubation-win32 -x86_64\plugins/org.eclipse.equinox.launcher_1.1.0.v20100507 .jar
-exitdata
1488_58
-product
-vm
C:\Windows\system32\javaw.exe
eclipse.home.location=file:/C:/Software/eclipse/eclipse-mode ling-helios-incubation-win32-x86_64/
eclipse.launcher=C:\Software\eclipse\eclipse-modeling-helios -incubation-win32-x86_64\eclipse.exe
eclipse.launcher.name=Eclipse
eclipse.p2.data.area=@config.dir/../p2/
eclipse.p2.profile=epp.package.modeling
eclipse.product=org.eclipse.epp.package.modeling.product
eclipse.startTime=1284166291287
eclipse.vm=C:\Windows\system32\javaw.exe
eclipse.vmargs=-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx512m
-XX:MaxPermSize=256m
-jar
equinox.use.ds=true
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\Software\eclipse\eclipse-modeling-helios- incubation-win32-x86_64\plugins/org.eclipse.equinox.launcher _1.1.0.v20100507.jar
java.class.version=50.0
java.endorsed.dirs=C:\Program Files\Java\jre6\lib\endorsed
java.ext.dirs=C:\Program Files\Java\jre6\lib\ext;C:\Windows\Sun\Java\lib\ext
java.home=C:\Program Files\Java\jre6
java.io.tmpdir=C:\Users\tvillars\AppData\Local\Temp\
java.library.path=C:\Windows\system32;.;C:\Windows\Sun\Java\ bin;C:\Windows\system32;C:\Windows;C:\Windows\system32;C:\Wi ndows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPo werShell\v1.0\;C:\Program Files\Intel\DMIX;C:\Program Files (x86)\NTRU Cryptosystems\NTRU TCG Software Stack\bin\;C:\Program Files\NTRU Cryptosystems\NTRU TCG Software Stack\bin\;C:\Program Files\Wave Systems Corp\Gemalto\Access Client\v5\
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_21-b07
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) 64-Bit Server VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=17.0-b17
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.NoOpLog
org.eclipse.equinox.launcher.splash.location=c:\Software\ecl ipse\eclipse-modeling-helios-incubation-win32-x86_64\plugins \org.eclipse.platform_3.6.0.v201006080911\splash.bmp
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.ec lipse.equinox.simpleconfigurator/bundles.info
org.eclipse.update.reconcile=false
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,OSGi/Minimum-1.2,JRE-1.1,J2SE-1.2,J2SE-1.3,J2S E-1.4,J2SE-1.5,JavaSE-1.6
org.osgi.framework.language=en
org.osgi.framework.os.name=Windows7
org.osgi.framework.os.version=6.1.0
org.osgi.framework.processor=x86-64
org.osgi.framework.system.packages=javax.accessibility,javax .activation,javax.activity,javax.annotation,javax.annotation .processing,javax.crypto,javax.crypto.interfaces,javax.crypt o.spec,javax.imageio,javax.imageio.event,javax.imageio.metad ata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,jav ax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap ,javax.lang.model,javax.lang.model.element,javax.lang.model. type,javax.lang.model.util,javax.management,javax.management .loading,javax.management.modelmbean,javax.management.monito r,javax.management.openmbean,javax.management.relation,javax .management.remote,javax.management.remote.rmi,javax.managem ent.timer,javax.naming,javax.naming.directory,javax.naming.e vent,javax.naming.ldap,javax.naming.spi,javax.net,javax.net. ssl,javax.print,javax.print.attribute,javax.print.attribute. standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.r mi.ssl,javax.script,javax.security.auth,javax.security.auth. callback,javax.security.auth.kerberos,javax.security.auth.lo gin,javax.security.auth.spi,javax.security.auth.x500,javax.s ecurity.cert,javax.security.sasl,javax.sound.midi,javax.soun d.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax .sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rows et.spi,javax.swing,javax.swing.border,javax.swing.colorchoos er,javax.swing.event,javax.swing.filechooser,javax.swing.pla f,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing. plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.sw ing.text,javax.swing.text.html,javax.swing.text.html.parser, javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax .tools,javax.transaction,javax.transaction.xa,javax.xml,java x.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotati on.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers ,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,j avax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.cry pto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.dataty pe,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,java x.xml.stream,javax.xml.stream.events,javax.xml.stream.util,j avax.xml.transform,javax.xml.transform.dom,javax.xml.transfo rm.sax,javax.xml.transform.stax,javax.xml.transform.stream,j avax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax. xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,java x.xml.ws.spi,javax.xml.ws.wsaddressing,javax.xml.xpath,org.i etf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.p ortable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage ,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.om g.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.om g.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.Dyn amicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.Dyna micAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPac kage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.Port ableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPacka ge,org.omg.PortableServer,org.omg.PortableServer.CurrentPack age,org.omg.PortableServer.POAManagerPackage,org.omg.Portabl eServer.POAPackage,org.omg.PortableServer.portable,org.omg.P ortableServer.ServantLocatorPackage,org.omg.SendingContext,o rg.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w 3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.l s,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.tra versal,org.w3c.dom.views,org.w3c.dom.xpath,org.xml.sax,org.x ml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.5.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=amd64
os.name=Windows 7
os.version=6.1
osgi.arch=x86_64
osgi.bundles=reference:file: org.eclipse.equinox.simpleconfigurator_1.0.200.v20100503.jar @1:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=C:\Software\eclipse\eclipse-modeling-helios -incubation-win32-x86_64\configuration\org.eclipse.osgi\bund les
osgi.configuration.area=file:/C:/Software/eclipse/eclipse-mo deling-helios-incubation-win32-x86_64/configuration/
osgi.framework=file:/c:/Software/eclipse/eclipse-modeling-he lios-incubation-win32-x86_64/plugins/org.eclipse.osgi_3.6.0. v20100517.jar
osgi.framework.extensions=
osgi.framework.shape=jar
osgi.framework.version=3.6.0.v20100517
osgi.install.area=file:/C:/Software/eclipse/eclipse-modeling -helios-incubation-win32-x86_64/
osgi.instance.area=file:/C:/Users/tvillars/eclipse/Modeling/
osgi.instance.area.default=file:/C:/Users/tvillars/workspace /
