Home » Archived » BIRT » Setting table groups in code (conditional grouping)(How to set dynamic table groups)
icon3.gif  Setting table groups in code (conditional grouping) [message #557855] Thu, 09 September 2010 05:03 Go to next message
what's the best way in the latest birt version to set the groups for a table dynamically in code?
For example i want to have 2 groups for my table in the report: Group1 and Group2. Now i want to set the group on criterion in the code because the groups are based on an user input in the application. I work with a scripted data set that gets filled in the code.
So the questions are:
- Is the easiest way to set the criterion in the code?
- There is a better solution for such a task?
Thx for your help
[Updated on: Thu, 09 September 2010 06:36] by Moderator
Re: Setting table groups in code [message #557998 is a reply to message #557855] Thu, 09 September 2010 13:34 Go to previous messageGo to next message
You can always change the group using the group expression. Something like:
if( params["Grp"].value == "Order" ){
row["ORDERNUMBER"];
}else{
row["PRODUCTCODE"];
You can also change it in the beforeFactory using some DE API like:
//TableHandle
var th =reportContext.getDesignHandle().findElement("MyTable");
//TableGroupHandle
//First group
var tgh = th.getGroups().get(0);
tgh.setKeyExpr("row[\"PRODUCTCODE\"]");
tgh.getTOC().setExpression("row[\"PRODUCTCODE\"]");
//DataItemHandle data item in group header
var di = reportContext.getDesignHandle().findElement("MyGroupLabel");
di.setResultSetColumn( "PRODUCTCODE" );
Note that the findElements require that you name your items
Jason
On 9/9/2010 5:03 AM, Mark Howard wrote:
> Hello,
> Thx for your help
icon14.gif  Re: Setting table groups in code (conditional grouping) [message #558067 is a reply to message #557855] Fri, 10 September 2010 01:58 Go to previous message
Thank you very much Jason, this was what i was looking for.
Previous Topic:Text not localized automatically
Next Topic:Joint Dataset
Current Time: Sat Jul 26 08:50:15 EDT 2025
Powered by FUDForum. Page generated in 0.03767 seconds
