Connect with an RCP-application to an Infocenter using SSL [message #556930] |
Fri, 03 September 2010 04:30  |
my last problem is solved, please see my last post in this thread for the new problem. Should be rather easy to fix?
--- Solved ---
my Infocenter is up and running, also I'm only able to connect to my Infocenter by logging in with my external Browser.
When I connect to the infocenter with my Eclipse RCP I can't access the help. I want the Eclipse RCP to ask the user for login like the external webbrowser or another possibility to automatically transfer the username and password. SSL is necessary.
I've searched a bit and found this http:// dev.eclipse.org/viewcvs/index.cgi/platform-help-home/infocen ter_secure_access.html?view=co but these extension points do not exist (heard tomcat isn't used internal anymore, instead jetty?) and also some bug-entries which didn't help me.
Is it possible without rewriting everything?
Thanks in advance
[Updated on: Thu, 09 September 2010 08:39] by Moderator
FUDForum. Page generated in 0.07566 seconds
