reset pagenumber on group without interval [message #556936] |
Fri, 03 September 2010 05:02  |
I have a report with a group and many detailrows with different hights, so I can not define an interval for the pagebreak. The bug 233755 https://bugs.eclipse.org/bugs/show_bug.cgi?id=233755 describes my problem. It is fixed, but in comment 3 was written, that in version 2.5.1 the same problem is still there.
I am using birt 2.5.2 and tested the report also in 2.6.0 with the same result. The pagebreak event was not called for dynamic pagebreaks in the render methode. The print methode is pdf. The run and render task is seperated.
Why the bug 233755 is not reopened? Or is there an other solution for this problem in a newer version?
pigargo
Re: reset pagenumber on group without interval [message #557038 is a reply to message #556936] |
Fri, 03 September 2010 13:00   |
Have you tried using page scripts?
Take a look at the following example in BIRT 2.6.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.6.0.v20100531 Build <2.6.0.v20100609-1613></property>
<property name="units">in</property>
<method name="beforeFactory"><![CDATA[prevGroupKey = "";
groupPageNumber = 1;
reportContext.setGlobalVariable("gGROUP_NAME", "");
reportContext.setGlobalVariable("gGROUP_PAGE", 1);
]]></method>
<method name="onPageEnd"><![CDATA[ //var groups =
this.getInstancesByElementName("GROUP_STATUS");
var groups = this.getInstancesByElementId(73);
var group;
if( groups != null ){
group = groups[0];
var groupKey = group.value;
//var prevGroupKey = reportContext.getPageVariable("GROUP_NAME");
//var groupPageNumber = reportContext.getPageVariable("GROUP_PAGE");
var prevGroupKey = reportContext.getGlobalVariable("gGROUP_NAME");
var groupPageNumber = reportContext.getGlobalVariable("gGROUP_PAGE");
if( prevGroupKey == null ){
prevGroupKey = "";
//prevGroupKey = reportContext.getPageVariable("GROUP_NAME");
//groupPageNumber = reportContext.getPageVariable("GROUP_PAGE");
if (prevGroupKey == groupKey)
if (groupPageNumber != null)
groupPageNumber = parseInt(groupPageNumber) + 1;
else {
else {
prevGroupKey = groupKey;
reportContext.setPageVariable("GROUP_NAME", groupKey);
reportContext.setPageVariable("GROUP_PAGE", groupPageNumber);
reportContext.setGlobalVariable("gGROUP_NAME", groupKey);
reportContext.setGlobalVariable("gGROUP_PAGE", groupPageNumber);
var groupTotalPage = reportContext.getPageVariable("GROUP_TOTAL_PAGE");
if (groupTotalPage == null)
groupTotalPage = new java.util.HashMap();
reportContext.setPageVariable("GROUP_TOTAL_PAGE", groupTotalPage);
groupTotalPage.put(groupKey, groupPageNumber);
} ]]></method>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="layoutPreference">fixed layout</property>
<property name="bidiLayoutOrientation">ltr</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="7">
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="9">
<list-property name="columnHints">
<structure>
<property name="columnName">ORDERNUMBER</property>
<text-property
name="displayName">ORDERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">ORDERDATE</property>
<text-property
name="displayName">ORDERDATE</text-property>
</structure>
<structure>
<property name="columnName">REQUIREDDATE</property>
<text-property
name="displayName">REQUIREDDATE</text-property>
</structure>
<structure>
<property name="columnName">SHIPPEDDATE</property>
<text-property
name="displayName">SHIPPEDDATE</text-property>
</structure>
<structure>
<property name="columnName">STATUS</property>
<text-property
name="displayName">STATUS</text-property>
</structure>
<structure>
<property name="columnName">COMMENTS</property>
<text-property
name="displayName">COMMENTS</text-property>
</structure>
<structure>
<property name="columnName">CUSTOMERNUMBER</property>
<text-property
name="displayName">CUSTOMERNUMBER</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">ORDERDATE</property>
<property name="dataType">date</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">REQUIREDDATE</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">SHIPPEDDATE</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">STATUS</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">COMMENTS</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">CUSTOMERNUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">ORDERDATE</property>
<property name="nativeDataType">91</property>
</structure>
<structure>
<property name="nativeName">REQUIREDDATE</property>
</structure>
<structure>
<property name="nativeName">SHIPPEDDATE</property>
</structure>
<structure>
