Re: global variable can access by all Views and Editors [message #557254 is a reply to message #557061] |
Mon, 06 September 2010 05:11  |
On 03.09.2010 23:07, Cosmas wrote:
> Do someone knows how to create a global variable which
> all views and editors can access to. Thank You!!
I cannot answer to this question without any further
explanation. Assume such a global variable would be
provided (and there are several means to realize that),
how would you ensure that *all* views and editors
use it?? You won't change the fundamental Eclipse source
code of views and editors, will you?
In other words: This question cannot reasonably be answered
without understanding your intended use-case.
HTH & Greetings from Bremen,
Daniel Krügler
FUDForum. Page generated in 0.03840 seconds
