OCL check [message #557168] |
Sun, 05 September 2010 12:26  |
I am checking link / association between usecase and an actor.
I did not find a way to check this. Can any provide some hints, how can I proceed.
regards,
Akhtar
Re: OCL check [message #557353 is a reply to message #557338] |
Tue, 07 September 2010 01:27   |
Hi Ak
I really cannot understand what you are doing, since a variety of your
statements variously do not make sense or seem impossible.
- there is no usecase to be a context
- why are you using Complete OCL in the OCL Console
To see if there is any problem, I created a UML model comprising
Package p
Actor a
UseCase u
I then selected actor a, and evaluated
self.useCase->notEmpty()
in the OCL Console against the Ecore or UML M2 meta-model and got 'false'.
I then set a's useCase to be u and evaluated again and got 'true',
which is exactly what I would expect with the expression I suggested.
If you cannot make this work, you must describe what you are doing very
carefully and accurately so that whatever strange things yoiu are doing
can be identified.
Ed Willink
On 06/09/2010 22:39, Akhtar wrote:
> Hi Ed,
> I tried to explore your hint, with context usecase as well as with Actor.
> context uml::UseCase
> inv: self.useCase
> This only returns usecase name.
> I am executing queries on UML meta-model M2 layer in eclipse console. I
> have been just stucked with this simple query.
> Is there any other way in OCL to check link between usecase and actor
> exists or not.
> Best regards,
> Ak
Re: OCL check [message #557507 is a reply to message #557491] |
Tue, 07 September 2010 17:02  |
Thanks Ed,
I navigate the association and got the required result with following query.
context UseCase
inv: Association.allInstances().getEndTypes()->includes(self)
Akhtar
FUDForum. Page generated in 0.04721 seconds
