Home » Eclipse Projects » Nebula » GridTreeViewer with SWT.CHECK and filters(Lost of previous checks when resetFilters)
GridTreeViewer with SWT.CHECK and filters [message #552248] Wed, 11 August 2010 08:43 Go to next message
I'm using a GridTreeViewer with SWT.CHECK in first column :
GridViewerColumn column = new GridViewerColumn(gridtreeviewer, SWT.CHECK);
To update my model during a check, I use :
column.setEditingSupport(new CheckEditingSupport(gridtreeviewer) {
	public void setValue(Object arg0, Object arg1) {
		((Node) arg0).setChecked(((Boolean) arg1).booleanValue());
where Node is my model with a setChecked method for storing check state.
When I add a filter :
ViewerFilter[] filters = new ViewerFilter[1];
filters[0] = new CheckFilter();
gridtreeviewer.setFilters(filters);
where CheckFilter is my filter on isChecked value of my model.
No problem, the checks are kept and my tree is updated.
But when I reset the filter :
gridtreeviewer.resetFilters();
gridtreeviewer.expandAll();
I lost my checks...
So it seems that I forget something. But what ?
Have you any idea ?
Thanks.
Re: GridTreeViewer with SWT.CHECK and filters [message #557604 is a reply to message #552248] Wed, 08 September 2010 05:25 Go to previous messageGo to next message
Up.
It seems to be a bug. All my tests leads to the same results.
Checks seems to be stored without handling filters...
David
Re: GridTreeViewer with SWT.CHECK and filters [message #557826 is a reply to message #557604] Thu, 09 September 2010 02:36 Go to previous message
Can you file a bugzilla and attach a simple example to reproduce?
Tom
Am 08.09.10 11:25, schrieb David F.:
> Up.
> David
Previous Topic:Grid, GridTableViewer - multiple column sort
Next Topic:GridTreeViewer with SWT.CHECK and filters
Current Time: Wed Jul 30 17:14:32 EDT 2025
Powered by FUDForum. Page generated in 0.03772 seconds
