EclipseLink 2.1 does not work together with obfuscated jar [message #557723] |
Wed, 08 September 2010 11:25  |
Hi all,
after upgrading from 1.2 to EclipseLink 2.1. we get a strange error message, when we try to start our application (see below).
We obfuscate some classes with proguard. If we replace the partly obfuscated production jar with the unobfuscated jar everything works fine.
We configured proguard to keep all persistent classes, all annotations, to do no shrinking and no optimization. So no classes that are referenced in the persistence.xml or ..-orm-xml are obfuscated. And with EclipseLink 1.x everything worked fine.
If I look into the obfuscated jar with a decompiler it looks fine. Alle the persistent classes are in place, the annotations are still there.
Does anyone have a clue what the reason for this is? We spend two complete days for hunting this issue and would have to roll back to 1.2 otherwise.
BTW: We get exactly the same (unhelpful) error message like described in case:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=324408
Maybe this problem is also related to some problems with the asm library that's used in EclipseLink
regards,
Hans
Stack Trace:
2010/09/08 17:15:20.537 | [INFO ][init] Creating persistence manager for persistence unit 'terminology-h2'
2010/09/08 17:15:25.004 | [EL Severe]: 2010-09-08 17:15:24.974--ServerSession(14995661)--Local Exception Stack:
2010/09/08 17:15:25.004 | Exception [EclipseLink-0] (Eclipse Persistence Services - 2.1.1.v20100817-r8050): org.eclipse.persistence.exceptions.IntegrityException
2010/09/08 17:15:25.004 | Descriptor Exceptions:
2010/09/08 17:15:25.004 | ---------------------------------------------------------
2010/09/08 17:15:25.004 | Exception [EclipseLink-93] (Eclipse Persistence Services - 2.1.1.v20100817-r8050): org.eclipse.persistence.exceptions.DescriptorException
2010/09/08 17:15:25.004 | Exception Description: The table [CUSTOMFIELDVALUEEJB] is not present in this descriptor.
2010/09/08 17:15:25.004 | Descriptor: RelationalDescriptor(com.ac.api.implementation.term.pe rsistence.TermEjb --> [DatabaseTable(TERMEJB)])
2010/09/08 17:15:25.004 | Runtime Exceptions:
2010/09/08 17:15:25.004 | java.lang.IndexOutOfBoundsException: Index: 0, Size: 0
2010/09/08 17:15:25.004 | at org.eclipse.persistence.internal.sessions.DatabaseSessionImp l.initializeDescriptors(DatabaseSessionImpl.java:471)
2010/09/08 17:15:25.004 | at org.eclipse.persistence.internal.sessions.DatabaseSessionImp l.initializeDescriptors(DatabaseSessionImpl.java:406)
2010/09/08 17:15:25.004 | at org.eclipse.persistence.internal.sessions.DatabaseSessionImp l.postConnectDatasource(DatabaseSessionImpl.java:666)
2010/09/08 17:15:25.004 | at org.eclipse.persistence.internal.sessions.DatabaseSessionImp l.login(DatabaseSessionImpl.java:628)
2010/09/08 17:15:25.004 | at org.eclipse.persistence.internal.jpa.EntityManagerFactoryPro vider.login(EntityManagerFactoryProvider.java:230)
2010/09/08 17:15:25.004 | at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl. deploy(EntityManagerSetupImpl.java:380)
2010/09/08 17:15:25.004 | at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImp l.getServerSession(EntityManagerFactoryImpl.java:157)
2010/09/08 17:15:25.004 | at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImp l.createEntityManagerImpl(EntityManagerFactoryImpl.java:214)
2010/09/08 17:15:25.004 | at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImp l.createEntityManager(EntityManagerFactoryImpl.java:202)
2010/09/08 17:15:25.004 | at ac.WI.createEntityManager(Unknown Source)
[Updated on: Wed, 08 September 2010 11:27] by Moderator
FUDForum. Page generated in 0.28552 seconds
