Home » Modeling » M2T (model-to-text transformation) » [Acceleo 3] ownedElement + filter + reject : unexpected behavior
[Acceleo 3] ownedElement + filter + reject : unexpected behavior [message #557488] Tue, 07 September 2010 12:42 Go to next message
Hi all,
For this test, you will just need a tiny UML model : a class diagram containing one package and one or more classes with public visibility in that package.
First script sample :
   [let classes : Sequence(Class) =
         pkg.eAllContents(Class)->reject
            (c : Class |
             c.visibility <> VisibilityKind::public)]
      [for (c : Class | classes)]
         [c.name/]
      [/for]
   [/let]
This one works fine, you will see the list of all class names.
Second script sample :
         pkg.ownedElement->filter(Class)->reject
            (c : Class |
         [c.name/]
      [/for]
   [/let]
Ouch, what's happening ? No more classes ?
Is that the reject condition which fails ?
Try this one :
            (c : Class | false)]
         [c.name/]
      [/for]
   [/let]
Same... no more class.
So is that the sole application of reject ?
Try this one :
         pkg.ownedElement->filter(Class)]
         [c.name/]
      [/for]
   [/let]
All classes back now.
Do not know why, reject seems to not work when it is applied to the result of "pkg.ownedElement->filter(Class)", while it works when it is applied to the result of "pkg.eAllContents(Class)"
[Updated on: Tue, 07 September 2010 12:43] by Moderator
Re: [Acceleo 3] ownedElement + filter + reject : unexpected behavior [message #557536 is a reply to message #557488] Tue, 07 September 2010 22:22 Go to previous messageGo to next message
Hi Yannick,
The problem is not coming from the filter or the reject it is coming from an invalid cast between the result of the reject and the type Sequence.
http://a.imageshack.us/img28/8693/reject.png
You can see in this picture that it works with a set but not with a sequence. Our documentation says that filter return a sequence, I'm pretty sure (with that problem) that it is returning a set instead or even better an OrderedSet (you should try with OrderedSet). So the documentation is false or our return type is false. I will check with the rest of the team to see which one is wrong. And we will correct that.
Stephane Begaudeau, Obeo
[Updated on: Tue, 07 September 2010 22:29] by Moderator
Re: [Acceleo 3] ownedElement + filter + reject : unexpected behavior [message #557546 is a reply to message #557536] Wed, 08 September 2010 00:26 Go to previous messageGo to next message
Stéphane,
You are right it works if I turn the type of the let variable into Set instead of Sequence.
Stephane Begaudeau
By the way, the Acceleo script editor, on Ctrl+Space, says filter returns Collection(T).
I've just also checked another topic of matter : Ctrl+Space at the location of reject, does not show reject in the list (nor select).
Does it all have to deal with something I read (do not remember the link) from Laurent on the web, talking about Acceleo improvements over standard OCL, about implicit conversions ?
Re: [Acceleo 3] ownedElement + filter + reject : unexpected behavior [message #557556 is a reply to message #557536] Wed, 08 September 2010 01:16 Go to previous messageGo to next message
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=321011
Ed Willink
On 08/09/2010 03:22, Stephane Begaudeau wrote:
> Hi Yannick,
> Sequence.
> pretty sure (with that problem) that it is returning a set instead. So
> that.
Re: [Acceleo 3] ownedElement + filter + reject : unexpected behavior [message #557667 is a reply to message #557556] Wed, 08 September 2010 09:13 Go to previous messageGo to next message
--------------000604010806090603060605
Thanks for the link to the bugzilla Ed, didn't remember where this
discussion had been held :).
In summary :
With the Acceleo 3.0.0 build, "filter" always returned a Sequence, no
matter what the source type was. This is no longer the case on HEAD and
the fix will be present in the 3.1.0M2 build (though not in the 3.0.1
maintenance builds has it changes existing behavior).
What you have is "package.ownedElement->filter". UML has no "ordered"
properties IIRC (seems like UML doesn't like the idea of ordering
things); and thus you _cannot_ have a Sequence (or an OrderedSet for
that matter) as a result. You have either a Set or a Bag depending on
whether the ownedElement property accepts duplicates. Stéphane's test
seem to indicate it is a Set.
You have to give extra attention when using the MOFM2T "let" block which
behavior is _not_ the same as the plain OCL "let". Acceleo's "let" does
allow for the creation of variables ... but it cannot throw compilation
errors with the type of the init expression not corresponding to the
variable type : the specification mentions that Acceleo's "let" should
act as an "oclAsType" (or "instanceof" if you prefer Java terms).
Our documentation is wrong about the return type of the "filter"
operation, it has been fixed on HEAD and the return type will no longer
be documented as "Sequence(X)" in 3.1.0M2.
I believe these cover all of the confusion, let me know if I missed a
point :).
Laurent Goubet
Obeo
Ed Willink wrote:
> Hi
> Regards
> Ed Willink
>> Hi Yannick,
>> Sequence.
>> that.
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------000604010806090603060605--
Re: [Acceleo 3] ownedElement + filter + reject : unexpected behavior [message #557737 is a reply to message #557667] Wed, 08 September 2010 11:58 Go to previous message
Hi Laurent
> things);
Not entirely true.
Operation.ownedParameter
TemplateSignature.parameter
Expression.operand
are ordered.
Ed Willink
Previous Topic:[Acceleo 3] Question about debugging templates
Next Topic:[Xtend/Xpand] Encoding problem
Current Time: Sat Jul 26 18:45:12 EDT 2025
Powered by FUDForum. Page generated in 0.24801 seconds
