Home » Archived » BIRT » bubble charts(setting the size of the bubbles)
icon5.gif  bubble charts [message #556916] Fri, 03 September 2010 03:58 Go to next message
The sizes of the bubbles are calculated and set automatically by birt
In many cases the sizes of all bubbles are too big, i want to have for example:
- a maximum size for all bubbles
- or multiply all bubble sizes with a factor for example with 0.3
- any other way that avoids extremely big bubbles overlapping many other bubbles.
I tried this script without success:
function beforeDrawDataPoint( dph, fill, icsc )
mybubbleval = dph.getOrthogonalValue();
if( mybubbleval.getClass().toString() == "class org.eclipse.birt.chart.datafeed.BubbleEntry") {
mybubbleval.setSize(1);
Many thank's for helping.
Re: bubble charts [message #557020 is a reply to message #556916] Fri, 03 September 2010 12:14 Go to previous message
I believe the problem is that the size is already used before the
beforeDrawDataPoint event occurs. You may want to log a bug for this.
As a work around change it in a prior script. For example in the
afterComputations like:
function afterComputations( chart, plotComputation )
importPackage(Packages.java.lang);
var xAxis = chart.getAxes().get(0);
var yAxis = xAxis.getAssociatedAxes().get(0);
var xSerieDef = xAxis.getSeriesDefinitions().get(0);
var ySerieDef = yAxis.getSeriesDefinitions().get(0);
var ySerie = ySerieDef.getRunTimeSeries().get(0);
var dpa =
plotComputation.getSeriesRenderingHints(ySerieDef,ySerie).ge tDataPoints();
for( ii =0; ii<dpa.length; ii++ ){
var csize = dpa[ii].getOrthogonalValue().getSize();
dpa[ii].getOrthogonalValue().setSize( Double.parseDouble( csize)*.3);
Jason
> example:
> bubbles.
> mybubbleval = dph.getOrthogonalValue(); if(
Previous Topic:open "Report design" perspective when open a ".rptDesign" file
Next Topic:Binding parameters in dataset
Current Time: Wed Jul 23 04:45:16 EDT 2025
Powered by FUDForum. Page generated in 1.08447 seconds
