Home » Modeling » Graphiti » Properties and Listeners(HELP ! (please!!!))
Properties and Listeners [message #556319] Tue, 31 August 2010 14:32 Go to next message
Hi guys,
May I ask your help to understand if I am properly implementing the listeners for two fields in the property section?
My questions are:
Q1: is it correct to have a different listener for each field/attribute?
Q2: is it correct the way I am implementing the refresh method? is there a way to understand which element changed in order to just refresh the element which is changed?
Q2: if I have another businessObject, namely "IntentionSpec", which:
- is a specialization of the businessObject "Intention"
- has the two attributes inherited from "Intention" plus another attribute called "newAttribute"
and I want that in the property section when:
i) an "Intention" diagram element is selected --> two attributes are visualized in the panel and if I edit them the "Intention" business object is changed (similar to the actual code)
ii) an "IntentsionSpec" is selected ---> three attributes are visualized in the panel and if I edit them the "IntentionSpec" business object is changed.
Do you have some suggestions how to do that?
For example, should I put everything it the same:
public void createControls(Composite parent, TabbedPropertySheetPage tabbedPropertySheetPage)
and add some lines such as:
Object bo= Graphiti.getLinkService().getBusinessObjectForLinkedPictogra mElement(pe);
if (bo == Intention) then
<actual code>
else
<code to visualize the previous two fields + the newAttribute, and in this case I use the same listeners plus a new one>
Is this correct?
Thank you very much for any help or suggestions Smile
public class IntentionSection extends GFPropertySection implements ITabbedPropertyConstants {
private Text nameText;
private Text descriptionText;
private ModifyListener listenerIntentionName = new ModifyListener(){
public void modifyText (ModifyEvent arg0){
PictogramElement pe = getSelectedPictogramElement();
Intention bimElement = (Intention) Graphiti.getLinkService().getBusinessObjectForLinkedPictogra mElement(pe);
bimElement.setName(nameText.getText());
bimElement.setDescription(descriptionText.getText());
System.out.print("\Name setted: "+bimElement.getName());
private ModifyListener listenerIntentionDescription = new ModifyListener(){
System.out.print("\nDescription setted: "+bimElement.getDescription());
public void createControls(Composite parent, TabbedPropertySheetPage tabbedPropertySheetPage) {
super.createControls(parent, tabbedPropertySheetPage);
TabbedPropertySheetWidgetFactory factory = getWidgetFactory();
Composite composite = factory.createFlatFormComposite(parent);
FormData data;
// nameText
nameText = factory.createText(composite, ""); //$NON-NLS-1$
data = new FormData();
//data.left = new FormAttachment(0, STANDARD_LABEL_WIDTH);
data.left = new FormAttachment(0, 100);
data.right = new FormAttachment(100, 0);
data.top = new FormAttachment(0, VSPACE);
nameText.setLayoutData(data);
//Daniele: I am adding the listener here
nameText.addModifyListener(listenerIntentionName);
CLabel valueLabel = factory.createCLabel(composite, "Name:"); //$NON-NLS-1$
data.left = new FormAttachment(0, 0);
data.right = new FormAttachment(nameText, -HSPACE);
data.top = new FormAttachment(nameText, 0, SWT.CENTER);
valueLabel.setLayoutData(data);
// descriptionText
descriptionText = factory.createText(composite, "", SWT.MULTI | SWT.BORDER | SWT.V_SCROLL); //$NON-NLS-1$
//TODO: try to modify the layout for property
data.top = new FormAttachment(nameText, VSPACE);
descriptionText.setLayoutData(data);
descriptionText.addModifyListener(listenerIntentionDescripti on);
CLabel valueLabelDescription = factory.createCLabel(composite, "Description:"); //$NON-NLS-1$
//-HSPACE
data.right = new FormAttachment(descriptionText, -HSPACE);
data.top = new FormAttachment(descriptionText, 0, SWT.CENTER);
valueLabelDescription.setLayoutData(data);
public void refresh() {
if (pe != null) {
Object bo = Graphiti.getLinkService().getBusinessObjectForLinkedPictogra mElement(pe);
// the filter assured, that it is a Intention
if (bo == null)
return;
// Remove listener
nameText.removeModifyListener(listenerIntentionName);
// Modify values of the properties
String name = ((Intention) bo).getName();
System.out.print("\nSet Name property: "+name);
nameText.setText(name == null ? "" : name); //$NON-NLS-1$
// (RE)Add listener
// Remove listener
descriptionText.removeModifyListener(listenerIntentionDescri ption);
String description = ((Intention) bo).getDescription();
System.out.print("\nSet Description property: "+description);
descriptionText.setText(description == null ? "" : description); //$NON-NLS-1$
// (RE)Add listener
descriptionText.addModifyListener(listenerIntentionName);
} Crying or Very Sad
[Updated on: Fri, 03 September 2010 14:57] by Moderator
Re: Properties and Listeners [message #556855 is a reply to message #556319] Thu, 02 September 2010 15:44 Go to previous messageGo to next message
Hi guys,
with the above code I have the problem reported below Sad Sad Sad
Do you have any suggestions?