osgi.logfile=C:\Users\tvillars\eclipse\Modeling\.metadata\.l og
osgi.manifest.cache=C:\Software\eclipse\eclipse-modeling-hel ios-incubation-win32-x86_64\configuration\org.eclipse.osgi\m anifests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=c:\Software\eclipse\eclipse-modeling-hel ios-incubation-win32-x86_64\plugins\org.eclipse.platform_3.6 .0.v201006080911\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\Software\eclipse\eclipse-modeling-helios-inc ubation-win32-x86_64\plugins
osgi.tracefile=C:\Users\tvillars\eclipse\Modeling\.metadata\ trace.log
osgi.ws=win32
path.separator=;
sun.arch.data.model=64
sun.boot.class.path=C:\Program Files\Java\jre6\lib\resources.jar;C:\Program Files\Java\jre6\lib\rt.jar;C:\Program Files\Java\jre6\lib\sunrsasign.jar;C:\Program Files\Java\jre6\lib\jsse.jar;C:\Program Files\Java\jre6\lib\jce.jar;C:\Program Files\Java\jre6\lib\charsets.jar;C:\Program Files\Java\jre6\classes
sun.boot.library.path=C:\Program Files\Java\jre6\bin
sun.cpu.endian=little
sun.cpu.isalist=amd64
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.java.launcher=SUN_STANDARD
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot 64-Bit Server Compiler
sun.os.patch.level=
user.country=US
user.dir=C:\Software\eclipse\eclipse-modeling-helios-incubat ion-win32-x86_64
user.home=C:\Users\tvillars
user.language=en
user.name=tvillars
user.timezone=America/New_York
user.variant=
*** Features:
org.eclipse.cvs (1.2.0.v20100427-7B77FKs8sF7B77SDX4GW85) "Eclipse CVS Client"
org.eclipse.draw2d (3.6.0.v20100519-2050-45-7w3121163602336) "Graphical Editing Framework Draw2d"
org.eclipse.emf (2.6.0.v20100614-1136) "EMF - Eclipse Modeling Framework Runtime and Tools"
org.eclipse.emf.cdo (3.0.0.v20100614-1657) "CDO Model Repository Client"
org.eclipse.emf.cdo.server (3.0.0.v20100614-1657) "CDO Model Repository Server"
org.eclipse.emf.codegen (2.6.0.v20100614-1136) "EMF Code Generation"
org.eclipse.emf.codegen.ecore (2.6.0.v20100614-1136) "EMF Ecore Code Generator"
org.eclipse.emf.codegen.ecore.ui (2.6.0.v20100614-1136) "EMF Ecore Code Generator UI"
org.eclipse.emf.codegen.ui (2.6.0.v20100614-1136) "EMF Code Generation UI"
org.eclipse.emf.common (2.6.0.v20100614-1136) "EMF Common"
org.eclipse.emf.common.ui (2.6.0.v20100614-1136) "EMF Common UI"
org.eclipse.emf.compare (1.1.0.v201006150400) "EMF Compare core"
org.eclipse.emf.compare.doc (1.1.0.v201006150400) "EMF Compare Documentation"
org.eclipse.emf.compare.sdk (1.1.0.v201006150400) "EMF Compare core"
org.eclipse.emf.converter (2.6.0.v20100614-1136) "EMF Model Converter"
org.eclipse.emf.databinding (1.2.0.v20100614-1136) "EMF Data Binding"
org.eclipse.emf.databinding.edit (1.2.0.v20100614-1136) "EMF Edit Data Binding"
org.eclipse.emf.doc (2.6.0.v20100614-1136) "EMF Documentation"
org.eclipse.emf.ecore (2.6.0.v20100614-1136) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.6.0.v20100614-1136) "EMF Ecore Edit"
org.eclipse.emf.ecore.editor (2.6.0.v20100614-1136) "EMF Sample Ecore Editor"
org.eclipse.emf.ecoretools (0.10.0.v20100615-1639) "Ecore Tools (Incubation)"
org.eclipse.emf.ecoretools.doc (0.10.0.v20100615-1639) "Ecore Tools Documentation (Incubation)"
org.eclipse.emf.edit (2.6.0.v20100614-1136) "EMF Edit"
org.eclipse.emf.edit.ui (2.6.0.v20100614-1136) "EMF Edit UI"
org.eclipse.emf.mapping (2.6.0.v20100614-1136) "EMF Mapping"
org.eclipse.emf.mapping.ecore (2.6.0.v20100614-1136) "EMF Ecore Mapping"
org.eclipse.emf.mapping.ecore.editor (2.6.0.v20100614-1136) "EMF Ecore Mapping Editor"
org.eclipse.emf.mapping.ui (2.6.0.v20100614-1136) "EMF Mapping UI"
org.eclipse.emf.mint (0.9.0.v201006142335) "Mint Runtime (Incubation)"
org.eclipse.emf.mint.doc (0.9.0.v201006142335) "Mint Developer Guide (Incubation)"
org.eclipse.emf.query (1.4.0.v20100428-2315-218Z7w311A142A1142) "EMF Model Query"
org.eclipse.emf.query.doc (1.4.0.v20100428-2315-33-8s733L466A3AE72) "EMF Model Query Documentation"
org.eclipse.emf.query.ocl (1.4.0.v20100428-2315-3--7w311A232602735) "EMF Model Query OCL Integration"
org.eclipse.emf.transaction (1.4.0.v20100428-2315-377-8s734C3E7D15D6B) "EMF Model Transaction Core"
org.eclipse.emf.transaction.doc (1.4.0.v20100428-2315-358Z8s733L466F3C6D4) "EMF Model Transaction Documentation"
org.eclipse.emf.validation (1.4.0.v20100428-2315-479-9oB56N5BBR6LCA6) "EMF Validation Framework Core"
org.eclipse.emf.validation.doc (1.4.0.v20100428-2315-35-8s733L466F3B769) "EMF Validation Framework Documentation"
org.eclipse.emf.validation.ocl (1.4.0.v20100428-2315-23-7w3121133502768) "EMF Validation Framework OCL Integration"
org.eclipse.emf.workspace (1.4.0.v20100428-2315-36-8s734C367E3CBC7) "EMF Model Transaction Workbench Integration Core"
org.eclipse.emf.workspace.doc (1.4.0.v20100428-2315-22-7w311A1238292A) "EMF Model Transaction Workbench Integration Documentation"
org.eclipse.epp.mpc (1.0.0.v20100611-0430) "EPP Marketplace Client"
org.eclipse.epp.package.modeling.feature (1.3.0.20100617-0520) "EPP Modeling Bundle"
org.eclipse.gef (3.6.0.v20100519-2050-777B-81A2Bz-69793A8B83447) "Graphical Editing Framework GEF"
org.eclipse.help (1.2.0.v20100427-7e7jEKFEx2XlnZinYPtgz03) "Help System Base"
org.eclipse.jdt (3.6.0.v20100526-0800-7z8XFUJFMTfCWGoVuHImpms9H155) "Eclipse Java Development Tools"
org.eclipse.mylyn_feature (3.4.0.v20100608-0100-e3x) "Mylyn"
org.eclipse.mylyn.bugzilla_feature (3.4.0.v20100608-0100-e3x) "Mylyn"
org.eclipse.mylyn.context_feature (3.4.0.v20100608-0100-e3x) "Mylyn"
org.eclipse.mylyn.ide_feature (3.4.0.v20100608-0100-e3x) "Mylyn"
org.eclipse.mylyn.java_feature (3.4.0.v20100608-0100-e3x) "Mylyn"
org.eclipse.mylyn.pde_feature (3.4.0.v20100608-0100-e3x) "Mylyn"
org.eclipse.mylyn.team_feature (3.4.0.v20100608-0100-e3x) "Mylyn"
org.eclipse.mylyn.wikitext_feature (1.3.0.v20100608-0100-e3x) "Mylyn"
org.eclipse.net4j (3.0.0.v20100614-1656) "Net4j Signalling Platform Transport"
org.eclipse.net4j.db (3.0.0.v20100614-1656) "Net4j DB Framework"
org.eclipse.net4j.db.derby (3.0.0.v20100614-1655) "Net4j DB Framework Derby Adapter"
org.eclipse.net4j.db.h2 (3.0.0.v20100614-1656) "Net4j DB Framework H2 Adapter"
org.eclipse.ocl (3.0.0.v201005061704-79-7G9oB5855J7O8P9D) "OCL (Object Constraint Language) Parser and Interpreter"
org.eclipse.ocl.doc (3.0.0.v201005061704-4--7w312117191311) "OCL Documentation"
org.eclipse.ocl.edit (3.0.0.v201005061704-7A--9oB5855K5N8Q5H) "OCL Edit Support"
org.eclipse.ocl.uml (3.0.0.v201005061704-4--7w312116172815) "OCL for UML"
org.eclipse.papyrus (0.7.0.v201007251735) "Papyrus Backbone (Incubation)"
org.eclipse.papyrus.diagram.activity (0.7.0.v201007251735) "Papyrus Activity Diagram (Incubation)"
org.eclipse.papyrus.diagram.clazz (0.7.0.v201007251735) "Papyrus Class Diagram (Incubation)"
org.eclipse.papyrus.diagram.communication (0.7.0.v201007251735) "Papyrus Communication Diagram (Incubation)"
org.eclipse.papyrus.diagram.composite (0.7.0.v201007251735) "Papyrus Composite Structure Diagram (incubation)"
