Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Problem with String replaceAll(Get null pointer exception when calling replaceAll)
[Acceleo] Problem with String replaceAll [message #557182] Sun, 05 September 2010 15:45 Go to next message
When calling the replaceAll service on a string I get the following error. I'm calling it like so:
getProperty('basePackage').replaceAll('.', '/')
I'm not sure if this has something with the getProperty method or what, but when I take out the replaceAll service the error doesn't happen. I'm setting the basePackage property string to "org.domain", so there should be a '.' to replace.
Thanks, here is the error:
at java.util.regex.Matcher.getTextLength(Matcher.java:1151)
at java.util.regex.Matcher.reset(Matcher.java:308)
at java.util.regex.Matcher.<init>(Matcher.java:228)
at java.util.regex.Pattern.matcher(Pattern.java:905)
at org.eclipse.acceleo.internal.traceability.engine.AcceleoTrac eabilityOperationVisitor.visitReplaceOperation(AcceleoTracea bilityOperationVisitor.java:226)
at org.eclipse.acceleo.internal.traceability.engine.AcceleoTrac eabilityVisitor.internalVisitOperationCallExp(AcceleoTraceab ilityVisitor.java:1218)
at org.eclipse.acceleo.internal.traceability.engine.AcceleoTrac eabilityVisitor.visitOperationCallExp(AcceleoTraceabilityVis itor.java:645)
at org.eclipse.ocl.ecore.impl.OperationCallExpImpl.accept(Opera tionCallExpImpl.java:390)
at org.eclipse.ocl.AbstractEvaluationVisitor.visitExpression(Ab stractEvaluationVisitor.java:247)
at org.eclipse.ocl.EvaluationVisitorDecorator.visitExpression(E valuationVisitorDecorator.java:156)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 517)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitExpression(AcceleoEvaluationVisitor.java:91 2)
at org.eclipse.acceleo.internal.traceability.engine.AcceleoTrac eabilityVisitor.visitExpression(AcceleoTraceabilityVisitor.j ava:524)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoBlock(AcceleoEvaluationVisitor.java: 250)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoIfBlock(AcceleoEvaluationVisitor.jav a:508)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitorDecorator.visitAcceleoIfBlock(AcceleoEvaluationVi sitorDecorator.java:163)
at org.eclipse.acceleo.internal.traceability.engine.AcceleoTrac eabilityVisitor.visitAcceleoIfBlock(AcceleoTraceabilityVisit or.java:374)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 471)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoTemplate(AcceleoEvaluationVisitor.ja va:781)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitorDecorator.visitAcceleoTemplate(AcceleoEvaluationV isitorDecorator.java:218)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 465)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoTemplateInvocation(AcceleoEvaluation Visitor.java:832)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitorDecorator.visitAcceleoTemplateInvocation(AcceleoE valuationVisitorDecorator.java:229)
at org.eclipse.acceleo.internal.traceability.engine.AcceleoTrac eabilityVisitor.visitAcceleoTemplateInvocation(AcceleoTracea bilityVisitor.java:432)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 492)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoIfBlock(AcceleoEvaluationVisitor.jav a:473)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoIfBlock(AcceleoEvaluationVisitor.jav a:505)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoForBlock(AcceleoEvaluationVisitor.ja va:423)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitorDecorator.visitAcceleoForBlock(AcceleoEvaluationV isitorDecorator.java:153)
at org.eclipse.acceleo.internal.traceability.engine.AcceleoTrac eabilityVisitor.visitAcceleoForBlock(AcceleoTraceabilityVisi tor.java:356)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 478)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoFileBlock(AcceleoEvaluationVisitor.j ava:316)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitorDecorator.visitAcceleoFileBlock(AcceleoEvaluation VisitorDecorator.java:143)
at org.eclipse.acceleo.internal.traceability.engine.AcceleoTrac eabilityVisitor.visitAcceleoFileBlock(AcceleoTraceabilityVis itor.java:335)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 485)
at org.eclipse.ocl.internal.evaluation.QueryImpl.evaluate(Query Impl.java:152)
at org.eclipse.ocl.ecore.QueryImpl.evaluate(QueryImpl.java:62)
at org.eclipse.acceleo.engine.generation.AcceleoEngine.doEvalua te(AcceleoEngine.java:265)
at org.eclipse.acceleo.engine.generation.AcceleoEngine.evaluate (AcceleoEngine.java:130)
at org.eclipse.acceleo.engine.service.AcceleoService.doGenerate Template(AcceleoService.java:544)
at org.eclipse.acceleo.engine.service.AcceleoService.doGenerate (AcceleoService.java:389)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator. generate(AbstractAcceleoGenerator.java:120)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator. doGenerate(AbstractAcceleoGenerator.java:99)
at org.openjaus.mercury.ecore.gen.cpp.Main.doGenerate(Main.java :148)
at org.openjaus.mercury.ecore.gen.cpp.Main.main(Main.java:126)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.acceleo.internal.ide.ui.launching.AcceleoLaunchO peration.run(AcceleoLaunchOperation.java:105)
at org.eclipse.acceleo.ide.ui.launching.strategy.AcceleoPluginL aunchingStrategy.launch(AcceleoPluginLaunchingStrategy.java: 220)
at org.eclipse.acceleo.ide.ui.launching.strategy.AcceleoPluginL aunchingStrategy.launch(AcceleoPluginLaunchingStrategy.java: 123)
at org.eclipse.acceleo.internal.ide.ui.launching.AcceleoLaunchD elegate.launch(AcceleoLaunchDelegate.java:53)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:853)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:702)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:923)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlu gin.java:1126)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Re: [Acceleo] Problem with String replaceAll [message #557183 is a reply to message #557182] Sun, 05 September 2010 15:59 Go to previous messageGo to next message
I figured out that I had the properties set up wrong. All fixed now...
Re: [Acceleo] Problem with String replaceAll [message #557219 is a reply to message #557183] Mon, 06 September 2010 03:31 Go to previous messageGo to next message
--------------080000050504040208080105
Happy to see you fixed it, though your first post does point to an error
we need to fix in the core.
Could you raise a bug about the "replaceAll(..)" operation throwing an
exception when called on an undefined String?
Laurent Goubet
Obeo
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------080000050504040208080105--
Re: [Acceleo] Problem with String replaceAll [message #557345 is a reply to message #557219] Mon, 06 September 2010 22:36 Go to previous messageGo to next message
I posted the bug. Thanks.
Re: [Acceleo] Problem with String replaceAll [message #557391 is a reply to message #557182] Tue, 07 September 2010 05:24 Go to previous messageGo to next message
Hi Tom,
What version of Acceleo are you using ? 3.0 or 3.1M1 ? You can see it in "Help -> About Eclipse -> Installation Details -> Plugins"
And for your bug, well I think I solved it with another bug few days ago that was similar, because I can't reproduce it in my developement version so the fix should be available in Acceleo 3.1 and Acceleo 3.0 SR1 or SR2.
Stephane Begaudeau, Obeo
Re: [Acceleo] Problem with String replaceAll [message #557446 is a reply to message #557391] Tue, 07 September 2010 09:15 Go to previous message
Thanks, that's great to hear. This is the version I'm using: 3.0.0.v201006150906
Tom
Previous Topic:Execute MWE Workflow programmatically
Next Topic:[Acceleo 3] Calling service on list
Current Time: Fri Jul 25 09:08:53 EDT 2025
Powered by FUDForum. Page generated in 0.05492 seconds
