Home » Archived » BIRT » reset pagenumber on group without interval
reset pagenumber on group without interval [message #556936] Fri, 03 September 2010 05:02 Go to next message
I have a report with a group and many detailrows with different hights, so I can not define an interval for the pagebreak. The bug 233755 https://bugs.eclipse.org/bugs/show_bug.cgi?id=233755 describes my problem. It is fixed, but in comment 3 was written, that in version 2.5.1 the same problem is still there.
I am using birt 2.5.2 and tested the report also in 2.6.0 with the same result. The pagebreak event was not called for dynamic pagebreaks in the render methode. The print methode is pdf. The run and render task is seperated.
Why the bug 233755 is not reopened? Or is there an other solution for this problem in a newer version?
pigargo
Re: reset pagenumber on group without interval [message #557038 is a reply to message #556936] Fri, 03 September 2010 13:00 Go to previous messageGo to next message
Have you tried using page scripts?
Take a look at the following example in BIRT 2.6.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.6.0.v20100531 Build &lt;2.6.0.v20100609-1613></property>
<property name="units">in</property>
<method name="beforeFactory"><![CDATA[prevGroupKey = "";
groupPageNumber = 1;
reportContext.setGlobalVariable("gGROUP_NAME", "");
reportContext.setGlobalVariable("gGROUP_PAGE", 1);
]]></method>
<method name="onPageEnd"><![CDATA[ //var groups =
this.getInstancesByElementName("GROUP_STATUS");
var groups = this.getInstancesByElementId(73);
var group;
if( groups != null ){
group = groups[0];
var groupKey = group.value;
//var prevGroupKey = reportContext.getPageVariable("GROUP_NAME");
//var groupPageNumber = reportContext.getPageVariable("GROUP_PAGE");
var prevGroupKey = reportContext.getGlobalVariable("gGROUP_NAME");
var groupPageNumber = reportContext.getGlobalVariable("gGROUP_PAGE");
if( prevGroupKey == null ){
prevGroupKey = "";
//prevGroupKey = reportContext.getPageVariable("GROUP_NAME");
//groupPageNumber = reportContext.getPageVariable("GROUP_PAGE");
if (prevGroupKey == groupKey)
if (groupPageNumber != null)
groupPageNumber = parseInt(groupPageNumber) + 1;
else {
else {
prevGroupKey = groupKey;
reportContext.setPageVariable("GROUP_NAME", groupKey);
reportContext.setPageVariable("GROUP_PAGE", groupPageNumber);
reportContext.setGlobalVariable("gGROUP_NAME", groupKey);
reportContext.setGlobalVariable("gGROUP_PAGE", groupPageNumber);
var groupTotalPage = reportContext.getPageVariable("GROUP_TOTAL_PAGE");
if (groupTotalPage == null)
groupTotalPage = new java.util.HashMap();
reportContext.setPageVariable("GROUP_TOTAL_PAGE", groupTotalPage);
groupTotalPage.put(groupKey, groupPageNumber);
} ]]></method>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="layoutPreference">fixed layout</property>
<property name="bidiLayoutOrientation">ltr</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="7">
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="9">
<list-property name="columnHints">
<structure>
<property name="columnName">ORDERNUMBER</property>
<text-property
name="displayName">ORDERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">ORDERDATE</property>
<text-property
name="displayName">ORDERDATE</text-property>
</structure>
<structure>
<property name="columnName">REQUIREDDATE</property>
<text-property
name="displayName">REQUIREDDATE</text-property>
</structure>
<structure>
<property name="columnName">SHIPPEDDATE</property>
<text-property
name="displayName">SHIPPEDDATE</text-property>
</structure>
<structure>
<property name="columnName">STATUS</property>
<text-property
name="displayName">STATUS</text-property>
</structure>
<structure>
<property name="columnName">COMMENTS</property>
<text-property
name="displayName">COMMENTS</text-property>
</structure>
<structure>
<property name="columnName">CUSTOMERNUMBER</property>
<text-property
name="displayName">CUSTOMERNUMBER</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">ORDERDATE</property>
<property name="dataType">date</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">REQUIREDDATE</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">SHIPPEDDATE</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">STATUS</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">COMMENTS</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">CUSTOMERNUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">ORDERDATE</property>
<property name="nativeDataType">91</property>
</structure>
<structure>
<property name="nativeName">REQUIREDDATE</property>
</structure>
<structure>
<property name="nativeName">SHIPPEDDATE</property>
</structure>
<structure>
<property name="nativeName">STATUS</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">COMMENTS</property>
</structure>