org.eclipse.papyrus.diagram.profile (0.7.0.v201007251735) "Papyrus UML Profile Diagram (Incubation)"
org.eclipse.papyrus.diagram.sequence (0.7.0.v201007251735) "Papyrus Sequence Diagram (Incubation)"
org.eclipse.papyrus.diagram.statemachine (0.7.0.v201007251735) "Papyrus State Machine Diagram (Incubation)"
org.eclipse.papyrus.diagram.usecase (0.7.0.v201007251735) "Papyrus UseCase Diagram (Incubation)"
org.eclipse.papyrus.layouttool (0.7.0.v201007251735) "pluginName"
org.eclipse.papyrus.sysml (0.7.0.v201007251735) "UML profile for SysML (from OMG SysML V1.1 formal/2008-11-02) (Incubation)"
org.eclipse.papyrus.uml.diagram.pkg (0.7.0.v201007251735) "Papyrus Package Diagram (incubation)"
org.eclipse.pde (3.6.0.v20100525-7b7mFKtFEx2XmfZ4_B7NUJA) "PDE"
org.eclipse.platform (3.6.0.v20100602-9gF78GpqFt6trOGhL60z0oEx3fz-JKNwxPY) "Eclipse Platform"
org.eclipse.rcp (3.6.0.v20100519-9OArFKvFtsd7WLUKh-DcYTS) "Eclipse RCP"
org.eclipse.sdk (3.6.0.v20100427-7Q7m-DPY2dP0s7TnP1vxqsprbrvrHJwHMVz0mb8mhRX mu) "Eclipse Project SDK"
org.eclipse.uml2 (3.1.0.v201006071150) "UML2"
org.eclipse.uml2.doc (3.1.0.v201005281015) "UML2 Documentation"
org.eclipse.uml2.examples (3.1.0.v201005281015) "UML2 Examples"
org.eclipse.xsd (2.6.0.v20100614-1136) "XSD Model"
org.eclipse.xsd.doc (2.6.0.v20100614-1136) "XSD Documentation"
org.eclipse.xsd.ecore.converter (2.6.0.v20100614-1136) "XSD Ecore Converter"
org.eclipse.xsd.edit (2.6.0.v20100614-1136) "XSD Edit"
org.eclipse.xsd.editor (2.6.0.v20100614-1136) "XSD Sample Editor"
org.eclipse.xsd.mapping (2.6.0.v20100614-1136) "XSD Mapping"
org.eclipse.xsd.mapping.editor (2.6.0.v20100614-1136) "XSD Mapping Editor"
*** Plug-in Registry:
ch.qos.logback.classic (0.9.19.v20100519-1505) "Logback Classic Module" [Resolved]
ch.qos.logback.core (0.9.19.v20100419-1216) "Logback Core Module" [Resolved]
ch.qos.logback.slf4j (0.9.19.v20100519-1910) "Logback Native SLF4J Logger Module" [Resolved]
com.google.collect (0.8.0.v201006170321) "Google Collections" [Resolved]
com.google.inject (2.0.0.v201003051000) "Google Guice" [Resolved]
com.ibm.icu (4.2.1.v20100412) "International Components for Unicode for Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.41.v200903070017) "JSch" [Resolved]
javax.mail.glassfish (1.4.1.v201005082020) "javax.mail bundle from Glassfish" [Resolved]
javax.servlet (2.5.0.v200910301333) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200806031607) "Java Server Pages API Bundle" [Resolved]
javax.xml.bind (2.0.0.v20080604-1500) "JAXB" [Resolved]
lpg.runtime.java (2.0.17.v201004271640) "SourceForge LPG Java Runtime" [Resolved]
org.antlr.runtime (3.0.0.v200803061811) "ANTLR Runtime" [Resolved]
org.aopalliance (1.0.0.v200905130917) "Aopalliance Plug-in" [Resolved]
org.apache.ant (1.7.1.v20100518-1145) "Apache Ant" [Resolved]
org.apache.batik.bridge (1.6.0.v200912221622) "Apache Batik Bridge/GVT/Scripting" [Resolved]
org.apache.batik.css (1.6.0.v200912221622) "Apache Batik CSS" [Resolved]
org.apache.batik.dom (1.6.0.v200912221622) "Apache Batik DOM" [Resolved]
org.apache.batik.dom.svg (1.6.0.v200805290154) "Apache Batik SVG DOM" [Resolved]
org.apache.batik.ext.awt (1.6.0.v200805290154) "Apache Batik AWT Utilities" [Resolved]
org.apache.batik.parser (1.6.0.v200805290154) "Apache Batik Parser" [Resolved]
org.apache.batik.pdf (1.6.0.v200806031500) "Apache Batik PDF" [Resolved]
org.apache.batik.svggen (1.6.0.v200805290154) "Apache Batik SVG Generation" [Resolved]
org.apache.batik.transcoder (1.6.0.v200805290154) "Apache Batik Transcoder" [Resolved]
org.apache.batik.util (1.6.0.v200805290154) "Apache Batik Utilities" [Resolved]
org.apache.batik.util.gui (1.6.0.v200805290154) "Apache Batik GUI Utilities" [Resolved]
org.apache.batik.xml (1.6.0.v200805290154) "Apache Batik XML" [Resolved]
org.apache.commons.cli (1.0.0.v20080604-1500) "pluginName" [Resolved]
org.apache.commons.codec (1.3.0.v20100106-1700) "Apache Commons Codec Plug-in" [Resolved]
org.apache.commons.codec (1.3.0.v20100518-1140) "Apache Commons Codec Plug-in" [Resolved]
org.apache.commons.el (1.0.0.v201004212143) "Apache Commons JSP 2.0 Expression Language Interpreter" [Resolved]
org.apache.commons.httpclient (3.1.0.v20080605-1935) "Apache Commons Httpclient" [Resolved]
org.apache.commons.httpclient (3.1.0.v201005080502) "Apache Commons Httpclient" [Resolved]
org.apache.commons.lang (2.3.0.v201005080501) "Apache Jakarta Commons Lang" [Resolved]
org.apache.commons.logging (1.0.4.v200904062259) "Apache Commons Logging Plug-in" [Resolved]
org.apache.commons.logging (1.0.4.v201005080501) "Apache Commons Logging Plug-in" [Resolved]
org.apache.commons.logging (1.1.1.v201005080502) "Apache Commons Logging Plug-in" [Resolved]
org.apache.derby (10.5.1.1_201005192117) "Apache Derby Plug-in" [Starting]
org.apache.jasper (5.5.17.v201004212143) "Apache Jasper 2 Plug-in" [Resolved]
org.apache.lucene (1.9.1.v20100518-1140) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v20100518-1140) "Apache Lucene Analysis" [Resolved]
org.apache.ws.commons.util (1.0.0.v20100518-1135) "WS Commons Util Plug-in" [Resolved]
org.apache.xmlrpc (3.0.0.v20100427-1100) "Apache XML-RPC Plug-in" [Resolved]
org.eclipse.amalgam.discovery.core (1.1.0.v201006150414) "Amalgam Component Discovery Core (Incubation)" [Active]
org.eclipse.amalgam.discovery.modeling (1.1.0.v201006150414) "Amalgam Modeling Discovery UI (Incubation)" [Active]
org.eclipse.amalgam.discovery.ui (1.1.0.v201006150414) "Amalgam Component Discovery User Interface (Incubation)" [Active]
org.eclipse.ant.core (3.2.200.v20100427) "Ant Build Tool Core" [Starting]
org.eclipse.ant.launching (1.0.0.v20100427) "Ant Launching Support" [Starting]
org.eclipse.ant.ui (3.5.0.v20100427) "Ant UI" [Starting]
org.eclipse.compare (3.5.100.I20100526-0800) "Compare Support" [Active]
org.eclipse.compare.core (3.5.100.I20100526-0800) "Core Compare Support" [Starting]
org.eclipse.compare.win32 (1.0.100.I20100505-1245) "Compare Support for Word" [Starting]
org.eclipse.core.boot (3.1.200.v20100505) "Core Boot" [Starting]
org.eclipse.core.commands (3.6.0.I20100512-1500) "Commands" [Resolved]
org.eclipse.core.contenttype (3.4.100.v20100505-1235) "Eclipse Content Mechanism" [Active]
org.eclipse.core.databinding (1.3.100.I20100601-0800) "JFace Data Binding" [Starting]
org.eclipse.core.databinding.beans (1.2.100.I20100601-0800) "JFace Data Binding for JavaBeans" [Resolved]
org.eclipse.core.databinding.observable (1.3.0.I20100601-0800) "JFace Data Binding Observables" [Active]
org.eclipse.core.databinding.property (1.3.0.I20100601-0800) "JFace Data Binding" [Starting]
org.eclipse.core.expressions (3.4.200.v20100505) "Expression Language" [Active]
org.eclipse.core.externaltools (1.0.0.v20100505) "External Tools Headless Support" [Starting]
org.eclipse.core.filebuffers (3.5.100.v20100520-0800) "File Buffers" [Active]
