The setting of the XML data source file in the java code [message #557641] |
Wed, 08 September 2010 08:17  |
Is the following possible?
1) Someone creates the report X with BIRT Designer and uses the A.xml as a test datasource
Later (the BIRT Designer is not used after phase 1):
2) The Java program calls the BIRT Runtime
3) The Java program loads the report X
4) The Java program sets the datasource to the file B.xml
5) The Java program runs the report X
If this is possible, how to do this? With event handlers?
BR,
Mika
[Updated on: Wed, 08 September 2010 08:18] by Moderator
Re: The setting of the XML data source file in the java code [message #558236 is a reply to message #558122] |
Fri, 10 September 2010 11:42   |
What version of BIRT are you using? Does the xml have the same
structure as the one tied to the datasource?
Here is a report I did and swapped the xml in the beforeOpen of the
dataource. Its not the same code as the API example but the concept is
the same.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21"
id="1">
<property name="comments">Copyright (c) 2007 <<Your Company
Name here>></property>
<property name="createdBy">Eclipse BIRT Designer Version
2.5.2.v20100208 Build <2.5.2.v20100210-0630></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<property name="units">in</property>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="layoutPreference">auto layout</property>
<property name="locale">en_EN</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.datatools.enablement.oda.xml" name="Data
Source" id="6">
<method name="beforeOpen"><![CDATA[importPackage(
Packages.java.io );
var mystr = "<?xml version=\"1.0\"?>";
mystr = mystr + "<library>";
mystr = mystr + "<book category=\"COOKING\">";
mystr = mystr + "<title lang=\"en\">The test3 Cook Book</title>";
mystr = mystr + "<author name=\"Miguel Ortiz\" country=\"es\"/>";
mystr = mystr + "<sold>10,312</sold>";
mystr = mystr + "<year>2005</year>";
mystr = mystr + "</book>";
mystr = mystr + "<book category=\"CHILDREN\">";
mystr = mystr + "<title lang=\"en\">Everyone is Super Special</title>";
mystr = mystr + "<author name=\"Sally Bush\" country=\"uk\"/>";
mystr = mystr + "<sold>8,222</sold>";
mystr = mystr + "<book category=\"AUTOBIOGRAPHY\">";
mystr = mystr + "<title lang=\"en\">Japanese Greetings</title>";
mystr = mystr + "<author name=\"Taro Yamada\" country=\"uk\"/>";
mystr = mystr + "<sold>7,852</sold>";
mystr = mystr + "<book category=\"WEB\">";
mystr = mystr + "<title lang=\"en\">Query Kick End</title>";
mystr = mystr + "<author name=\"James McGovern\" country=\"us\"/>";
mystr = mystr + "<sold>15,111</sold>";
mystr = mystr + "<year>2006</year>";
mystr = mystr + "<audio format=\"CD\" category=\"MUSIC\">";
mystr = mystr + "<title lang=\"en\">Feels Like Home</title>";
mystr = mystr + "<artist name=\"Norah Jones\" country=\"us\"/>";
mystr = mystr + "<sold>9,675</sold>";
mystr = mystr + "</audio>";
mystr = mystr +"</library>";
JavaStr = new java.lang.String( mystr );
bais = new ByteArrayInputStream( JavaStr.getBytes());
appcon = reportContext.getAppContext();
appcon.put("org.eclipse.datatools.enablement.oda.xml.inputStream ", bais);
//appcon.put("org.eclipse.birt.report.data.oda.xml.inputStream ",
bais);]]></method>
<property name="FILELIST">C:\test\xmldatasource.xml</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.datatools.enablement.oda.xml.dataSet "
name="Data Set" id="7">
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">category</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">title</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">name</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">sold</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">year</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">category</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">title</property>
</structure>
<structure>
<property name="nativeName">name</property>
</structure>
<structure>
<property name="nativeName">sold</property>
</structure>
<structure>
<property name="nativeName">year</property>
</structure>
</list-property>
<xml-property
name="queryText">< ![CDATA[table0#-TNAME-#table0#:#[/library/book]#:#{category; STRING;/@category},{title;STRING;/title},{name;STRING;/autho r/@name},{sold;STRING;/sold},{year;STRING;/year}]] ></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>category</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>-1</design:precision>
