Home » Eclipse Projects » Eclipse 4 » Workbench Save Restore
Workbench Save Restore [message #557430] Tue, 07 September 2010 07:56 Go to next message
Hello
Can you give me an equivalent of iworkbenchconfigurer.setsaveandrestore ().
Thank you,
Claude
Re: Workbench Save Restore [message #557666 is a reply to message #557430] Wed, 08 September 2010 08:26 Go to previous messageGo to next message
That's done by the save and restore of the deltas.xml file.
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Workbench Save Restore [message #557749 is a reply to message #557666] Wed, 08 September 2010 13:25 Go to previous messageGo to next message
Thank you for your reply.
For saveandrestore to false the only solution is a delete of deltas.xml?
If yes in the future improvement is expected?
Thank you
Claude
Re: Workbench Save Restore [message #557823 is a reply to message #557749] Thu, 09 September 2010 02:34 Go to previous messageGo to next message
a) In your product-extension point define an attribute like this:
-----8<------
<property
name="persistState"
value="false">
</property>
-----8<------
b) Launch with -persistState false
Tom
Am 08.09.10 19:25, schrieb FAATH:
> Thank you
> Claude
Re: Workbench Save Restore [message #557908 is a reply to message #557823] Thu, 09 September 2010 07:58 Go to previous messageGo to next message
Thank you for the info.
It's ok for the non persistence but with errors at startup [..... -consoleLog -persistState false java.lang.NullPointerException at org.eclipse.e4.ui.internal.workbench.ResourceHandler.loadMos tRecentModel(ResourceHandler.java:233) ...... ] and the application shutdown [ java.net.UnknownServiceException: protocol doesn't support output at java.net.URLConnection.getOutputStream(Unknown Source) at org.eclipse.emf.ecore.resource.impl.URIHandlerImpl.createOut putStream(URIHandlerImpl.java:137) .......] test with or without deltas.xml.
Claude.
Re: Workbench Save Restore [message #557913 is a reply to message #557908] Thu, 09 September 2010 08:00 Go to previous messageGo to next message
Hm. Then this looks like a bug. Can you file a bugzilla and attach me to it.
Tom
Am 09.09.10 13:58, schrieb FAATH:
> deltas.xml.
> Claude.
Re: Workbench Save Restore [message #557925 is a reply to message #557913] Thu, 09 September 2010 08:51 Go to previous messageGo to next message
I don 't know to file a bug.
I'll post my little application, if it can advance e4 (your email address tutorials.)
Thank you for your information and tutorials
Claude.
Re: Workbench Save Restore [message #557930 is a reply to message #557913] Thu, 09 September 2010 08:43 Go to previous messageGo to next message
Ok. You can also make the application clean up the delta.xml before
launching by using: -clearPersistedState
Tom
Am 09.09.10 14:00, schrieb Tom Schindl:
> Tom
>> Hi,
>> deltas.xml.
>> Claude.
Re: Workbench Save Restore [message #557931 is a reply to message #557925] Thu, 09 September 2010 08:55 Go to previous messageGo to next message
I've already found the problem in our code. It is quite obvious from the
exception line you gave me here.
I'll file a bug my own and fix the problem in the code. In the meanwhile
you can use the -clearPersistedState option to clear the restoring (it's
not 100% ideal though because we still collect the deltas for well
nothing but it makes you application behave like you want it to).
Tom
Am 09.09.10 14:51, schrieb FAATH:
> address tutorials.)
> Claude.
Re: Workbench Save Restore [message #557932 is a reply to message #557931] Thu, 09 September 2010 09:30 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=324841
Tom
Am 09.09.10 14:55, schrieb Tom Schindl:
> Tom
>> address tutorials.)
>> Claude.
Re: Workbench Save Restore [message #581491 is a reply to message #557666] Wed, 08 September 2010 13:25 Go to previous message
Thank you
Claude
Re: Workbench Save Restore [message #581500 is a reply to message #581491] Thu, 09 September 2010 02:34 Go to previous message
-----8<------
<property
name="persistState"
value="false">
</property>
-----8<------
Tom
> Thank you
> Claude
Re: Workbench Save Restore [message #581565 is a reply to message #557823] Thu, 09 September 2010 07:58 Go to previous message
Claude.
Re: Workbench Save Restore [message #581579 is a reply to message #581565] Thu, 09 September 2010 08:00 Go to previous message
Tom
> deltas.xml.
> Claude.
Re: Workbench Save Restore [message #581594 is a reply to message #557913] Thu, 09 September 2010 08:43 Go to previous message
Tom
> Tom
>> Hi,
>> deltas.xml.
>> Claude.
Re: Workbench Save Restore [message #581609 is a reply to message #557913] Thu, 09 September 2010 08:51 Go to previous message
Claude.
Re: Workbench Save Restore [message #581624 is a reply to message #557925] Thu, 09 September 2010 08:55 Go to previous message
Tom
> address tutorials.)
> Claude.
Re: Workbench Save Restore [message #581644 is a reply to message #557931] Thu, 09 September 2010 09:30 Go to previous message
Tom
> Tom
>> address tutorials.)
>> Claude.
Previous Topic:Reuse eclipse 3.x views
Next Topic:Confusion about Eclipse 4.0 Application Model
Current Time: Thu Jul 24 15:48:18 EDT 2025
Powered by FUDForum. Page generated in 0.06438 seconds