<structure>
<property name="nativeName">CUSTOMERNUMBER</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from CLASSICMODELS.ORDERS]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERDATE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>91</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>ORDERDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERDATE</design:label>
<design:displaySize>10</design:displaySize>
<design:attributes>
<design:name>REQUIREDDATE</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>REQUIREDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>REQUIREDDATE</design:label>
<design:attributes>
<design:name>SHIPPEDDATE</design:name>
<design:position>4</design:position>
<design:uiHints>
<design:displayName>SHIPPEDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>SHIPPEDDATE</design:label>
<design:attributes>
<design:name>STATUS</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>STATUS</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>STATUS</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>COMMENTS</design:name>
<design:position>6</design:position>
<design:precision>32700</design:precision>
<design:uiHints>
<design:displayName>COMMENTS</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>COMMENTS</design:label>
<design:displaySize>32700</design:displaySize>
<design:attributes>
<design:name>CUSTOMERNUMBER</design:name>
<design:position>7</design:position>
<design:uiHints>
<design:displayName>CUSTOMERNUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CUSTOMERNUMBER</design:label>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">"Verdana"</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
<style name="table-header" id="97">
<property name="backgroundColor">#6078BF</property>
<property name="fontFamily">"Arial"</property>
<property name="fontSize">small</property>
<property name="fontWeight">bold</property>
<property name="color">#FFFFFF</property>
<property name="paddingTop">0px</property>
<property name="paddingLeft">0px</property>
<property name="paddingBottom">0px</property>
<property name="paddingRight">0px</property>
</style>
<style name="table-footer" id="98">
</style>
<style name="table-detail" id="99">
<property name="backgroundColor">#E6ECFF</property>
<property name="fontSize">x-small</property>
<property name="color">#000080</property>
</style>
<style name="table-group-header-1" id="100">
<property name="backgroundColor">#809FFF</property>
</style>
<style name="table-group-footer-1" id="101">
</style>
<style name="special-header" id="102">
<property name="fontSize">medium</property>
</style>
<style name="crosstab-detail" id="103">
</style>
<style name="crosstab-header" id="104">
</style>
<style name="mydata" id="105">
<property name="color">orange</property>
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-header>
<grid id="74">
<column id="75"/>
<column id="76"/>
<row id="78">
<property name="style">special-header</property>
<cell id="79">
<auto-text id="83">
<property
name="textUnderline">underline</property>
<property
name="type">page-variable</property>
<property
name="pageVariable">GROUP_NAME</property>
</auto-text>
</cell>
<cell id="80">
<grid id="88">
<property name="width">2.125in</property>
<column id="89">
<property
name="width">0.25in</property>
</column>
<column id="95">
<property name="width">0.1in</property>
</column>
<column id="90">
<property
</column>
<row id="91">
<cell id="92">
<auto-text id="84">
<property
name="textUnderline">none</property>
<property
<property
name="pageVariable">GROUP_PAGE</property>
</auto-text>
</cell>
<cell id="94">
<label id="96">
<text-property name="text">
of</text-property>
</label>
</cell>
<cell id="93">
<auto-text id="87">
<method
name="onRender"><![CDATA[
var totalPage = reportContext.getPageVariable("GROUP_TOTAL_PAGE");
var groupName = reportContext.getPageVariable("GROUP_NAME");
if (totalPage != null)
this.text = java.lang.Integer.toString(totalPage.get(groupName));
]]></method>
<property
<property
name="pageVariable">GROUP_TOTAL_PAGE</property>
</auto-text>
</cell>
</row>
</grid>
</cell>
</row>
</grid>
</page-header>
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="10">
<property name="masterPage">Simple MasterPage</property>
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<text-property
<expression
name="expression">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<text-property
<expression
name="expression">dataSetRow["ORDERDATE"]</expression>
</structure>
<structure>
<text-property
<expression
name="expression">dataSetRow["REQUIREDDATE"]</expression >
</structure>
<structure>
<text-property
<expression
name="expression">dataSetRow["SHIPPEDDATE"]</expression >
</structure>
<structure>
<text-property
<expression
name="expression">dataSetRow["STATUS"]</expression>