org.eclipse.core.filesystem (1.3.0.v20100526-0737) "Core File Systems" [Active]
org.eclipse.core.filesystem.win32.x86_64 (1.1.200.v20100505-1235) "Core File System for Windows 64 bit" [Resolved]
org.eclipse.core.jobs (3.5.0.v20100515) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.net (1.2.100.I20100511-0800) "Internet Connection Management" [Active]
org.eclipse.core.net.win32.x86_64 (1.0.100.I20100505-1245) "Proxy for Windows" [Resolved]
org.eclipse.core.resources (3.6.0.v20100526-0737) "Core Resource Management" [Active]
org.eclipse.core.runtime (3.6.0.v20100505) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.2.100.v20100505) "Core Runtime Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.200.v20100517) "Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.3.0.v20100520) "Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.400.v20100505) "Core Variables" [Starting]
org.eclipse.cvs (1.0.500.v201006080911) "Eclipse CVS Client" [Starting]
org.eclipse.debug.core (3.6.0.v20100519) "Debug Core" [Starting]
org.eclipse.debug.ui (3.6.0.v20100601-1530) "Debug UI" [Starting]
org.eclipse.draw2d (3.6.0.v20100525-1225) "Graphical Editing Framework Draw2d" [Active]
org.eclipse.draw2d.doc.isv (3.5.0.v20100519-2050) "Graphical Editing Framework Draw2d Documentation" [Starting]
org.eclipse.ecf (3.1.0.v20100529-0735) "ECF Core API" [Starting]
org.eclipse.ecf.filetransfer (4.0.0.v20100529-0735) "ECF Filetransfer API" [Starting]
org.eclipse.ecf.identity (3.1.0.v20100529-0735) "ECF Identity API" [Starting]
org.eclipse.ecf.provider.filetransfer (3.1.0.v20100529-0735) "ECF Filetransfer Provider" [Starting]
org.eclipse.ecf.provider.filetransfer.httpclient (4.0.0.v20100529-0735) "ECF HttpClient Filetransfer Provider" [Starting]
org.eclipse.ecf.provider.filetransfer.httpclient.ssl (1.0.0.v20100529-0735) "ECF HttpClient Filetransfer Provider" [Resolved]
org.eclipse.ecf.provider.filetransfer.ssl (1.0.0.v20100529-0735) "ECF Filetransfer Provider" [Resolved]
org.eclipse.ecf.ssl (1.0.0.v20100529-0735) "ECF Core API" [Resolved]
org.eclipse.emf (2.6.0.v20100614-1136) "EMF - Eclipse Modeling Framework Runtime and Tools" [Starting]
org.eclipse.emf.ant (2.6.0.v20100521-1846) "EMF Ant Tasks" [Starting]
org.eclipse.emf.cdo (3.0.0.v20100614-1657) "CDO Model Repository Client" [Starting]
org.eclipse.emf.cdo.common (3.0.0.v20100614-1655) "CDO Model Repository Common" [Starting]
org.eclipse.emf.cdo.common.db (3.0.0.v20100614-1656) "CDO Model Repository Common DB Support" [Starting]
org.eclipse.emf.cdo.edit (3.0.0.v20100614-1655) "CDO Model Repository Edit Support" [Starting]
org.eclipse.emf.cdo.migrator (3.0.0.v20100614-1655) "CDO Model Repository Migrator Tool" [Resolved]
org.eclipse.emf.cdo.net4j (3.0.0.v20100614-1655) "CDO Model Repository Client Net4j Support" [Starting]
org.eclipse.emf.cdo.server (3.0.0.v20100614-1654) "CDO Model Repository Server" [Starting]
org.eclipse.emf.cdo.server.net4j (3.0.0.v20100614-1654) "CDO Model Repository Server Net4j Support" [Starting]
org.eclipse.emf.cdo.team (3.0.0.v20100614-1656) "CDO Model Repository Client Team Support" [Starting]
org.eclipse.emf.cdo.ui (3.0.0.v20100614-1656) "CDO Model Repository Client UI" [Starting]
org.eclipse.emf.cdo.ui.ide (3.0.0.v20100614-1654) "CDO Model Repository Client UI IDE" [Starting]
org.eclipse.emf.cheatsheets (2.5.0.v20100521-1846) "EMF Cheat Sheets" [Starting]
org.eclipse.emf.codegen (2.6.0.v20100614-1136) "EMF Code Generation" [Starting]
org.eclipse.emf.codegen.ecore (2.6.0.v20100614-1136) "EMF Ecore Code Generator" [Starting]
org.eclipse.emf.codegen.ecore.ui (2.6.0.v20100614-1136) "EMF Ecore Code Generator UI" [Starting]
org.eclipse.emf.codegen.ui (2.6.0.v20100614-1136) "EMF Code Generation UI" [Starting]
org.eclipse.emf.common (2.6.0.v20100614-1136) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.6.0.v20100614-1136) "EMF Common UI" [Active]
org.eclipse.emf.compare (1.1.0.v201006150400) "EMF Compare core" [Starting]
org.eclipse.emf.compare.diff (1.1.0.v201006150400) "EMF Compare differencer" [Starting]
org.eclipse.emf.compare.diff.edit (1.1.0.v201006150400) "Diff Edit Support" [Starting]
org.eclipse.emf.compare.doc (1.1.0.v201006150400) "EMF Compare Documentation" [Starting]
org.eclipse.emf.compare.epatch (1.1.0.v201006150400) "EPatch Plugin" [Resolved]
org.eclipse.emf.compare.match (1.1.0.v201006150400) "EMF Compare matcher" [Starting]
org.eclipse.emf.compare.ui (1.1.0.v201006150400) "EMF Compare UI" [Starting]
org.eclipse.emf.converter (2.5.0.v20100614-1136) "EMF Model Converter" [Starting]
org.eclipse.emf.databinding (1.2.0.v20100614-1136) "EMF Data Binding" [Starting]
org.eclipse.emf.databinding.edit (1.2.0.v20100614-1136) "EMF Edit Data Binding" [Starting]
org.eclipse.emf.doc (2.6.0.v20100614-1136) "EMF Documentation" [Starting]
org.eclipse.emf.ecore (2.6.0.v20100614-1136) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.5.0.v20100521-1846) "EMF Change Model" [Active]
org.eclipse.emf.ecore.change.edit (2.5.0.v20100521-1846) "EMF Change Edit" [Starting]
org.eclipse.emf.ecore.edit (2.6.0.v20100614-1136) "EMF Ecore Edit" [Active]
org.eclipse.emf.ecore.editor (2.6.0.v20100614-1136) "EMF Sample Ecore Editor" [Starting]
org.eclipse.emf.ecore.xmi (2.5.0.v20100521-1846) "EMF XML/XMI Persistence" [Active]
org.eclipse.emf.ecoretools (0.10.0.v20100615-1639) "Ecore Tools (Incubation)" [Active]
org.eclipse.emf.ecoretools.diagram (0.10.0.v20100521-2009) "Ecore Tools Diagram (Incubation)" [Active]
org.eclipse.emf.ecoretools.diagram.ui.outline (0.9.0.v20100521-2009) "Outline Navigator (Incubation)" [Active]
org.eclipse.emf.ecoretools.doc (0.10.0.v20100615-1639) "Ecore Tools Documentation (Incubation)" [Starting]
org.eclipse.emf.ecoretools.filters (0.8.0.v20100521-2009) "Ecore Diagram Filtering (Incubation)" [Active]
org.eclipse.emf.ecoretools.properties (0.8.0.v20100521-2009) "Ecore Tools Properties (Incubation)" [Starting]
org.eclipse.emf.ecoretools.tabbedproperties (0.8.0.v20100521-2009) "EMF Tabbed Properties (Incubation)" [Starting]
org.eclipse.emf.edit (2.6.0.v20100614-1136) "EMF Edit" [Active]
org.eclipse.emf.edit.ui (2.6.0.v20100614-1136) "EMF Edit UI" [Active]
org.eclipse.emf.example.installer (1.2.0.v20100521-1846) "EMF Example Installer" [Starting]
org.eclipse.emf.exporter (2.6.0.v20100521-1846) "EMF Model Exporter" [Starting]
org.eclipse.emf.importer (2.6.0.v20100521-1846) "EMF Model Importer" [Starting]
org.eclipse.emf.importer.ecore (2.6.0.v20100521-1846) "EMF Ecore Importer" [Starting]
org.eclipse.emf.importer.java (2.6.0.v20100521-1846) "EMF Annotated Java Importer" [Starting]
org.eclipse.emf.importer.rose (2.6.0.v20100521-1846) "EMF Rose Importer" [Starting]
org.eclipse.emf.mapping (2.6.0.v20100614-1136) "EMF Mapping" [Starting]
org.eclipse.emf.mapping.ecore (2.6.0.v20100614-1136) "EMF Ecore Mapping" [Starting]
