Home » Archived » Buckminster » lastRevision NullPointerException on monitor?
lastRevision NullPointerException on monitor? [message #557294] Mon, 06 September 2010 10:05 Go to next message
Originally posted by: dhendriksREMOVE_THIS.tueREMOVE.THIS.nl
Hello all,
trying to do this (part of test.xml):
<buckminster.lastRevision property="lastRev"
                           readerType="svn"
repositoryLocation="http://svn-st.inf.tu-dresden.de/svn/reuseware/trunk/"/>
from an Ant actor using Headless Buckminster (latest Helios stable), I get:
ERROR: org.eclipse.core.runtime.CoreException: test.xml:7:
         at
org.eclipse.buckminster.ant.AntRunner.handleInvocationTargetException(AntRunner.java:167)
         at org.eclipse.buckminster.ant.AntRunner.run(AntRunner.java:322)
         at
         at
org.eclipse.buckminster.subversion.GenericSession.listFolder(GenericSession.java:558)
         at
org.eclipse.buckminster.subversive.internal.SubversiveSession.getDirEntry(SubversiveSession.java:279)
         at
org.eclipse.buckminster.subversive.internal.SubversiveSession.getLastChangeNumber(SubversiveSession.java:290)
         ... 48 more
I think it goes wrong at listFolder at line 558 (Class
org.eclipse.buckminster.subversion.GenericSession). Looking at the
source, it seems to do this:
			} finally {
				monitor.done();
So I guess 'monitor' is null here, hence the NullPointerException. Is
this a bug? Maybe headless calls don't have a monitor?
Note that if I instead use workingCopy (instead of repositoryLocation)
it does work...
Dennis
Re: lastRevision NullPointerException on monitor? [message #557296 is a reply to message #557294] Mon, 06 September 2010 10:17 Go to previous messageGo to next message
Please log an issue with the information you provided.
- henrik
On 9/6/10 4:05 PM, Dennis Hendriks wrote:
> Hello all,
> readerType="svn"
> at
> at
> at
> at
> at
> ... 48 more
> } finally {
> monitor.done();
> it does work...
> Dennis
Re: lastRevision NullPointerException on monitor? [message #557303 is a reply to message #557296] Mon, 06 September 2010 10:25 Go to previous messageGo to next message
OK, thanks.
See: https://bugs.eclipse.org/bugs/show_bug.cgi?id=324586
Dennis
> Regards
> - henrik
>> Hello all,
>> readerType="svn"
>> get:
>> at
>> at
>> at
>> at
>> at
>> ... 48 more
>> } finally {
>> monitor.done();
>> it does work...
>> Thanks,
>> Dennis
Re: lastRevision NullPointerException on monitor? [message #557304 is a reply to message #557296] Mon, 06 September 2010 10:27 Go to previous messageGo to next message
Dennis, could it be this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=317516
It's been fixed in the maintenance branch. If you're using the latest
maintenance build, it should work for you.
--Peter
Re: lastRevision NullPointerException on monitor? [message #557305 is a reply to message #557303] Mon, 06 September 2010 10:32 Go to previous message
Hello Henrik,
Yes, looks like it. I marked the bug as duplicate.
I'm using the Helios stable release, not the maintenance release... How
can I install Buckminster maintenance release using the headless
director? Or do I have to wait for Helios SR1?
Dennis
> OK, thanks.
> Regards,
> Dennis
>> Regards
>> - henrik
>>> Hello all,
>>> readerType="svn"
>>> I get:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 48 more
>>> } finally {
>>> monitor.done();
>>> it does work...
>>> Thanks,
>>> Dennis
Previous Topic:Changes in a Hudson job config don't show up in the build
Next Topic:product update does not work
Current Time: Thu Jul 24 21:46:53 EDT 2025
Powered by FUDForum. Page generated in 0.08785 seconds