</structure>
<structure>
<text-property
<expression
name="expression">dataSetRow["COMMENTS"]</expression>
</structure>
<structure>
<text-property
<expression
name="expression">dataSetRow["CUSTOMERNUMBER"]</expression >
</structure>
</list-property>
<property name="pageBreakInterval">0</property>
<column id="49"/>
<column id="50"/>
<column id="51"/>
<column id="52"/>
<column id="53"/>
<column id="54"/>
<column id="55"/>
<header>
<row id="11">
<cell id="12">
<label id="13">
<text-property
name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="14">
<label id="15">
<text-property
name="text">ORDERDATE</text-property>
</label>
</cell>
<cell id="16">
<label id="17">
<text-property
name="text">REQUIREDDATE</text-property>
</label>
</cell>
<cell id="18">
<label id="19">
<text-property
name="text">SHIPPEDDATE</text-property>
</label>
</cell>
<cell id="20">
<label id="21">
<text-property
name="text">STATUS</text-property>
</label>
</cell>
<cell id="22">
<label id="23">
<text-property
name="text">COMMENTS</text-property>
</label>
</cell>
<cell id="24">
<label id="25">
<text-property
name="text">CUSTOMERNUMBER</text-property>
</label>
</cell>
</row>
</header>
<group id="56">
<property name="groupName">STATUS</property>
<property name="interval">none</property>
<property name="sortDirection">asc</property>
<expression name="keyExpr"
type="javascript">row["STATUS"]</expression>
<structure name="toc">
<expression name="expressionValue"
</structure>
<property name="repeatHeader">true</property>
<property name="hideDetail">false</property>
<property name="pageBreakAfter">auto</property>
<property
name="pageBreakBefore">always-excluding-first</property>
<property name="pageBreakInside">auto</property>
<header>
<row id="57">
<cell id="58">
<data name="GROUP_STATUS" id="73">
<property
name="resultSetColumn">STATUS</property>
</data>
</cell>
<cell id="59">
<text id="106">
<property
<text-property
name="content"><![CDATA[<viewtime-value-of>
vars["GROUP_PAGE"]
</viewtime-value-of>
]]></text-property>
</text>
</cell>
<cell id="60"/>
<cell id="61"/>
<cell id="62"/>
<cell id="63"/>
<cell id="64"/>
</row>
</header>
<footer>
<row id="65">
<cell id="66"/>
<cell id="67"/>
<cell id="68"/>
<cell id="69"/>
<cell id="70"/>
<cell id="71"/>
<cell id="72"/>
</row>
</footer>
</group>
<detail>
<row id="26">
<cell id="27">
<data id="28">
<property
name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="29">
<data id="30">
<property
name="resultSetColumn">ORDERDATE</property>
</data>
</cell>
<cell id="31">
<data id="32">
<property
name="resultSetColumn">REQUIREDDATE</property>
</data>
</cell>
<cell id="33">
<data id="34">
<property
name="resultSetColumn">SHIPPEDDATE</property>
</data>
</cell>
<cell id="35">
<data id="36">
<property
</data>
</cell>
<cell id="37">
<data id="38">
<property
name="resultSetColumn">COMMENTS</property>
</data>
</cell>
<cell id="39">
<data id="40">
<property
name="resultSetColumn">CUSTOMERNUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="41">
<cell id="42"/>
<cell id="43"/>
<cell id="44"/>
<cell id="45"/>
<cell id="46"/>
<cell id="47"/>
<cell id="48"/>
</row>
</footer>
</table>
</body>
<property name="pageVariables">
<variable-element name="GROUP_NAME">
<property name="type">page</property>
</variable-element>
<variable-element name="GROUP_PAGE">
</variable-element>
<variable-element name="GROUP_TOTAL_PAGE">
<property name="type">report</property>
</variable-element>
</property>
</report>
On 9/3/2010 5:02 AM, pigargo wrote:
> Hello,
> seperated.
> pigargo
Re: reset pagenumber on group without interval [message #557223 is a reply to message #556936] Mon, 06 September 2010 03:54 Go to previous messageGo to next message
Hello Jason,
I have used the onPageBreak Event of the table.
Now I have tried your example and I got the same problem. The total page is correct but the page number is always set to 1. I think it is a problem of the pdf-output. With html it seems to work.
pigargo
Re: reset pagenumber on group without interval [message #557461 is a reply to message #557223] Tue, 07 September 2010 09:55 Go to previous messageGo to next message
How are you running the report? Have you tried with the viewer?
Jason
On 9/6/2010 3:54 AM, pigargo wrote:
> Hello Jason,
> pigargo
Re: reset pagenumber on group without interval [message #558739 is a reply to message #557461] Tue, 14 September 2010 05:14 Go to previous messageGo to next message
Hello Jason,
I tried it with the viewer (View Report -> In Web Viewer) and in the Web Viewer the pagenumber was correct.
But if I try "export to pdf" in the Web Viewer the pagenumber always will be 1 of 12, for all 12 pages.
I also have tried it with a small java application which a seperat run and render task and pdf-output. In the output file will be printed the pagenumber 1 of 12 for all 12 pages.