Please Smile, I am stuck
Thank you very much!!!
Daniele
eclipse.buildId=I20100608-0911
java.version=1.6.0_18
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_CA
Framework arguments: -product org.eclipse.platform.ide
Command-line arguments: -product org.eclipse.platform.ide -data /home/daniele/workspace/../runtime-EclipseApplication -dev file:/home/daniele/workspace/.metadata/.plugins/org.eclipse. pde.core/Eclipse Application/dev.properties -os linux -ws gtk -arch x86
Error
Thu Sep 02 15:38:22 EDT 2010
Unhandled event loop exception
java.lang.IllegalStateException: Cannot modify resource set without a write transaction
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.a ssertWriting(TransactionChangeRecorder.java:348)
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.a ppendNotification(TransactionChangeRecorder.java:302)
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.p rocessObjectNotification(TransactionChangeRecorder.java:284)
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.n otifyChanged(TransactionChangeRecorder.java:240)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify (BasicNotifierImpl.java:280)
at BIM.impl.ThingImpl.setName(ThingImpl.java:210)
at org.eclipse.graphiti.bim.property.IntentionSection$1.modifyT ext(IntentionSection.java:58)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:173)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3552)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3171)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2629)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2593)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 27)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:663)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
[Updated on: Thu, 02 September 2010 15:45] by Moderator
Re: Properties and Listeners [message #557284 is a reply to message #556319] Mon, 06 September 2010 08:53 Go to previous messageGo to next message
you can not modify an EObject directly if it is controlled
by an EditingDomain.
See EMF Model Transaction Developer Guide
in the eclipse help for an explanation of the concepts.
In general, you can access the EditingDomain of an EObject
via
org.eclipse.emf.transaction.util.TransactionUtil.getEditingD omain(...)
Also you can use the method
public void execute(IFeature feature, IContext context)
of the GFPropertySection to have your model modification executed
inside a feature. Then the framework takes care of using the editingdomain of the diagram editor.
Best, Tim
Re: Properties and Listeners [message #557512 is a reply to message #557284] Tue, 07 September 2010 18:07 Go to previous messageGo to next message
Thank you very much Tim!!!
I much appreciated your help. Actually, I am trying to understand how this work looking at the guide you suggested.
Daniele
p.s.
I was wondering if you have also an example within the graphiti tutorial which I can use to better undestand the editingDomain or the execute method.
Re: Properties and Listeners [message #557522 is a reply to message #557512] Tue, 07 September 2010 19:47 Go to previous messageGo to next message
Hi Tim,
what about this solution (w.r.t. the above code)?
it seems to work but I am not sure if this is the correct way to do that.