<property name="nativeName">STATUS</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">COMMENTS</property>
</structure>
<structure>
<property name="nativeName">CUSTOMERNUMBER</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from CLASSICMODELS.ORDERS]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERDATE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>91</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>ORDERDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERDATE</design:label>
<design:displaySize>10</design:displaySize>
<design:attributes>
<design:name>REQUIREDDATE</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>REQUIREDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>REQUIREDDATE</design:label>
<design:attributes>
<design:name>SHIPPEDDATE</design:name>
<design:position>4</design:position>
<design:uiHints>
<design:displayName>SHIPPEDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>SHIPPEDDATE</design:label>
<design:attributes>
<design:name>STATUS</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>STATUS</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>STATUS</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>COMMENTS</design:name>
<design:position>6</design:position>
<design:precision>32700</design:precision>
<design:uiHints>
<design:displayName>COMMENTS</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>COMMENTS</design:label>
<design:displaySize>32700</design:displaySize>
<design:attributes>
<design:name>CUSTOMERNUMBER</design:name>
<design:position>7</design:position>
<design:uiHints>
<design:displayName>CUSTOMERNUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CUSTOMERNUMBER</design:label>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">"Verdana"</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
<style name="table-header" id="97">
<property name="backgroundColor">#6078BF</property>
<property name="fontFamily">"Arial"</property>
<property name="fontSize">small</property>
<property name="fontWeight">bold</property>
<property name="color">#FFFFFF</property>
<property name="paddingTop">0px</property>
<property name="paddingLeft">0px</property>
<property name="paddingBottom">0px</property>
<property name="paddingRight">0px</property>
</style>
<style name="table-footer" id="98">
</style>
<style name="table-detail" id="99">
<property name="backgroundColor">#E6ECFF</property>
<property name="fontSize">x-small</property>
<property name="color">#000080</property>
</style>
<style name="table-group-header-1" id="100">
<property name="backgroundColor">#809FFF</property>
</style>
<style name="table-group-footer-1" id="101">
</style>
<style name="special-header" id="102">
<property name="fontSize">medium</property>
</style>
<style name="crosstab-detail" id="103">
</style>
<style name="crosstab-header" id="104">
</style>
<style name="mydata" id="105">
<property name="color">orange</property>
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-header>
<grid id="74">
<column id="75"/>
<column id="76"/>
<row id="78">
<property name="style">special-header</property>
<cell id="79">
<auto-text id="83">
<property
name="textUnderline">underline</property>
<property
name="type">page-variable</property>
<property
name="pageVariable">GROUP_NAME</property>
</auto-text>
</cell>
<cell id="80">
<grid id="88">
<property name="width">2.125in</property>
<column id="89">
<property
name="width">0.25in</property>
</column>
<column id="95">
<property name="width">0.1in</property>
</column>
<column id="90">
<property
</column>
<row id="91">
<cell id="92">
<auto-text id="84">
<property
name="textUnderline">none</property>
<property
<property
name="pageVariable">GROUP_PAGE</property>
</auto-text>
</cell>
<cell id="94">
<label id="96">
<text-property name="text">
of</text-property>
</label>
</cell>
<cell id="93">
<auto-text id="87">
<method
name="onRender"><![CDATA[
var totalPage = reportContext.getPageVariable("GROUP_TOTAL_PAGE");
var groupName = reportContext.getPageVariable("GROUP_NAME");
if (totalPage != null)
this.text = java.lang.Integer.toString(totalPage.get(groupName));
]]></method>
<property
<property
name="pageVariable">GROUP_TOTAL_PAGE</property>
</auto-text>
</cell>
</row>
</grid>
</cell>
</row>
</grid>
</page-header>
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="10">
<property name="masterPage">Simple MasterPage</property>
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<text-property
<expression
name="expression">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<text-property
<expression
