Home » Archived » BIRT » attach sources to BIRT jars
attach sources to BIRT jars [message #556956] Fri, 03 September 2010 06:45 Go to next message
I would like to attach the sources to the jars inside the platform/plugin folder so I can debug through the code. What is the best way to do it in Eclipse?
Thanks.
Re: attach sources to BIRT jars [message #557039 is a reply to message #556956] Fri, 03 September 2010 13:01 Go to previous messageGo to next message
Are you debugging an API example or are you wanting to attach to
something like tomcat and debug it?
Jason
> Thanks.
Re: attach sources to BIRT jars [message #557054 is a reply to message #557039] Fri, 03 September 2010 15:26 Go to previous messageGo to next message
I have a web project and added the plugin folder (taken from the report engine download) under the WEB-INF folder. I would like to step through the code whose jars are in the plugin folder. I can do that for the jars in the lib folder (coreapi.jar, dteapi.jar, etc) since I added them in the classpath and attached the sources to them but I am not be able to do it for the jars in the plugin folder. I am using tomcat as web server. I was wondering if there any other options other than open all the BIRT projects in my workspace. Maybe using Eclipse User Libraries?
Re: attach sources to BIRT jars [message #557459 is a reply to message #557054] Tue, 07 September 2010 09:50 Go to previous message
The only way I have done this is to use the method described here:
http://confluence.sakaiproject.org/display/BOOT/Debugging+To mcat+Remotely+Using+Eclipse
I did open the source in the workspace (either check it out or download
the source from the download page). There may be a better way to do
this, but I have not done it.
Jason
Previous Topic:Column width Overflow
Next Topic: Connection profile store location
Current Time: Wed Jul 23 16:14:49 EDT 2025
Powered by FUDForum. Page generated in 0.25066 seconds