<design:scale>-1</design:scale>
<design:nullability>Unknown</design:nullability>
</design:attributes>
<design:usageHints>
<design:label>category</design:label>
<design:formattingHints/>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>title</design:name>
<design:position>2</design:position>
<design:usageHints>
<design:label>title</design:label>
<design:attributes>
<design:name>name</design:name>
<design:position>3</design:position>
<design:usageHints>
<design:label>name</design:label>
<design:attributes>
<design:name>sold</design:name>
<design:position>4</design:position>
<design:usageHints>
<design:label>sold</design:label>
<design:attributes>
<design:name>year</design:name>
<design:position>5</design:position>
<design:usageHints>
<design:label>year</design:label>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
<list-property name="privateDriverProperties">
<ex-property>
<name>MAX_ROW</name>
<value>-1</value>
</ex-property>
<ex-property>
<name>XML_FILE</name>
</ex-property>
</list-property>
</oda-data-set>
</data-sets>
<styles>
<style name="crosstab" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="5">
</style>
<style name="detail" id="42">
<property name="backgroundColor">#BACAE2</property>
<property name="fontFamily">"Arial"</property>
<property name="fontSize">small</property>
<property name="paddingTop">0px</property>
<property name="paddingLeft">0px</property>
<property name="paddingBottom">0px</property>
<property name="paddingRight">0px</property>
</style>
<style name="headerfooter" id="43">
<property name="backgroundColor">#004080</property>
<property name="fontWeight">bold</property>
<property name="color">#FFFFFF</property>
</style>
<style name="groupheader" id="44">
<property name="backgroundColor">#0080FF</property>
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="topMargin">1in</property>
<property name="leftMargin">1.25in</property>
<property name="bottomMargin">1in</property>
<property name="rightMargin">1.25in</property>
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<grid id="49">
<property name="borderBottomColor">#004080</property>
<property name="borderBottomWidth">medium</property>
<property name="borderLeftColor">#004080</property>
<property name="borderLeftWidth">medium</property>
<property name="borderRightColor">#004080</property>
<property name="borderRightWidth">medium</property>
<property name="borderTopColor">#004080</property>
<property name="borderTopWidth">medium</property>
<property name="width">7in</property>
<column id="50"/>
<row id="51">
<cell id="52">
<extended-item extensionName="Chart" name="mychart"
id="48">
<xml-property
name="xmlRepresentation"><![CDATA[<model:ChartWithAxes
xmlns:attribute="http://www.birt.eclipse.org/ChartModelAttribute"
xmlns:data="http://www.birt.eclipse.org/ChartModelData"
xmlns:layout="http://www.birt.eclipse.org/ChartModelLayout"
xmlns:model="http://www.birt.eclipse.org/ChartModel"
xmlns:type="http://www.birt.eclipse.org/ChartModelType">
<Type>Bar Chart</Type>
<SubType>Side-by-side</SubType>
<Block>
<Children xsi:type="layout:TitleBlock">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
<Height>0.0</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Bottom>3.0</Bottom>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Rowspan>-1</Rowspan>
<Columnspan>-1</Columnspan>
<Outline>
<Style>Solid</Style>
<Thickness>1</Thickness>
<Color>
<Transparency>255</Transparency>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
<Visible>false</Visible>
</Outline>
<Visible>true</Visible>
<Label>
<Caption>
<Value>Bar Chart Title</Value>
<Font>
<Size>16.0</Size>
<Bold>true</Bold>
<Alignment>
<horizontalAlignment>Center</horizontalAlignment>
<verticalAlignment>Center</verticalAlignment>
</Alignment>
</Font>
</Caption>
<Background xsi:type="attribute:ColorDefinition">
<Transparency>0</Transparency>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Bottom>0.0</Bottom>
<Right>3.0</Right>
</Insets>
</Label>
</Children>
<Children xsi:type="layout:Plot">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<HorizontalSpacing>5</HorizontalSpacing>
<VerticalSpacing>5</VerticalSpacing>
<ClientArea>
<Outline>
<Thickness>0</Thickness>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>0.0</Left>
<Right>0.0</Right>
</Insets>