org.eclipse.emf.mapping.ecore.editor (2.6.0.v20100614-1136) "EMF Ecore Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2ecore (2.5.0.v20100521-1847) "EMF Ecore to Ecore Mapping" [Starting]
org.eclipse.emf.mapping.ecore2ecore.editor (2.4.0.v20100521-1847) "EMF Ecore to Ecore Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2xml (2.5.0.v20100521-1847) "EMF Ecore to XML Mapping" [Starting]
org.eclipse.emf.mapping.ecore2xml.ui (2.5.0.v20100521-1847) "EMF Ecore to XML Mapping Editor" [Starting]
org.eclipse.emf.mapping.ui (2.6.0.v20100614-1136) "EMF Mapping UI" [Starting]
org.eclipse.emf.mapping.xsd2ecore (2.5.0.v20100521-1855) "XSD to Ecore Mapping" [Starting]
org.eclipse.emf.mapping.xsd2ecore.editor (2.6.0.v20100521-1855) "XSD to Ecore Mapping Editor" [Starting]
org.eclipse.emf.mint (0.9.0.v201006142335) "Mint Runtime (Incubation)" [Starting]
org.eclipse.emf.mint.doc (0.9.0.v201006142335) "Mint Developer Guide (Incubation)" [Starting]
org.eclipse.emf.mint.ui (0.9.0.v201006142335) "Mint UI (Incubation)" [Starting]
org.eclipse.emf.mwe.core (1.0.0.v201006150535) "MWE Core" [Starting]
org.eclipse.emf.mwe.utils (1.0.0.v201006150535) "MWE Utilities" [Resolved]
org.eclipse.emf.mwe2.language (1.0.0.v201006150907) "Modeling Workflow Engine 2 Language" [Starting]
org.eclipse.emf.mwe2.launch (1.0.0.v201006150907) "Modeling Workflow Engine 2 Launch" [Resolved]
org.eclipse.emf.mwe2.runtime (1.0.0.v201006150446) "Modeling Workflow Engine 2 Runtime" [Resolved]
org.eclipse.emf.query (1.2.100.v200903190031) "EMF Model Query" [Starting]
org.eclipse.emf.query.doc (1.2.0.v20091210-1711) "EMF Model Query Documentation" [Starting]
org.eclipse.emf.query.examples (1.2.0.v200901271643) "EMF Model Query Examples" [Starting]
org.eclipse.emf.query.ocl (2.0.0.v20091215-1624) "EMF Model Query OCL Integration" [Starting]
org.eclipse.emf.transaction (1.4.0.v20100331-1738) "EMF Model Transaction Core" [Active]
org.eclipse.emf.transaction.doc (1.4.0.v20091215-1213) "EMF Model Transaction Documentation" [Starting]
org.eclipse.emf.transaction.examples (1.2.100.v200901271819) "EMF Model Transaction Examples" [Starting]
org.eclipse.emf.transaction.ui (1.4.0.v20090819-1300) "EMF Model Transaction UI" [Starting]
org.eclipse.emf.validation (1.4.0.v20100428-2315) "EMF Validation Framework Core" [Active]
org.eclipse.emf.validation.doc (1.3.0.v20091215-1218) "EMF Validation Framework Documentation" [Starting]
org.eclipse.emf.validation.examples (1.3.0.v200901271722) "EMF Validation Framework Example" [Starting]
org.eclipse.emf.validation.ocl (1.4.0.v20100224-1657) "EMF Validation Framework OCL Integration" [Resolved]
org.eclipse.emf.validation.ui (1.3.0.v200901271722) "EMF Validation Framework UI" [Starting]
org.eclipse.emf.validation.ui.ide (1.3.0.v200901271722) "EMF Validation Framework UI IDE" [Starting]
org.eclipse.emf.workspace (1.4.0.v20100224-1706) "EMF Model Transaction Workbench Integration Core" [Active]
org.eclipse.emf.workspace.doc (1.3.0.v200901271819) "EMF Model Transaction Workbench Integration Documentation" [Starting]
org.eclipse.emf.workspace.ui (1.3.0.v200901271819) "EMF Model Transaction Workbench Integration UI" [Starting]
org.eclipse.epp.mpc.core (1.0.0.v20100611-0430) "Marketplace Client" [Resolved]
org.eclipse.epp.mpc.help.ui (1.0.0.v20100611-0430) "Marketplace Client Help" [Resolved]
org.eclipse.epp.mpc.ui (1.0.0.v20100611-0430) "EPP Marketplace Client" [Starting]
org.eclipse.epp.package.common (1.3.0.20100617-0520) "EPP Common Bundle" [Resolved]
org.eclipse.epp.package.modeling (1.3.0.20100617-0520) "EPP Modeling Bundle" [Resolved]
org.eclipse.epp.usagedata.gathering (1.3.0.R201005261100) "Usage Data Gathering Plug-in" [Active]
org.eclipse.epp.usagedata.recording (1.3.0.R201005261100) "Usage Data Recording Plug-in" [Active]
org.eclipse.epp.usagedata.ui (1.3.0.R201005261100) "Usage Data UI Plug-in" [Starting]
org.eclipse.equinox.app (1.3.0.v20100512) "Equinox Application Container" [Active]
org.eclipse.equinox.common (3.6.0.v20100503) "Common Eclipse Runtime" [Active]
org.eclipse.equinox.concurrent (1.0.100.v20100503) "Equinox Concurrent API" [Starting]
org.eclipse.equinox.ds (1.2.0.v20100507) "Declarative Services" [Active]
org.eclipse.equinox.event (1.2.0.v20100503) "Event Admin" [Active]
org.eclipse.equinox.frameworkadmin (2.0.0.v20100503) "Equinox Framework Admin" [Starting]
org.eclipse.equinox.frameworkadmin.equinox (1.0.200.v20100505) "Equinox Framework Admin for Equinox" [Starting]
org.eclipse.equinox.http.jetty (2.0.0.v20100503) "Jetty Http Service" [Starting]
org.eclipse.equinox.http.registry (1.1.0.v20100503) "Http Service Registry Extensions" [Resolved]
org.eclipse.equinox.http.servlet (1.1.0.v20100503) "Http Services Servlet" [Starting]
org.eclipse.equinox.jsp.jasper (1.0.200.v20100421) "Jasper Jsp Support Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.200.v20100503) "Jasper Jsp Registry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.1.0.v20100507) "Equinox Launcher" [Resolved]
org.eclipse.equinox.launcher.win32.win32.x86_64 (1.1.0.v20100503) "Equinox Launcher Win32 X86_64 Fragment" [Resolved]
org.eclipse.equinox.p2.artifact.repository (1.1.0.v20100513) "Equinox Provisioning Artifact Repository Support" [Starting]
org.eclipse.equinox.p2.console (1.0.200.v20100601) "Equinox Provisioning Console" [Starting]
org.eclipse.equinox.p2.core (2.0.0.v20100510) "Equinox Provisioning Core" [Active]
org.eclipse.equinox.p2.director (2.0.0.v20100525) "Equinox Provisioning Director" [Starting]
org.eclipse.equinox.p2.director.app (1.0.200.v20100527) "Equinox Provisioning Director Application" [Starting]
org.eclipse.equinox.p2.directorywatcher (1.0.200.v20100601) "Equinox Provisioning Directory Watcher" [Active]
org.eclipse.equinox.p2.discovery (1.0.0.v20100503) "Equinox Provisioning Discovery" [Resolved]
org.eclipse.equinox.p2.discovery.compatibility (1.0.0.v20100518) "Equinox Provisioning Discovery" [Resolved]
org.eclipse.equinox.p2.engine (2.0.0.v20100606) "Equinox Provisioning Engine" [Active]
org.eclipse.equinox.p2.extensionlocation (1.2.0.v20100518) "Extension Location Repository Support" [Starting]
org.eclipse.equinox.p2.garbagecollector (1.0.100.v20100503) "Provisioning Garbage Collector" [Starting]
org.eclipse.equinox.p2.jarprocessor (1.0.200.v20100503a) "Equinox Provisioning JAR Processor" [Resolved]
org.eclipse.equinox.p2.metadata (2.0.0.v20100601) "Equinox Provisioning Metadata" [Active]
org.eclipse.equinox.p2.metadata.generator (1.0.200.v20100503a) "Equinox Provisioning Metadata Generator" [Starting]
org.eclipse.equinox.p2.metadata.repository (1.1.0.v20100513) "Equinox Provisioning Metadata Repository" [Active]
org.eclipse.equinox.p2.operations (2.0.0.v20100510) "Equinox Provisioning Update Checker" [Active]
org.eclipse.equinox.p2.publisher (1.1.0.v20100513) "Equinox Provisioning Publisher" [Starting]
org.eclipse.equinox.p2.ql (2.0.0.v20100503a) "p2 query language" [Starting]
