Home » Eclipse Projects » Subversive » Always get tree conflict on merge
Always get tree conflict on merge [message #557320] Mon, 06 September 2010 12:34 Go to next message
Can anyone think why I would always get tree conflicts when merging a branch on to the trunk in a particular project ?
If I run 'svn diff' on the trunk and branch from the console (svn diff https://.../trunk https://.../branches/mybranch), it lists changes to files, but doesn't appear to explode the same way Subversive does. The changes it lists are all fairly minor.
The local copy of the trunk I'm trying to merge my branch to has no outstanding changes.
Eclipse 3.5 on Win32 with the latest Subversive for it.
Tried both the native Java and binary win32 connectors, to no noticeable difference, ditto using the reintergrate tab (or not).
[Updated on: Mon, 06 September 2010 12:40] by Moderator
icon4.gif  Re: Always get tree conflict on merge [message #557398 is a reply to message #557320] Tue, 07 September 2010 05:48 Go to previous message
ohhhhhhh !
http://durak.org/sean/pubs/software/version-control-with-sub version-1.6/svn.branchmerge.basicmerging.html :
"In Subversion 1.5 [or later], once a --reintegrate merge is done from branch to trunk, the branch is no longer usable for further work. It's not able to correctly absorb new trunk changes, nor can it be properly reintegrated to trunk again"
Previous Topic:Problem with Flex Builder 3.2
Next Topic:Confusing merge behavior
Current Time: Wed Jul 23 06:13:29 EDT 2025
Powered by FUDForum. Page generated in 0.05327 seconds