</ClientArea>
</Children>
<Children xsi:type="layout:Legend">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>2.0</Top>
<Left>2.0</Left>
<Bottom>2.0</Bottom>
<Right>2.0</Right>
</Insets>
</ClientArea>
<Text>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Text>
<Orientation>Vertical</Orientation>
<Direction>Top_Bottom</Direction>
<Separator>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Separator>
<Position>Right</Position>
<ItemType>Categories</ItemType>
<Title>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Above</TitlePosition>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>509.99999999759996</Width>
<Height>309.00000000240004</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
</Block>
<Dimension>Two_Dimensional</Dimension>
<Units>Points</Units>
<SeriesThickness>10.0</SeriesThickness>
<SampleData>
<BaseSampleData>
<DataSetRepresentation>A, B, C</DataSetRepresentation>
</BaseSampleData>
<OrthogonalSampleData>
<DataSetRepresentation>5,4,12</DataSetRepresentation>
<SeriesDefinitionIndex>0</SeriesDefinitionIndex>
</OrthogonalSampleData>
</SampleData>
<Interactivity/>
<EmptyMessage>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</EmptyMessage>
<Axes>
<Type>Text</Type>
<Title>
<Caption>
<Value>X-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Below</TitlePosition>
<AssociatedAxes>
<Type>Linear</Type>
<Title>
<Caption>
<Value>Y-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
<Rotation>90.0</Rotation>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Left</TitlePosition>
<SeriesDefinitions>
<Query>
<Definition></Definition>
</Query>
<SeriesPalette>
<Entries xsi:type="attribute:ColorDefinition">
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>7</Red>
<Green>146</Green>
<Blue>94</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>0</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>255</Blue>
</Entries>
<Red>128</Red>
<Green>64</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>80</Red>
<Green>240</Green>
<Blue>120</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>0</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>0</Blue>
</Entries>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
</SeriesPalette>
<Series xsi:type="type:BarSeries">
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row["sold"]</Definition>
</DataDefinition>
<SeriesIdentifier></SeriesIdentifier>
<DataPoint>
<Components>
<Type>Orthogonal_Value</Type>
</Components>
<Separator>, </Separator>
</DataPoint>
<LabelPosition>Outside</LabelPosition>
<Stacked>false</Stacked>
<Riser>Rectangle</Riser>
</Series>
<Grouping>
<Enabled>false</Enabled>
<GroupingInterval>2.0</GroupingInterval>
<GroupType>Text</GroupType>
<AggregateExpression>Sum</AggregateExpression>
</Grouping>
<Sorting>Ascending</Sorting>
</SeriesDefinitions>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<LabelPosition>Left</LabelPosition>
<MajorGrid>
<LineAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickStyle>Across</TickStyle>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
<LineAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</TickAttributes>
</MinorGrid>
<Scale>
<MinorGridsPerUnit>5</MinorGridsPerUnit>
</Scale>
<Origin>
<Type>Min</Type>
<Value xsi:type="data:NumberDataElement">
<Value>0.0</Value>
</Value>
</Origin>
<PrimaryAxis>true</PrimaryAxis>
<Percent>false</Percent>
</AssociatedAxes>
<SeriesDefinitions>
<Query>
</Query>
<SeriesPalette>
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>7</Red>
<Green>146</Green>
<Blue>94</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>0</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>255</Blue>
</Entries>
<Red>128</Red>
<Green>64</Green>
<Blue>64</Blue>
</Entries>
<Re
Re: The setting of the XML data source file in the java code [message #558748 is a reply to message #557641] |
Tue, 14 September 2010 05:58   |
My BIRT version is 2.6.0 (for both the designer and runtime).
I tried with the simple data.xml, test.rptdesign and RunReport.java and the lines:
ByteArrayInputStream bais = new ByteArrayInputStream(xmlstring.getBytes());
task.getAppContext().put("org.eclipse.datatools.enablement.oda.xml.inputStream ", bais);
are not working. The test.rptdesign report only prints the contents of the one data element of the data.xml file: "test". The RunReport.java didn't replace "test" with the "ttteeessstttt" in my testing.
