[EWL] Use data from different models/files [message #555696] |
Fri, 27 August 2010 13:07  |
I'm using EWL to implement some transformations.
However, to perform a transformation, I need to have access to data that is on a different model/file.
Is this possible? If so, how can I do this?
Thanks.
[Updated on: Fri, 03 September 2010 06:25] by Moderator
Re: [EWL] Use data from different [message #593438 is a reply to message #556957] |
Fri, 03 September 2010 07:09  |
That's good news :)
Thanks again.
Dimitrios Kolovos wrote on Fri, 03 September 2010 05:55
> Actually, all languages in Epsilon (including EWL) support access to an
> arbitrary number of models. However, for EWL there's no out-of-the-box
> UI to allow you to load additional models. In ETL you can do this using
> the launch configuration dialog ("Models" tab).
> Cheers,
> Dimitris
http://cs.utexas.edu/~rcg
FUDForum. Page generated in 0.07293 seconds
