Home » Eclipse Projects » Rich Client Platform (RCP) » for org.eclipse.ui.navigator.navigatorContent where/how are the "property" values defined?
for org.eclipse.ui.navigator.navigatorContent where/how are the "property" values defined? [message #557975] Thu, 09 September 2010 12:17 Go to next message
R3.4 (I know, I know), WinXP
I have a collection of plug-ins for Eclipse, including an extension to
"org.eclipse.ui.navigator.navigatorContent", which defines a
ContentProvider and so on.
I'd like to add yet another <test> using a "property", but do not know
where and how the ids and so on for the "property" test ...
The relevant part of the plugin.xml looks like this (in a <triggerPoints>):
<and>
<instanceof value="org.eclipse.core.resources.IProject" />
<test forcePluginActivation="true"
property="org.eclipse.core.resources.projectNature"
value="com.mun.ist.project.myprojectnature"/>
</and>
So -- where do I look up what property values are already defined? and
how would I plug in a new one?
(I did look at the extension-point definition, of course, and also at
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/cnf.htm,
and at some other sites found via google, but no luck ...)
thanks
Paul
Re: for org.eclipse.ui.navigator.navigatorContent where/how are the "property" values defi [message #558065 is a reply to message #557975] Fri, 10 September 2010 01:50 Go to previous message
The way I always figure this out is look for a message by Paul Webster, his email signature has the links to all of the good stuff:
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
The one you want is:
This should work fine for 3.4
Previous Topic:"No application id has been found." when I imported new dependency
Next Topic:Creating Excel sheet using RCP
Current Time: Sun Jul 27 11:26:07 EDT 2025
Powered by FUDForum. Page generated in 0.03148 seconds