org.eclipse.equinox.p2.reconciler.dropins (1.1.0.v20100525) "Dropin Reconciler Plug-in" [Active]
org.eclipse.equinox.p2.repository (2.0.0.v20100519) "Equinox Provisioning Repository" [Active]
org.eclipse.equinox.p2.repository.tools (2.0.0.v20100520) "Equinox p2 repository tools." [Starting]
org.eclipse.equinox.p2.touchpoint.eclipse (2.0.0.v20100513) "Equinox Provisioning Eclipse Touchpoint" [Starting]
org.eclipse.equinox.p2.touchpoint.natives (1.0.200.v20100503a) "Equinox Provisioning Native Touchpoint" [Starting]
org.eclipse.equinox.p2.ui (2.0.0.v20100518) "Equinox Provisioning UI Support" [Active]
org.eclipse.equinox.p2.ui.discovery (1.0.0.v20100519) "Equinox Provisioning Discovery UI" [Resolved]
org.eclipse.equinox.p2.ui.sdk (1.0.100.v20100513) "Equinox Provisioning Platform Update Support" [Active]
org.eclipse.equinox.p2.ui.sdk.scheduler (1.0.0.v20100507-1815) "Equinox Provisioning Platform Automatic Update Support" [Active]
org.eclipse.equinox.p2.updatechecker (1.1.100.v20100503a) "Equinox Provisioning Update Checker" [Active]
org.eclipse.equinox.p2.updatesite (1.0.200.v20100503) "Update site repository adapter bundle (Incubation)" [Starting]
org.eclipse.equinox.preferences (3.3.0.v20100503) "Eclipse Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.5.0.v20100503) "Extension Registry Support" [Active]
org.eclipse.equinox.security (1.0.200.v20100503) "Equinox Java Authentication and Authorization Service (JAAS)" [Active]
org.eclipse.equinox.security.ui (1.0.200.v20100503) "Equinox Security Default UI" [Starting]
org.eclipse.equinox.simpleconfigurator (1.0.200.v20100503) "Simple Configurator" [Active]
org.eclipse.equinox.simpleconfigurator.manipulator (2.0.0.v20100503) "Simple Configurator Manipulator" [Starting]
org.eclipse.equinox.util (1.0.200.v20100503) "Equinox Util Bundle" [Active]
org.eclipse.gef (3.6.0.v20100525-1225) "Graphical Editing Framework GEF" [Active]
org.eclipse.gef.doc.isv (3.5.0.v20100519-2050) "Graphical Editing Framework GEF Documentation" [Starting]
org.eclipse.gef.examples.ui.pde (3.5.0.v20100519-2050) "Graphical Editing Framework Example Plug-ins" [Starting]
org.eclipse.gmf.runtime.common.core (1.4.0.v20100423-2359) "GMF Common Core" [Active]
org.eclipse.gmf.runtime.common.ui (1.4.0.v20100518-2230) "GMF Common UI" [Active]
org.eclipse.gmf.runtime.common.ui.action (1.2.0.v20090403-1720) "GMF Common UI Action" [Active]
org.eclipse.gmf.runtime.common.ui.action.ide (1.4.0.v20100223-2359) "GMF Common UI Action IDE" [Active]
org.eclipse.gmf.runtime.common.ui.printing (1.4.0.v20100223-2359) "GMF Printing" [Starting]
org.eclipse.gmf.runtime.common.ui.services (1.3.0.v20100423-2359) "GMF Common UI Services" [Active]
org.eclipse.gmf.runtime.common.ui.services.action (1.4.0.v20100430-1518) "GMF Common UI Action Services" [Active]
org.eclipse.gmf.runtime.common.ui.services.properties (1.3.0.v20100115-2350) "GMF Common UI Properties Service Framework" [Active]
org.eclipse.gmf.runtime.diagram.core (1.4.0.v20100331-2359) "GMF Diagram Core" [Active]
org.eclipse.gmf.runtime.diagram.ui (1.4.0.v20100528-2230) "GMF Diagram UI" [Active]
org.eclipse.gmf.runtime.diagram.ui.actions (1.4.0.v20100223-2359) "GMF Diagram Actions" [Active]
org.eclipse.gmf.runtime.diagram.ui.printing (1.4.0.v20100430-1518) "GMF Diagram Printing" [Starting]
org.eclipse.gmf.runtime.diagram.ui.printing.render (1.4.0.v20100423-2359) "GMF Diagram UI Printing Render Plug-In" [Starting]
org.eclipse.gmf.runtime.diagram.ui.properties (1.4.0.v20100430-1518) "GMF Diagram UI Properties" [Active]
org.eclipse.gmf.runtime.diagram.ui.providers (1.4.0.v20100430-1518) "GMF Diagram Providers" [Active]
org.eclipse.gmf.runtime.diagram.ui.providers.ide (1.2.0.v20090403-1720) "GMF Diagram Providers IDE" [Active]
org.eclipse.gmf.runtime.diagram.ui.render (1.4.0.v20100511-1424) "GMF Diagram UI Render Plug-In" [Active]
org.eclipse.gmf.runtime.diagram.ui.resources.editor (1.4.0.v20100531-2230) "GMF Diagram UI Resources Editor Plug-In" [Active]
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide (1.2.0.v20100423-2359) "GMF IDE Editor" [Starting]
org.eclipse.gmf.runtime.draw2d.ui (1.4.0.v20100514-1615) "GMF Draw2d Additions" [Active]
org.eclipse.gmf.runtime.draw2d.ui.render (1.4.0.v20100430-1518) "GMF Draw2d Image Rendering Additions" [Active]
org.eclipse.gmf.runtime.draw2d.ui.render.awt (1.4.0.v20100430-1518) "GMF Draw2d Image AWT based Rendering Additions" [Starting]
org.eclipse.gmf.runtime.emf.clipboard.core (1.4.0.v20100430-1518) "GMF EMF Clipboard Support" [Starting]
org.eclipse.gmf.runtime.emf.commands.core (1.4.0.v20100423-2359) "GMF Commands" [Active]
org.eclipse.gmf.runtime.emf.core (1.4.0.v20100325-2359) "GMF Modeling Service Layer" [Active]
org.eclipse.gmf.runtime.emf.type.core (1.4.0.v20100423-2359) "GMF EMF Type Core" [Active]
org.eclipse.gmf.runtime.emf.ui (1.2.0.v20090403-1720) "GMF MSL UI" [Active]
org.eclipse.gmf.runtime.emf.ui.properties (1.4.0.v20100304-2359) "GMF EMF UI Properties Providers" [Starting]
org.eclipse.gmf.runtime.gef.ui (1.4.0.v20100430-1518) "GMF GEF Additions" [Active]
org.eclipse.gmf.runtime.notation (1.4.0.v20100512-1416) "GMF Notation Model Support" [Active]
org.eclipse.gmt.modisco.infra.browser (0.8.0.v201006150543) "MoDisco Generic Model Browser (Incubation)" [Starting]
org.eclipse.gmt.modisco.infra.browser.custom (0.8.0.v201006150543) "MoDisco Browser customization metamodel (Incubation)" [Starting]
org.eclipse.gmt.modisco.infra.browser.custom.core (0.8.0.v201006150543) "MoDisco Customizations Core (Incubation)" [Starting]
org.eclipse.gmt.modisco.infra.browser.custom.ui (0.8.0.v201006150543) "MoDisco Browser Customization UI plugin (Incubation)" [Starting]
org.eclipse.gmt.modisco.infra.browser.uicore (0.8.0.v201006150543) "MoDisco Model Browser UI Core (Incubation)" [Starting]
org.eclipse.gmt.modisco.infra.common.core (0.8.0.v201006150543) "MoDisco Core (Incubation)" [Starting]
org.eclipse.gmt.modisco.infra.common.ui (0.8.0.v201006150543) "MoDisco Common UI (Incubation)" [Starting]
org.eclipse.gmt.modisco.infra.facet (0.8.0.v201006150543) "MoDisco Facet Meta Model Implementation (Incubation)" [Starting]
org.eclipse.gmt.modisco.infra.facet.core (0.8.0.v201006150543) "MoDisco Facet Core (Incubation)" [Starting]
org.eclipse.gmt.modisco.infra.facet.edit (0.8.0.v201006150543) "MoDisco Facet Edit Support (Incubation)" [Starting]
org.eclipse.gmt.modisco.infra.facet.editor (0.8.0.v201006150543) "MoDisco Facet Editor (Incubation)" [Starting]
org.eclipse.gmt.modisco.infra.facet.ui (0.8.0.v201006150543) "Modisco Facet UI Plug-in (Incubation)" [Starting]
org.eclipse.gmt.modisco.infra.query (0.8.0.v201006150543) "MoDisco Query Model (Incubation)" [Starting]
org.eclipse.gmt.modisco.infra.query.core (0.8.0.v201006150543) "Modisco Query Core (Incubation)" [Starting]