I also tried the beforeOpen method in the .rptdesign file (test2.rptdesign), but it didn't work with Eclipse viewer or with the RunReport.java example.
Is it possible to see my own beforeOpen method functioning with Eclipse viewer or do I have to call the report from the java code?
Do you know how to fix the problem? I attached below the test files. If you know how to fix the examples, could you send the fixed examples. That would be great!
Mika
data.xml:
<data>test</data>
test.rptdesign:
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.6.0.v20100531 Build <2.6.0.v20100609-1613></property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">96</property>
<data-sources>
<oda-data-source extensionID="org.eclipse.datatools.enablement.oda.xml" name="Data Source" id="7">
<property name="FILELIST">C:\data.xml</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.datatools.enablement.oda.xml.dataSet" name="Data Set" id="8">
<structure>
<property name="name">data</property>
</structure>
</list-property>
</structure>
<structure>
<property name="nativeName">data</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[table0#-TNAME-#table0#:#[/data]#:#{data;STRING;}]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml version="1.0" encoding="UTF-8"?>
<model:DesignValues xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design" xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<design:attributes>
<design:name>data</design:name>
<design:usageHints>
<design:label>data</design:label>
<design:criteria/>
<ex-property>
<value>-1</value>
</ex-property>
<ex-property>
</ex-property>
</list-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
</style>
<style name="crosstab" id="6">
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
<text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</page-setup>
<body>
<data id="9">
<property name="whiteSpace">nowrap</property>
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<text-property name="displayName">data</text-property>
<expression name="expression" type="javascript">dataSetRow["data"]</expression>
</structure>
</list-property>
<property name="resultSetColumn">data</property>
</data>
</body>
</report>
RunReport.java:
import java.io.ByteArrayInputStream;
import java.util.HashMap;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
import org.eclipse.birt.report.engine.api.ReportEngine;
public class RunReport {
String templateFilename = "c:\\test.rptdesign";
EngineConfig config = new EngineConfig();
config
.setEngineHome("C:\\Documents and Settings\\mitapana\\My Documents\\xml2pdf\\examples\\birt\\birt-runtime-2_6_0\\birt-runtime-2_6_0\\ReportEngine");
ReportEngine engine = new ReportEngine(config);
IReportRunnable report = null;
try {
report = engine.openReportDesign(templateFilename);
} catch (Exception e) {
System.err.println("Report " + templateFilename + " not found!\n");
engine.destroy();
return;
IRunAndRenderTask task = engine.createRunAndRenderTask(report);
// use xmlstring
String xmlstring = "<?xml version=\"1.0\" encoding=\"UTF-8\"?> ";
xmlstring += "<data>ttteeessstttt</data>";
bais);
HTMLRenderOption options = new HTMLRenderOption();
options.setOutputFormat(HTMLRenderOption.OUTPUT_FORMAT_PDF);
String output = templateFilename.replaceFirst(".rptdesign", "." + HTMLRenderOption.OUTPUT_FORMAT_PDF);
options.setOutputFileName(output);
task.setRenderOption(options);
task.setParameterValues(new HashMap());
// Run the report.
try {
task.run();
} catch (EngineException e1) {
System.err.println("Report " + templateFilename + " run failed.\n");
System.err.println(e1.toString());
engine.destroy();
Platform.shutdown();
test2.rptdesing (same as test.rptdesign, but includes the beforeOpen method):
<data-sources>
Packages.java.io );
mystr = mystr + "<data>ttteeessstttt</data>";
]]></method>
</oda-data-source>
</data-sources>
<data-sets>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
</list-property>
<design:attributes>
<design:usageHints>
<design:criteria/>
<ex-property>
<value>-1</value>
</ex-property>
<ex-property>
</ex-property>
</list-property>
</oda-data-set>
</data-sets>
<styles>
</style>
</style>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
</text>
</page-footer>
</page-setup>
<body>
<data id="9">
<structure>
</structure>
</list-property>
</data>
</body>
</report>
[Updated on: Tue, 14 September 2010 06:17] by Moderator
FUDForum. Page generated in 0.27338 seconds