name="expression">dataSetRow["ORDERDATE"]</expression>
</structure>
<structure>
<text-property
<expression
name="expression">dataSetRow["REQUIREDDATE"]</expression >
</structure>
<structure>
<text-property
<expression
name="expression">dataSetRow["SHIPPEDDATE"]</expression >
</structure>
<structure>
<text-property
<expression
name="expression">dataSetRow["STATUS"]</expression>
</structure>
<structure>
<text-property
<expression
name="expression">dataSetRow["COMMENTS"]</expression>
</structure>
<structure>
<text-property
<expression
name="expression">dataSetRow["CUSTOMERNUMBER"]</expression >
</structure>
</list-property>
<property name="pageBreakInterval">0</property>
<column id="49"/>
<column id="50"/>
<column id="51"/>
<column id="52"/>
<column id="53"/>
<column id="54"/>
<column id="55"/>
<header>
<row id="11">
<cell id="12">
<label id="13">
<text-property
name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="14">
<label id="15">
<text-property
name="text">ORDERDATE</text-property>
</label>
</cell>
<cell id="16">
<label id="17">
<text-property
name="text">REQUIREDDATE</text-property>
</label>
</cell>
<cell id="18">
<label id="19">
<text-property
name="text">SHIPPEDDATE</text-property>
</label>
</cell>
<cell id="20">
<label id="21">
<text-property
name="text">STATUS</text-property>
</label>
</cell>
<cell id="22">
<label id="23">
<text-property
name="text">COMMENTS</text-property>
</label>
</cell>
<cell id="24">
<label id="25">
<text-property
name="text">CUSTOMERNUMBER</text-property>
</label>
</cell>
</row>
</header>
<group id="56">
<property name="groupName">STATUS</property>
<property name="interval">none</property>
<property name="sortDirection">asc</property>
<expression name="keyExpr"
type="javascript">row["STATUS"]</expression>
<structure name="toc">
<expression name="expressionValue"
</structure>
<property name="repeatHeader">true</property>
<property name="hideDetail">false</property>
<property name="pageBreakAfter">auto</property>
<property
name="pageBreakBefore">always-excluding-first</property>
<property name="pageBreakInside">auto</property>
<header>
<row id="57">
<cell id="58">
<data name="GROUP_STATUS" id="73">
<property
name="resultSetColumn">STATUS</property>
</data>
</cell>
<cell id="59">
<text id="106">
<property
<text-property
name="content"><![CDATA[<viewtime-value-of>
vars["GROUP_PAGE"]
</viewtime-value-of>
]]></text-property>
</text>
</cell>
<cell id="60"/>
<cell id="61"/>
<cell id="62"/>
<cell id="63"/>
<cell id="64"/>
</row>
</header>
<footer>
<row id="65">
<cell id="66"/>
<cell id="67"/>
<cell id="68"/>
<cell id="69"/>
<cell id="70"/>
<cell id="71"/>
<cell id="72"/>
</row>
</footer>
</group>
<detail>
<row id="26">
<cell id="27">
<data id="28">
<property
name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="29">
<data id="30">
<property
name="resultSetColumn">ORDERDATE</property>
</data>
</cell>
<cell id="31">
<data id="32">
<property
name="resultSetColumn">REQUIREDDATE</property>
</data>
</cell>
<cell id="33">
<data id="34">
<property
name="resultSetColumn">SHIPPEDDATE</property>
</data>
</cell>
<cell id="35">
<data id="36">
<property
</data>
</cell>
<cell id="37">
<data id="38">
<property
name="resultSetColumn">COMMENTS</property>
</data>
</cell>
<cell id="39">
<data id="40">
<property
name="resultSetColumn">CUSTOMERNUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="41">
<cell id="42"/>
<cell id="43"/>
<cell id="44"/>
<cell id="45"/>
<cell id="46"/>
<cell id="47"/>
<cell id="48"/>
</row>
</footer>
</table>
</body>
<property name="pageVariables">
<variable-element name="GROUP_NAME">
<property name="type">page</property>
</variable-element>
<variable-element name="GROUP_PAGE">
</variable-element>
<variable-element name="GROUP_TOTAL_PAGE">
<property name="type">report</property>
</variable-element>
</property>
</report>
On 9/3/2010 5:02 AM, pigargo wrote:
> Hello,
> seperated.
> pigargo
Re: reset pagenumber on group without interval [message #630080 is a reply to message #629956] |
Thu, 30 September 2010 11:16  |
Pigargo,
here is the bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=324860
Jason
On 9/30/2010 2:45 AM, pigargo wrote:
> Hello Jason,
> I have tried the report in the new version 2.6.1, but there is the same
> problem.
> Have you already written a bug? Can you tell me the bug number?
> Or should I write the bug?
> It was a big problem for me, that the pagenumber was not print in the
> right way and without bug I can not see when the problem will be solved.
> Thanks for your help.
> pigargo
FUDForum. Page generated in 0.04273 seconds
