Home » Archived » M2M (model-to-model transformation) » [QVTo] Failed to load model extent
[QVTo] Failed to load model extent [message #557246] Mon, 06 September 2010 05:16 Go to next message
recently i encountered an error, when i try to start a transformation i get the following message:
Transformation runner initiliaze
Failed to load model extent uri=platform:/resource/AADLv1/in/TransModelv1.aaxl
For input string: "aadlSpec[@name=TransModelv1]
i thougth that Xpath could be the problem. The source models are provided in an XMI representation, object references are made with xpath. But the references work just fine in other parts of the source model.
Perhaps the source MetaModel is the problem ? The MetaModel is specified in multiple ecore files, referencing each other. I created one generator model and deployed the model code as plugin.
In the Metamodel Explorer i get for each source ecore-file a single MetaModel.
Has anybody expereience with multiple Metamodels or encountered the same problem ?
thanks in advance
regards
PS: Sorry for double posting, please just ignore the other post
[Updated on: Mon, 06 September 2010 05:26] by Moderator
Re: [QVTo] Failed to load model extent [message #557470 is a reply to message #557246] Tue, 07 September 2010 10:38 Go to previous message
I identified the problem
the provided source models in XMI representation use the XPath reference construct. Obviously QVT cannot resolve the references properly.
Thus the source models have to use the EMF reference format
[Updated on: Tue, 07 September 2010 10:44] by Moderator
Previous Topic:[ATL] PackageImpl cannot be cast to Classifi
Next Topic:[QVTo] Timing transformations
Current Time: Sun Jul 20 22:28:15 EDT 2025
Powered by FUDForum. Page generated in 0.03566 seconds