This was the java application for testing.
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.IPDFRenderOption;
import org.eclipse.birt.report.engine.api.IRenderOption;
import org.eclipse.birt.report.engine.api.IRenderTask;
import org.eclipse.birt.report.engine.api.IReportDocument;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunTask;
import org.eclipse.birt.report.engine.api.PDFRenderOption;
import org.eclipse.birt.report.engine.api.RenderOption;
public class MainClass {
* @param args
IReportEngine engine = null;
try{
final EngineConfig config = new EngineConfig( );
config.setEngineHome("C:\\Birt_2_6_0\\runtime\\ReportEngine ");
Platform.startup( config ); //If using RE API in Eclipse/RCP application this is not needed.
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject( IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
engine = factory.createReportEngine( config );
}catch( Exception ex){
ex.printStackTrace();
// Run reports, etc.
try {
run(engine);
render(engine);
} catch (EngineException e) {
e.printStackTrace();
// destroy the engine.
engine.destroy();
Platform.shutdown();
public static void run(IReportEngine engine) throws EngineException{
//Open a report design
IReportRunnable design = engine.openReportDesign("H:\\birt_report\\version260proj\\pagenumber in 2_6.rptdesign");
//Create task to run the report - use the task to execute the report and save to disk.
IRunTask task = engine.createRunTask(design);
//run the report and destroy the engine
task.run("H:\\birt_report\\version260proj\\pagenumber in 2_6.rptdocument");
task.close();
public static void render(IReportEngine engine) throws EngineException{
//Open a report document
IReportDocument document = engine.openReportDocument("H:\\birt_report\\version260proj\\pagenumber in 2_6.rptdocument");
IRenderOption options = new RenderOption();
options.setOutputFormat("pdf");
options.setOutputFileName("H:\\birt_report\\version260proj\\pagenumber in 2_6.pdf");
PDFRenderOption pdfOptions = new PDFRenderOption( options );
pdfOptions.setOption( IPDFRenderOption.PAGE_OVERFLOW, IPDFRenderOption.OUTPUT_TO_MULTIPLE_PAGES);
//pdfOptions.setOption(IPDFRenderOption.PAGEBREAK_PAGINATION _ONLY, new Boolean(false));
//Create Render Task
IRenderTask task = engine.createRenderTask(document);
task.setRenderOption(pdfOptions);
task.render();
document.close();
pigargo
Re: reset pagenumber on group without interval [message #558865 is a reply to message #558739] Tue, 14 September 2010 11:53 Go to previous messageGo to next message
Do you have a page break interval set on the table? Can you put one on
to test it? I think this is a bug. I experienced the same issue when
using tables with no pagebreak interval. I have already logged the issue.
Jason
On 9/14/2010 5:15 AM, pigargo wrote:
> Hello Jason,
> * @param args
> public static void main(String[] args) {
> try{
> this is not needed.
> try {
> run(engine);
> render(engine);
> engine.destroy();
> //Open a report design IReportRunnable design =
> 2_6.rptdesign");
> save to disk.
> IRunTask task = engine.createRunTask(design); //run the report and
> destroy the engine
> task.close();
> //Open a report document IReportDocument document =
> in 2_6.pdf");
> Boolean(false));
> task.render();
> document.close();
> pigargo
Re: reset pagenumber on group without interval [message #559559 is a reply to message #558865] Fri, 17 September 2010 04:02 Go to previous messageGo to next message
I don't have a page break interval on the table, because the hight of the rows can be different.
If I set a page break interval the page nubmer will be right.
Will you create a bug?
Where can I see when an new Release is planned and if my bug is contained there?
Thanks for your great help.
pigargo
Re: reset pagenumber on group without interval [message #629956 is a reply to message #559559] Thu, 30 September 2010 02:45 Go to previous messageGo to next message
Hello Jason,
I have tried the report in the new version 2.6.1, but there is the same problem.
Have you already written a bug? Can you tell me the bug number?
Or should I write the bug?
It was a big problem for me, that the pagenumber was not print in the right way and without bug I can not see when the problem will be solved.
Thanks for your help.
pigargo
Re: reset pagenumber on group without interval [message #630080 is a reply to message #629956] Thu, 30 September 2010 11:16 Go to previous message
Pigargo,
here is the bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=324860
Jason
On 9/30/2010 2:45 AM, pigargo wrote:
> Hello Jason,
> problem.
> pigargo
Previous Topic:encoding problem
Next Topic:birt HSQL
Current Time: Wed Jul 23 18:55:28 EDT 2025
Powered by FUDForum. Page generated in 0.15839 seconds
