NullPointerException when running com.ibm.examples.chart RCP application [message #544744] |
Mon, 05 July 2010 08:03  |
Hello everyone,
I am trying to use the BIRT API, and am having the following problem:
!SESSION 2010-07-05 13:40:20.882 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_20
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments: -application com.ibm.examples.chart.application
Command-line arguments: -application com.ibm.examples.chart.application -data C:\somedir\workspaces\BirtHelios/../runtime-com.ibm.examples .chart.application -dev file:C:/somedir/workspaces/BirtHelios/.metadata/.plugins/org .eclipse.pde.core/com.ibm.examples.chart.application/dev.pro perties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.ui 4 0 2010-07-05 13:40:29.162
!MESSAGE Unable to create editor ID com.ibm.examples.chart.editors.SampleEditor: An unexpected exception was thrown.
!STACK 0
at org.eclipse.birt.chart.device.swt.SwtTextMetrics.getHeight(S wtTextMetrics.java:178)
at org.eclipse.birt.chart.computation.Methods.computeFontHeight (Methods.java:1247)
at org.eclipse.birt.chart.computation.BIRTChartComputation.comp uteFontHeight(BIRTChartComputation.java:30)
at org.eclipse.birt.chart.computation.EllipsisHelper$SimpleTest er. <init>(EllipsisHelper.java:213)
at org.eclipse.birt.chart.computation.EllipsisHelper.createSimp leTester(EllipsisHelper.java:176)
at org.eclipse.birt.chart.computation.EllipsisHelper.simpleInst ance(EllipsisHelper.java:183)
at org.eclipse.birt.chart.computation.LabelLimiter.limitLabelSi ze(LabelLimiter.java:256)
at org.eclipse.birt.chart.computation.LabelLimiter.limitLabelSi ze(LabelLimiter.java:211)
at org.eclipse.birt.chart.model.layout.impl.TitleBlockImpl.comp uteBox(TitleBlockImpl.java:112)
at org.eclipse.birt.chart.model.layout.impl.LabelBlockImpl.getP referredSize(LabelBlockImpl.java:266)
at org.eclipse.birt.chart.internal.layout.LayoutManager$ChartLa yout. <init>(LayoutManager.java:111)
at org.eclipse.birt.chart.internal.layout.LayoutManager.doLayou t_tmp(LayoutManager.java:1145)
at org.eclipse.birt.chart.internal.layout.LayoutManager.doLayou t(LayoutManager.java:1310)
at org.eclipse.birt.chart.factory.Generator.build(Generator.jav a:1092)
at com.ibm.examples.chart.widget.ChartCanvas.buildChart(ChartCa nvas.java:127)
at com.ibm.examples.chart.widget.ChartCanvas.access$1(ChartCanv as.java:120)
at com.ibm.examples.chart.widget.ChartCanvas$2.controlResized(C hartCanvas.java:111)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
at org.eclipse.swt.widgets.Control.WM_SIZE(Control.java:4813)
at org.eclipse.swt.widgets.Scrollable.WM_SIZE(Scrollable.java:2 91)
at org.eclipse.swt.widgets.Composite.WM_SIZE(Composite.java:165 3)
at org.eclipse.swt.widgets.Canvas.WM_SIZE(Canvas.java:454)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4234 )
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4873 )
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2454 )
at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable .java:80)
at org.eclipse.swt.widgets.Control.WM_WINDOWPOSCHANGED(Control. java:4970)
at org.eclipse.swt.widgets.Canvas.WM_WINDOWPOSCHANGED(Canvas.ja va:460)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4244 )
at org.eclipse.swt.internal.win32.OS.SetWindowPos(Native Method)
at org.eclipse.swt.widgets.Widget.SetWindowPos(Widget.java:1456 )
at org.eclipse.swt.widgets.Control.setBounds(Control.java:2816)
at org.eclipse.swt.widgets.Composite.setBounds(Composite.java:1 018)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:2777)
at org.eclipse.swt.widgets.Control.setSize(Control.java:3291)
at com.ibm.examples.chart.editors.SampleEditor.createPartContro l(SampleEditor.java:138)
at org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:670)
at org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:31 3)
at org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1254)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1207)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 06)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:497)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 )
at org.eclipse.ui.internal.PartStack.add(PartStack.java:483)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 )
at org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:225)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:213)
at org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:778)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:677)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:638)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2860)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2768)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2760)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2711)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2707)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2691)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2674)
at com.ibm.examples.chart.actions.SampleAction.run(SampleAction .java:55)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2629)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2593)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 27)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:663)
at com.ibm.examples.chart.Application.run(Application.java:30)
at org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hodWithException(EclipseAppContainer.java:587)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:198)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
I am using BIRT 2.6, Eclipse 3.6, am running Windows XP and have installed the following birt features (only!) BIRT Advanced XML Editor Plug-in, BIRT Chart Framework, and Business Intelligence and Reporting Tools.
I am trying to run com.ibm.examples.chart (downloaded from http://www.eclipse.org/articles/Article-BIRTChartEngine/com. ibm.examples.chart.zip). The Exception is thrown (for example) when selecting "Bar Chart" from the Sample menu.
Any insights?
Is it because Eclipse 3.6 is too new for the example? If so, is there a more current example which shows how to use the BIRT API in Eclipse 3.6? The "Simple Chart API Examples" bullet on http://wiki.eclipse.org/Integration_Examples_%28BIRT%29 seems suspiciously non-clickable...
Thanks!
Karin
Re: NullPointerException when running com.ibm.examples.chart RCP application [message #545048 is a reply to message #544744] |
Tue, 06 July 2010 10:09   |
Karin,
As a test can you download the allinone BIRT download and then import
the projects from this
download:http://www.birt-exchange.org/org/devshare/deploying -birt-reports/1187-eclipsecon-2010-birt-metal-ppt/
There are three rcp examples that use the 1) BIRT API, 2) Chart API, 3)
BIRT Viewer in rcp applications.
Jason
On 7/5/2010 8:03 AM, karins.spam@gmail.com wrote:
> Hello everyone,
> thrown.
> !STACK 0
> (Methods.java:1247)
> nvas.java:127)
> as.java:120)
> ner.java:228)
> erence.java:465)
> reaHelper.java:225)
> aHelper.java:213)
> Manager.java:778)
> er.java:638)
> chPage.java:2768)
> e.java:2760)
> ge.java:2707)
> ge.java:2691)
> ge.java:2674)
> (Realm.java:332)
> bench.java:663)
> tarter.java:369)
> tarter.java:179)
> Tools.
> the Sample menu.
> Any insights?
> Thanks!
> Karin
Re: NullPointerException when running com.ibm.examples.chart RCP application [message #557779 is a reply to message #544744] |
Wed, 08 September 2010 17:32  |
Karin,
I have just managed to get the (modified) ibm example you mentioned working in eclipse 3.6.
The problem in the ibm example is that a SWT GC reference in the SWT renderer is NULL.
I added the following to ChartCanvas:
public void paintControl(PaintEvent e) {
Composite co = (Composite) e.getSource();
final Rectangle rect = co.getClientArea();
// Add this....
render.setProperty(IDeviceRenderer.GRAPHICS_CONTEXT, e.gc);
if (cachedImage == null) {
buildChart();
drawToCachedImage(rect);
And:
public void controlResized(ControlEvent e) {
// add this....
render.setProperty(IDeviceRenderer.GRAPHICS_CONTEXT, new GC(ChartCanvas.this));
buildChart();
regards,
Dinne
FUDForum. Page generated in 0.03896 seconds