Thanks in advance for any suggestions
Daniele
// set the new name for the Intention
final Intention bimElement = (Intention) Graphiti.getLinkService().getBusinessObjectForLinkedPictogra mElement(pe);
TransactionalEditingDomain editingDomain = TransactionUtil.getEditingDomain(bimElement);
editingDomain.getCommandStack().execute(new RecordingCommand(editingDomain) {
protected void doExecute() {
[Updated on: Tue, 07 September 2010 19:48] by Moderator
Re: Properties and Listeners [message #557717 is a reply to message #556319] Wed, 08 September 2010 11:19 Go to previous messageGo to next message
Looks good for me...
Best, Tim
Re: Properties and Listeners [message #557738 is a reply to message #557717] Wed, 08 September 2010 12:03 Go to previous messageGo to next message
Thank you Tim for your support!!
Daniele
Re: Properties and Listeners [message #558034 is a reply to message #557738] Thu, 09 September 2010 16:59 Go to previous messageGo to next message
I've been looking at this issue as well. I tried to implement an update to my domain model from a PropertySheet change using a feature, since that seemed like the preferred method. However, my attempt to set an attribute in the domain model failed because there was no active transaction.
I noticed that the implementation of execute() in GFPropertySection performs its command execution without a domain editor. When I changed it to look more like the command executions in AbstractFeatureProvider, it worked. Specifically, I substituted:
public void execute(final IFeature feature, final IContext context)
final TransactionalEditingDomain editingDomain =
this.getDiagramTypeProvider().getDiagramEditor().getEditingD omain();
CommandExec.getSingleton().executeCommand(
new GenericFeatureCommandWithContext(feature, context),
editingDomain);
That fixed my property originated update of the domain model.
Am I missing something in my process which would make the existing implementation of execute in GFPropertySection work?
Re: Properties and Listeners [message #558841 is a reply to message #556319] Tue, 14 September 2010 11:18 Go to previous messageGo to next message
probably you missed the last fix.
I checked in the fix to make it work on 6th of september.
If you update graphiti it should work
out of the box.
Best, Tim
Re: Properties and Listeners [message #558843 is a reply to message #558034] Tue, 14 September 2010 11:23 Go to previous messageGo to next message
Hi Rhett,
If you have a minute can you post how " to implement an update to my domain model from a PropertySheet change using a feature, since that seemed like the preferred method."
What I did work perfectly but since, as you said, using feature is the preferred method can you provide an example in this thread? (and maybe say why is the preffered one and why I should use that Smile?)
I will much appreciate that.
Daniele
[Updated on: Tue, 14 September 2010 11:25] by Moderator
Re: Properties and Listeners [message #568087 is a reply to message #557717] Wed, 08 September 2010 12:03 Go to previous messageGo to next message
Daniele
Re: Properties and Listeners [message #568109 is a reply to message #568087] Thu, 09 September 2010 16:59 Go to previous messageGo to next message
editingDomain);
Re: Properties and Listeners [message #568279 is a reply to message #568109] Tue, 14 September 2010 11:23 Go to previous messageGo to next message
Hi Rhett,
Daniele
Re: Properties and Listeners [message #692071 is a reply to message #568279] Sun, 03 July 2011 08:07 Go to previous messageGo to next message
I'm asking myself the same question, if it is a common way, to have a different focusListener for each field/combo/attribute etc.. I don't know how to assure, that only the textField, of which I was changing the value, is updated in my model. Currently I'm resetting all attributes of my model, when the focus of an element is lost, to make sure, the new value is updated.
Re: Properties and Listeners [message #714808 is a reply to message #568279] Thu, 11 August 2011 10:41 Go to previous message
Daniele wrote on Tue, 14 September 2010 11:23
Hi Rhett,
I would also be very interested in an example for the method GFPropertySection.execute(IFeature feature, IContext context)
Anyone Wink
thanks in advance!
EDIT:
found an example!
http://www.eclipse.org/graphiti/developers/resources/ModifyListener.txt
[Updated on: Thu, 11 August 2011 11:27] by Moderator
Previous Topic:Validation for DirectEditFeatures
Next Topic:Bug with Undo after RenameEClassFeature
Current Time: Sat Jul 26 10:43:56 EDT 2025
Powered by FUDForum. Page generated in 0.52469 seconds
