Home » Archived » Buckminster » missing native launcher?
missing native launcher? [message #557621] Wed, 08 September 2010 07:06 Go to next message
seems i am missing the native launcher after the p2.site has completed, I use the product.ant file and the *.cspecx
<project>
	 <pathconvert property="equinox.launcher.jar">
	   <first count="1">
	     <sort>
	       <fileset dir="${eclipse.home}/plugins" includes="**/org.eclipse.equinox.launcher_*.jar"/>
	       <reverse xmlns="antlib:org.apache.tools.ant.types.resources.comparators">
	         <date/>
	       </reverse>
	     </sort>
	   </first>
	 </pathconvert>
	<target name="create.product">
		<property name="destination" location="${sp:destination}"/>
		<property name='org.eclipse.equinox.p2.roaming' value='true'/>
		<delete dir="${destination}"></delete>
		<makeurl property="repository" file="${sp:repository}"/>
		<mkdir dir="${destination}"/>
		<echoproperties ></echoproperties>
		<echo message="${equinox.launcher.jar}"/>
		<echo message="${repository}"/>
		<echo message="${destination}"/>
		<java jar="${equinox.launcher.jar}" fork="true" failonerror="true" >
			<arg value="-application"/>
			<arg value="org.eclipse.equinox.p2.director"/>
			<arg value="-artifactRepository"/>
			<arg value="${repository}"/>
			<arg value="-metadataRepository"/>
			<arg value="-destination"/>
			<arg value="${destination}"/>
			<arg value="-bundlepool"/>
			<arg value="-profile"/>
			<arg value="${profile}"/>
			<arg value="-profileProperties" />
			<arg value="org.eclipse.update.install.features=true" />
			<arg value="-installIU"/>
			<arg value="${iu}"/>
			<arg value="-p2.os" />
			<arg value="${target.os}" />
			<arg value="-p2.ws" />
			<arg value="${target.ws}" />
			<arg value="-p2.arch" />
			<arg value="${target.arch}" />
			<arg value="-consoleLog"/>
			<arg value="-roaming"/>
		</java>
	</target>
</project>
I read about the "-roaming" so i added that and removed the jvmargs, but still no native launcher.
The product file has the checkbox include native launcher artifacts checked. The PDE build gives me the native launcher but buckminster build doesn't. Probably some oversight somewhere from mypart..but where?
edited -spelling
[Updated on: Wed, 08 September 2010 07:07] by Moderator
Re: missing native launcher? [message #558152 is a reply to message #557621] Fri, 10 September 2010 07:12 Go to previous messageGo to next message
Went headless via hudson/buckminster plugin (using archived target), it builds, creates the site.p2 then runs create.product all ends in sucess, but still no native launcher (eclipse.exe) . If i copy the eclipse.exe in the product works fine, debug output doesn't give me any clues.
Any clues on where i should start to look?
best regards
David
Re: missing native launcher? [message #558314 is a reply to message #558152] Sat, 11 September 2010 02:28 Go to previous messageGo to next message
Hi David,
I think your product (or defining feature) should include the
org.eclipse.equinox.executable feature to get these launchers.
Peter
> best regards
> David
Re: missing native launcher? [message #559030 is a reply to message #558314] Wed, 15 September 2010 07:29 Go to previous messageGo to next message
Yes the feature org.eclipse.equinox.executable was missing in my feature. But after an rebuild with buckminster and still i didn't get any native launcher.
When i looked a little closer to the feature that held the .product file i noticed that the .product file was not included in build.properties (doh) i remember i renamed it a while ago for testing with maven/tycho builds hence the problem.
if i included the "org.eclipse.equinox.executable" i got an "launcher.exe" + the "eclipse.exe", so i removed that feature and then the launcher.exe was gone after an rebuild.
Note on tycho and buckminster is that the directory structure does not really mix if you want to switch or test tycho, as tycho is dependant on that the .product file has the exact naming of the feature id +.product. Thus the suggested structure in the buckybook was no good. But as a sidenote i never got an good maven/build working for eclipse products as tycho was not really integrated with p2 yet it seems, i.e it ignored my p2.inf file for instance (that might have changed since i tested it the last time)
best regards
David
Re: missing native launcher? [message #559043 is a reply to message #559030] Wed, 15 September 2010 08:17 Go to previous messageGo to next message
I never include the .product in my build.properties because it's only a
build artifact. Is it necessary to do this with buckminster? It
certainly isn't with pde build.
Peter
Re: missing native launcher? [message #559045 is a reply to message #557621] Wed, 15 September 2010 08:31 Go to previous messageGo to next message
At least that fixed the problem, i know that with PDE build its not needed, as that has been the escape so far to be able to do the builds.
Re: missing native launcher? [message #559207 is a reply to message #559043] Wed, 15 September 2010 20:10 Go to previous messageGo to next message
Products that I build using buckminster does not include the .product
artifact in the binary result, so - not required.
- henrik
Re: missing native launcher? [message #559260 is a reply to message #559207] Thu, 16 September 2010 04:04 Go to previous messageGo to next message
Hi Peter,
There's no need to include the .product file in your build.properties.
Its content is picked up from the source during publishing, not from the
built jar.
Thomas Hallgren
> Regards
> - henrik
Re: missing native launcher? [message #559370 is a reply to message #557621] Thu, 16 September 2010 09:37 Go to previous message
After a couple of rebuilds, i saw that i never cleaned my workspace in hudson.
Removing the .product file from build.properties then cleaning the buckminster workspace now gives me an product with the native launcher again.
Seems the old data in the workspace must have messed up things.
best regards
David
Previous Topic:Ant actor non-zero exit code does not terminate Buckminster
Next Topic:Could not instantiate provider org.eclipse.team.svn.core.svnnature
Current Time: Tue Jul 22 13:09:27 EDT 2025
Powered by FUDForum. Page generated in 0.24977 seconds