org.eclipse.gmt.modisco.infra.query.edit (0.8.0.v201006150543) "MoDisco Query Edit Support (Incubation)" [Starting]
org.eclipse.gmt.modisco.infra.query.editor (0.8.0.v201006150543) "MoDisco Query Editor (Incubation)" [Starting]
org.eclipse.gmt.modisco.infra.query.ui (0.8.0.v201006150543) "MoDisco Query User Interface (Incubation)" [Starting]
org.eclipse.help (3.5.0.v20100524) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.400.v20100427) "Help Application Server" [Starting]
org.eclipse.help.base (3.5.0.v201006080911) "Help System Base" [Starting]
org.eclipse.help.ui (3.5.0.v20100517) "Help System UI" [Starting]
org.eclipse.help.webapp (3.5.0.v20100507) "Help System Webapp" [Starting]
org.eclipse.jdt (3.6.0.v201006080911) "Eclipse Java Development Tools" [Resolved]
org.eclipse.jdt.apt.core (3.3.400.v20100513-0845) "Java Annotation Processing Core" [Starting]
org.eclipse.jdt.apt.pluggable.core (1.0.300.v20100513-0845) "Java Compiler Apt IDE" [Starting]
org.eclipse.jdt.apt.ui (3.3.300.v20100513-0845) "Java Annotation Processing UI" [Starting]
org.eclipse.jdt.compiler.apt (1.0.300.v20100513-0845) "Java Compiler Apt" [Resolved]
org.eclipse.jdt.compiler.tool (1.0.100.v_A58) "Java Compiler Tool Support" [Resolved]
org.eclipse.jdt.core (3.6.0.v_A58) "Java Development Tools Core" [Active]
org.eclipse.jdt.core.manipulation (1.3.0.v20100520-0800) "Java Code Manipulation Functionality" [Active]
org.eclipse.jdt.debug (3.6.0.v20100526) "JDI Debug Model" [Starting]
org.eclipse.jdt.debug.ui (3.5.0.v20100602-0830) "JDI Debug UI" [Starting]
org.eclipse.jdt.doc.isv (3.6.0.v20100602-1600) "Eclipse JDT Plug-in Developer Guide" [Resolved]
org.eclipse.jdt.doc.user (3.6.0.v20100608) "Eclipse Java development user guide" [Resolved]
org.eclipse.jdt.junit (3.6.0.v20100526-0800) "Java Development Tools JUnit support" [Starting]
org.eclipse.jdt.junit.core (3.6.0.v20100526-0800) "Java Development Tools JUnit core support" [Starting]
org.eclipse.jdt.junit.runtime (3.4.200.v20100526-0800) "Java Development Tools JUnit Runtime Support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.1.100.v20100526-0800) "Java Development Tools JUnit4 Runtime Support" [Resolved]
org.eclipse.jdt.launching (3.5.100.v20100526) "Java Development Tools Launching Support" [Starting]
org.eclipse.jdt.ui (3.6.0.v20100602-1600) "Java Development Tools UI" [Active]
org.eclipse.jface (3.6.0.I20100601-0800) "JFace" [Active]
org.eclipse.jface.databinding (1.4.0.I20100601-0800) "JFace Data Binding for SWT and JFace" [Resolved]
org.eclipse.jface.text (3.6.0.v20100526-0800) "JFace Text" [Resolved]
org.eclipse.jsch.core (1.1.200.I20100505-1245) "JSch Core" [Active]
org.eclipse.jsch.ui (1.1.300.I20100505-1245) "JSch UI" [Starting]
org.eclipse.ltk.core.refactoring (3.5.100.v20100526-0800) "Refactoring Core" [Starting]
org.eclipse.ltk.ui.refactoring (3.5.0.v20100526-0800) "Refactoring UI" [Starting]
org.eclipse.mylyn (3.4.0.v20100608-0100-e3x) "Mylyn" [Resolved]
org.eclipse.mylyn.bugzilla.core (3.4.0.v20100608-0100-e3x) "Mylyn Bugzilla Connector Core" [Active]
org.eclipse.mylyn.bugzilla.ide (3.4.0.v20100608-0100-e3x) "Mylyn Bugzilla IDE Extensions" [Resolved]
org.eclipse.mylyn.bugzilla.ui (3.4.0.v20100608-0100-e3x) "Mylyn Bugzilla Connector UI" [Active]
org.eclipse.mylyn.commons.core (3.4.0.v20100608-0100-e3x) "Mylyn Commons Core" [Resolved]
org.eclipse.mylyn.commons.net (3.4.0.v20100608-0100-e3x) "Mylyn Commons Net" [Active]
org.eclipse.mylyn.commons.ui (3.4.0.v20100608-0100-e3x) "Mylyn Commons UI" [Active]
org.eclipse.mylyn.commons.xmlrpc (3.4.0.v20100608-0100-e3x) "Mylyn XML-RPC Support" [Starting]
org.eclipse.mylyn.context.core (3.4.0.v20100608-0100-e3x) "Mylyn Context Core" [Active]
org.eclipse.mylyn.context.ui (3.4.0.v20100608-0100-e3x) "Mylyn Context UI" [Active]
org.eclipse.mylyn.discovery.core (3.4.0.v20100608-0100-e3x) "Mylyn Connector Discovery Core" [Resolved]
org.eclipse.mylyn.discovery.ui (3.4.0.v20100608-0100-e3x) "Mylyn Connector Discovery UI" [Resolved]
org.eclipse.mylyn.help.ui (3.4.0.v20100608-0100-e3x) "Mylyn Help" [Starting]
org.eclipse.mylyn.ide.ant (3.4.0.v20100608-0100-e3x) "Mylyn Ant Bridge" [Starting]
org.eclipse.mylyn.ide.ui (3.4.0.v20100608-0100-e3x) "Mylyn IDE UI" [Starting]
org.eclipse.mylyn.java.tasks (3.4.0.v20100608-0100-e3x) "Mylyn Java Tasks" [Starting]
org.eclipse.mylyn.java.ui (3.4.0.v20100608-0100-e3x) "Mylyn Java Bridge" [Starting]
org.eclipse.mylyn.monitor.core (3.4.0.v20100608-0100-e3x) "Mylyn Monitor Core" [Resolved]
org.eclipse.mylyn.monitor.ui (3.4.0.v20100608-0100-e3x) "Mylyn Monitor UI" [Active]
org.eclipse.mylyn.pde.ui (3.4.0.v20100608-0100-e3x) "Mylyn PDE Bridge" [Starting]
org.eclipse.mylyn.resources.ui (3.4.0.v20100608-0100-e3x) "Mylyn Resources UI" [Starting]
org.eclipse.mylyn.tasks.bugs (3.4.0.v20100608-0100-e3x) "Mylyn Bug Reporting" [Starting]
org.eclipse.mylyn.tasks.core (3.4.0.v20100608-0100-e3x) "Mylyn Tasks Core" [Resolved]
org.eclipse.mylyn.tasks.search (3.4.0.v20100608-0100-e3x) "Mylyn Tasks UI" [Resolved]
org.eclipse.mylyn.tasks.ui (3.4.0.v20100608-0100-e3x) "Mylyn Tasks UI" [Active]
org.eclipse.mylyn.team.cvs (3.4.0.v20100608-0100-e3x) "Mylyn CVS Extensions" [Resolved]
org.eclipse.mylyn.team.ui (3.4.0.v20100608-0100-e3x) "Mylyn Team UI" [Active]
org.eclipse.mylyn.wikitext.confluence.core (1.3.0.v20100608-0100-e3x) "Mylyn WikiText Confluence" [Resolved]
org.eclipse.mylyn.wikitext.confluence.ui (1.3.0.v20100608-0100-e3x) "Mylyn WikiText Confluence UI" [Resolved]
org.eclipse.mylyn.wikitext.core (1.3.0.v20100608-0100-e3x) "Mylyn WikiText" [Starting]
org.eclipse.mylyn.wikitext.help.ui (1.3.0.v20100608-0100-e3x) "Mylyn WikiText Help UI" [Resolved]
org.eclipse.mylyn.wikitext.mediawiki.core (1.3.0.v20100608-0100-e3x) "Mylyn WikiText MediaWiki" [Resolved]
org.eclipse.mylyn.wikitext.mediawiki.ui (1.3.0.v20100608-0100-e3x) "Mylyn WikiText MediaWiki UI" [Resolved]
org.eclipse.mylyn.wikitext.tasks.ui (1.3.0.v20100608-0100-e3x) "Mylyn WikiText Tasks UI" [Starting]
org.eclipse.mylyn.wikitext.textile.core (1.3.0.v20100608-0100-e3x) "Mylyn WikiText Textile" [Resolved]
org.eclipse.mylyn.wikitext.textile.ui (1.3.0.v20100608-0100-e3x) "Mylyn WikiText Textile UI" [Resolved]
org.eclipse.mylyn.wikitext.tracwiki.core (1.3.0.v20100608-0100-e3x) "Mylyn WikiText TracWiki" [Resolved]
org.eclipse.mylyn.wikitext.tracwiki.ui (1.3.0.v20100608-0100-e3x) "Mylyn WikiText TracWiki UI" [Resolved]
org.eclipse.mylyn.wikitext.twiki.core (1.3.0.v20100608-0100-e3x) "Mylyn WikiText Twiki" [Resolved]
org.eclipse.mylyn.wikitext.twiki.ui (1.3.0.v20100608-0100-e3x) "Mylyn WikiText Twiki UI" [Resolved]
org.eclipse.mylyn.wikitext.ui (1.3.0.v20100608-0100-e3x) "Mylyn WikiText UI" [Starting]
org.eclipse.net4j (3.0.0.v20100614-1655) "Net4j Signalling Platform Transport" [Starting]
org.eclipse.net4j.db (3.0.0.v20100614-1654) "Net4j DB Framework" [Starting]
org.eclipse.net4j.db.derby (3.0.0.v20100614-1655) "Net4j DB Framework Derby Adapter" [Starting]
