Home » Modeling » EMF » help overriding createMoveCommand() or createDragAndDropCommand()
help overriding createMoveCommand() or createDragAndDropCommand() [message #558355] Sat, 11 September 2010 10:49 Go to next message
I've been trying to figure out the best way to handle move/drag-n-drop
events for one of my objects. I will try to explain below. I've
searched the newsgroup and the EMF book, and am still having some
problems trying to solve my issue. I believe I want to override
createMoveCommand() or createDragAndDropCommand(), but can't find any
concrete examples, and am having problems debugging (and setting up
breakpoints in the right place).
Here's an example setup / ecore model:
MainObject
listA [0...100]: ObjectA
listB [0...200]: ObjectB
ObjectA
ObjectB
pointerToA: Int
When I drag and drop objects in listA, I would like to "fix" all the
ObjectB#pointerToA values based on a preference. If the preference is
true, then I need to update pointerToA with the new indexes of ObjectA;
if the preference is false, then I don't need to do anything: pointerA
can stay pointing at the old index.
This is a simplified example, but should describe my issue.
Anyways, in MainObjectItemProvider, I've tried overriding both
createDragAndDropCommand() and createMoveCommand().
When I return UnexecutableCommand.INSTANCE for
createDragAndDropCommand(), it seems to have no effect. I can move
ObjectA items around in my editor- and they behave the same way they did
before I overrode createDragAndDropCommand(). If I put a breakpoint in
that function, I see that it is never called when I drag-n-drop items.
When I add a breakpoint on createMoveCommand(), I see that it is being
called when I drag-n-drop ObjectA items in my editor. The problem is,
my breakpoint is triggered when I am "dragging" items. I don't know how
to set the breakpoint to only trigger when I "drop" the items.
Also, I can't figure out the correct implementation of
createMoveCommand(). It doesn't take a collection of items. How does it
know that a batch of items are being moved at once?
Another thing is, if I return UnexecutableCommand.INSTANCE in that
function, then dragging and dropping ObjectA items has "weird" behavior.
The dragged item seems to be copied into the new slot, and a null
exeception is thrown because an item appears to be removed from the end
of my listA.
Am I going about this the wrong way? Can anybody point me in the right
direction on how to set a breakpoint only for the "drop" action?
Also, I'm wondering how a compound command is achieved for
MoveCommand(). I don't see it accepting a collection, so how does it
know to undo/redo a whole batch of commands when moving multiple items
at once?
If I can figure out these things, I think I'll be closer to creating my
own compound command that will also "fix" pointerToA values when moving
items around.
Thanks for any help you can provide, and sorry for the long-winded question!
-Jeff
Re: help overriding createMoveCommand() or createDragAndDropCommand() [message #558364 is a reply to message #558355] Sat, 11 September 2010 14:07 Go to previous messageGo to next message
Jeff,
Comments below.
Debugging drag and drop is hard because stopping at a breakpoint kills
the flow of control...
> MainObject
> ObjectA
> ObjectB
> pointerToA: Int
> ObjectA; if the preference is false, then I don't need to do anything:
> pointerA can stay pointing at the old index.
> did before I overrode createDragAndDropCommand(). If I put a
> breakpoint in that function, I see that it is never called when I
> drag-n-drop items.
EditingDomainViewerDropAdapter.DragAndDropCommandInformation .createCommand
calls DragAndDropCommand.create which calls
domain.createCommand(DragAndDropCommand.class which dispatches to the
owner, the thing onto which you are dropping. That might well be
another ObjectA instance.
> how to set the breakpoint to only trigger when I "drop" the items.
Anything you do to affect the state should happen when the command is
executed, not when it's being created...
> it know that a batch of items are being moved at once?
You'll see that DragAndDropCommand.prepareDropMoveInsert creates a bunch
of MoveCommands and composed them.
> behavior. The dragged item seems to be copied into the new slot, and
> a null exeception is thrown because an item appears to be removed from
> the end of my listA.
Not sure about that. DragAndDrop tries a whole bunch of different
things. If a move doesn't work, it will create a copy and try to add
that copy.
> right direction on how to set a breakpoint only for the "drop" action?
In the end, cut and paste should do the same thing shouldn't it?
> at once?
They're composed into a compound command which handles undo and redoing
each one.
> my own compound command that will also "fix" pointerToA values when
> moving items around.
Hopefully that's enough hints...
> question!
> -Jeff
Re: help overriding createMoveCommand() or createDragAndDropCommand() [message #558369 is a reply to message #558364] Sat, 11 September 2010 14:59 Go to previous message
Ed-
Thanks a lot for the help. You definitely gave me some places to start
looking.
On 9/11/2010 2:07 PM, Ed Merks wrote:
> Jeff,
> Comments below.
>> MainObject
>> ObjectA
>> ObjectB
>> pointerToA: Int
>> drag-n-drop items.
> owner, the thing onto which you are dropping. That might well be another
> ObjectA instance.
>> behavior. The dragged item seems to be copied into the new slot, and a
> that copy.
>> at once?
> each one.
>> question!
>> -Jeff
Previous Topic:Getting Helios final version from git
Next Topic:[teneo] entity class not found
Current Time: Sat Jul 26 13:17:49 EDT 2025
Powered by FUDForum. Page generated in 0.28102 seconds
