Home » Archived » IMP » Proposed API change to IMessageHandler
Proposed API change to IMessageHandler [message #554928] Tue, 24 August 2010 14:46 Go to next message
*** Problem: ***
Quick Fix support:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=323532
*** Diagnosis: ***
For some quickfixes additional information is needed (an error code for example) when creating IMarkers and Annotations.
*** Proposed IMP API change: ***
Add the following method:
public interface IMessageHandler{
void handleSimpleMessage(String msg, int startOffset, int endOffset,
int startCol, int endCol,
int startLine, int endLine, Map<String, Object> attributeMap);
Also since this is a breaking change to this API, I suggest that IMessageHandlerExtension is thrown out and its method be added to IMessageHandler as well
Re: Proposed API change to IMessageHandler [message #554935 is a reply to message #554928] Tue, 24 August 2010 15:11 Go to previous messageGo to next message
Hi Adam
In my experience, functions with many arguments have many arguments
because there is a missing configuration/state object.
If you're breaking the API why not break it properly. Why are seven
attributes privileged while the rest are mapped? Surely severity,
source,... deserve to be privileged too? Why not allow derived
implementations to manage the representation to taste.
Generally at least one of startOffset or startLine/startCol is
redundant, ditto end... Putting them in the interface mandates that the
redundant one is calculated and that redundant state is propagated.
Ed Willink
On 24/08/2010 19:46, Adam Taylor wrote:
> *** Problem: ***
> Quick Fix support:
> *** Diagnosis: ***
Re: Proposed API change to IMessageHandler [message #558305 is a reply to message #554935] Fri, 10 September 2010 20:00 Go to previous messageGo to next message
On 8/24/10 3:11 PM, Ed Willink wrote:
> Hi Adam
> In my experience, functions with many arguments have many arguments because there is a missing configuration/state object.
> If you're breaking the API why not break it properly. Why are seven attributes privileged while the rest are mapped?
> Surely severity, source,... deserve to be privileged too? Why not allow derived implementations to manage the
> Generally at least one of startOffset or startLine/startCol is redundant, ditto end... Putting them in the interface
> mandates that the redundant one is calculated and that redundant state is propagated.
Not so - not all of that info is redundant, and putting all of the attributes in a
map obscures the fact that omitting certain kinds of information disables key IDE
functionality. E.g., if one omits the line # info, the user can't double-click on
items in the Problems View and have the editor go to the correct line. Likewise,
if one omits offset information, the wrong range of text will get highlighted by
the editor annotation.
>> *** Problem: ***
>> Quick Fix support:
>> *** Diagnosis: ***
-- Bob
Robert M. Fuhrer
Research Staff Member
Programming Technologies Dept.
IBM T.J. Watson Research Center
IDE Meta-tooling Platform Project Lead (http://www.eclipse.org/imp)
X10: Productive High-Performance Parallel Programming (http://x10.sf.net)
Re: Proposed API change to IMessageHandler [message #558359 is a reply to message #558305] Sat, 11 September 2010 11:53 Go to previous message
>> Hi Adam
>> object.
To be more precise, at least the line # info isn't redundant since it can only be
calculated given something like an IDocument, which isn't available in the context
of an incremental project builder.
>>> *** Problem: ***
>>> Quick Fix support:
>>> *** Diagnosis: ***
-- Bob
Robert M. Fuhrer
Re: Proposed API change to IMessageHandler [message #578123 is a reply to message #554935] Fri, 10 September 2010 20:00 Go to previous message
> Hi Adam
>> *** Problem: ***
>> Quick Fix support:
>> *** Diagnosis: ***
-- Bob
Robert M. Fuhrer
Re: Proposed API change to IMessageHandler [message #578159 is a reply to message #558305] Sat, 11 September 2010 11:53 Go to previous message
>> Hi Adam
>> object.
>>> *** Problem: ***
>>> Quick Fix support:
>>> *** Diagnosis: ***
-- Bob
Robert M. Fuhrer
Previous Topic:Upcoming breaking API changes in the IMP runtime
Next Topic:Experiences; custom parser?
Current Time: Wed Jul 23 03:10:09 EDT 2025
Powered by FUDForum. Page generated in 0.13139 seconds