org.eclipse.net4j.db.h2 (3.0.0.v20100614-1656) "Net4j DB Framework H2 Adapter" [Starting]
org.eclipse.net4j.http (3.0.0.v20100614-1655) "Net4j Signalling Platform Transport HTTP" [Starting]
org.eclipse.net4j.http.common (3.0.0.v20100614-1656) "Net4j Signalling Platform Transport HTTP Common" [Starting]
org.eclipse.net4j.http.server (3.0.0.v20100614-1655) "Net4j Signalling Platform Transport HTTP Server" [Starting]
org.eclipse.net4j.jms.api (3.0.0.v20100614-1655) "Net4j JMS Provider Spec API (Experimental)" [Resolved]
org.eclipse.net4j.jvm (3.0.0.v20100614-1655) "Net4j Signalling Platform Transport JVM" [Starting]
org.eclipse.net4j.tcp (3.0.0.v20100614-1656) "Net4j Signalling Platform Transport TCP" [Starting]
org.eclipse.net4j.util (3.0.0.v20100614-1655) "Net4j Signalling Platform Utilities" [Starting]
org.eclipse.net4j.util.ui (3.0.0.v20100614-1654) "Net4j Signalling Platform Utilities UI" [Starting]
org.eclipse.ocl (3.0.0.v201005061704) "OCL (Object Constraint Language) Parser and Interpreter" [Starting]
org.eclipse.ocl.doc (3.0.0.v201006080200) "OCL Documentation" [Starting]
org.eclipse.ocl.ecore (3.0.0.v201005061704) "OCL for Ecore" [Starting]
org.eclipse.ocl.ecore.edit (3.0.0.v201005061704) "OCL for Ecore Edit Support" [Starting]
org.eclipse.ocl.edit (3.0.0.v201005061704) "OCL Edit Support" [Starting]
org.eclipse.ocl.uml (3.0.0.v201005061704) "OCL for UML" [Starting]
org.eclipse.ocl.uml.edit (3.0.0.v201005061704) "OCL for UML Edit Support" [Starting]
org.eclipse.osgi (3.6.0.v20100517) "OSGi System Bundle" [Active]
org.eclipse.osgi.services (3.2.100.v20100503) "OSGi Release 4.2.0 Services" [Resolved]
org.eclipse.osgi.util (3.2.100.v20100503) "OSGi Release 4.2.0 Utility Classes" [Resolved]
org.eclipse.papyrus.controlmode (0.7.0.v201007251735) "pluginName" [Starting]
org.eclipse.papyrus.controlmode.history (0.7.0.v201007251735) "Papyrus Control Mode Trace (Incubation)" [Active]
org.eclipse.papyrus.core (0.7.0.v201007251735) "Papyrus Backbone (Incubation)" [Active]
org.eclipse.papyrus.core.adaptor.gmf (0.7.0.v201007251735) "UML Papyrus GMF Editor (Incubation)" [Active]
org.eclipse.papyrus.core.resourceloading (0.7.0.v201007251735) "pluginName" [Active]
org.eclipse.papyrus.core.resourceloading.preferences (0.7.0.v201007251735) "pluginName" [Active]
org.eclipse.papyrus.diagram.activity (0.7.0.v201007251735) "Papyrus Activity Diagram (Incubation)" [Active]
org.eclipse.papyrus.diagram.clazz (0.7.0.v201007251735) "Papyrus Class Diagram (Incubation)" [Active]
org.eclipse.papyrus.diagram.common (0.7.0.v201007251735) "Papyrus Common Diagram (Incubation)" [Active]
org.eclipse.papyrus.diagram.common.groups (0.7.0.v201007251735) "pluginName" [Active]
org.eclipse.papyrus.diagram.communication (0.7.0.v201007251735) "Papyrus Communication Diagram (Incubation)" [Active]
org.eclipse.papyrus.diagram.composite (0.7.0.v201007251735) "Papyrus Composite Structure Diagram (incubation)" [Active]
org.eclipse.papyrus.diagram.icons.uml (0.7.0.v201007251735) "pluginName" [Starting]
org.eclipse.papyrus.diagram.profile (0.7.0.v201007251735) "Papyrus UML Profile Diagram (Incubation)" [Active]
org.eclipse.papyrus.diagram.sequence (0.7.0.v201007251735) "Papyrus Sequence Diagram (Incubation)" [Active]
org.eclipse.papyrus.diagram.statemachine (0.7.0.v201007251735) "Papyrus State Machine Diagram (Incubation)" [Active]
org.eclipse.papyrus.diagram.usecase (0.7.0.v201007251735) "Papyrus UseCase Diagram (Incubation)" [Active]
org.eclipse.papyrus.doc (0.7.0.v201007251735) "Papyrus Documenation and Help Plugin" [Resolved]
org.eclipse.papyrus.editor (0.7.0.v201007251735) "pluginName" [Active]
org.eclipse.papyrus.extensionpoints.editors (0.7.0.v201007251735) "Papyrus Embedded Editors extensions point (Incubation)" [Active]
org.eclipse.papyrus.extensionpoints.uml2 (0.7.0.v201007251735) "Papyrus UML extensions - library and profile (Incubation)" [Starting]
org.eclipse.papyrus.icons.uml (0.7.0.v201007251735) "pluginName" [Starting]
org.eclipse.papyrus.layouttool (0.7.0.v201007251735) "pluginName" [Active]
org.eclipse.papyrus.layouttool.algorithms.gridAlgorithm (0.7.0.v201007251735) "GridAlgorithm Plug-in" [Active]
org.eclipse.papyrus.layouttool.algorithms.horizontalAlgorith m (0.7.0.v201007251735) "HorizontalAlgorithm Plug-in" [Active]
org.eclipse.papyrus.layouttool.algorithms.horizontalSymmetry Algorithm (0.7.0.v201007251735) "HorizontalSymmetryAlgorithm Plug-in" [Active]
org.eclipse.papyrus.layouttool.algorithms.horizontalTreeAlgo rithm (0.7.0.v201007251735) "HorizontalTreeAlgorithm Plug-in" [Active]
org.eclipse.papyrus.layouttool.algorithms.radialAlgorithm (0.7.0.v201007251735) "RadialAlgorithm Plug-in" [Active]
org.eclipse.papyrus.layouttool.algorithms.springAlgorithm (0.7.0.v201007251735) "SpringAlgorithm Plug-in" [Active]
org.eclipse.papyrus.layouttool.algorithms.treeAlgorithm (0.7.0.v201007251735) "TreeAlgorithm Plug-in" [Active]
org.eclipse.papy
Re: Installation help [message #558464 is a reply to message #558374] |
Mon, 13 September 2010 03:20  |
Hello Tom, Yannick, all,
As I'm involved in both TOPCASED and Papyrus projects, I'll try to
clarify a little bit.
Papyrus will not replace TOPCASED as both products do not have the same
scope. Papyrus aims at delivering model-based graphical editors while
TOPCASED is a full modeling platform (including model-based editors).
In TOPCASED roadmap, we have planned to integrate MDT Papyrus as our
next generation for Modeling editors for the very beginning of 2011. It
gives us a few months to mature, stabilize and improve MDT Papyrus
before the integration. And there will probably be cohabitation between
"old" and "new" modeling editors during some period in TOPCASED so that
end users can smoothly switch at their ryhtm.
Hope it helps
regards
raphaël Faudou
Papyrus team
TOPCASED team
Le 12/09/2010 01:02, Yannick Duchene a écrit :
> Tom Villars wrote
>> Actually ignoring is not a workaround as none of the diagramming
>> works. For example when I try to add a swimlane to a UML sequence
>> diagram I get this in the log:
> I have also noticed some bug which are really blocking (I did not
> suspected it was the same for you).
> May I suggest you to try the same I am planning to do : try with TopCased :
> http://www.topcased.org/
> http://gforge.enseeiht.fr/docman/view.php/52/4014/Installati on%20Guide%20v4.2.pdf
> And see which one should be used : Papyrus or TopCased ?
> I read about some assertions Papyrus should replace TopCased, while
> Papyrus seems a bit buggy to me, so I wonder what this assertion really
> values and if TopCased should not be used instead.
> Better explanations about Papyrus vs TopCased would be welcome, but I
> did not find any thing clear about this subtle topic.
Current Time: Fri Jul 18 20:08:55 EDT 2025
Powered by FUDForum. Page generated in 0.03865 seconds
