Home » Archived » M2M (model-to-model transformation) » [QVTo] Truncate output file / do not append results
[QVTo] Truncate output file / do not append results [message #556692] Thu, 02 September 2010 07:01 Go to next message
Hi @all,
well, I already performed some more or less complex experiments with QVTo. I read many tutorials, but the exact semantics of some things are still unclear to me. Hopefully, I get enlighted sometime.
My question refers to the (output) result of a transformation. My use case: I have an input model (file), perform an transformation, and I wanna get an output model (file). My problem: the result of my transormation is appended/embedded into the output file. That means, if I execute the transformation twice, my model is inside the output file two times. The workaround: delete the result file before each transformation. However, this approach is inconvenient and sounds unfamilar to me. Even if there are many scenarios in which such a behavior might be meaningful, I expect a completely new model/file, if I have a simple output (no inout, whatever).
Is this the normal behavior?
Am I doing something wrong?
I found the option "Clear contents" in the run configurations for the output model. However, the checkbox is disabled.
BTW: This behavior can simply be reproduced by creating and running the example shipped with QVTo "SimpleUML to RDB".
I am using Topcased 4.0.0 with QVTo 20100606
[Updated on: Thu, 02 September 2010 07:02] by Moderator
Re: [QVTo] Truncate output file / do not append results [message #556805 is a reply to message #556692] Thu, 02 September 2010 12:19 Go to previous message
Hi Vultur
This is https://bugs.eclipse.org/bugs/show_bug.cgi?id=320010
Ed Willink
On 02/09/2010 12:01, vultur wrote:
> Hi @all,
> QVT. I read many tutorials, but the exact semantics of some things are
> I execute the transformation twice, I my model is inside the output file
Previous Topic:Refactoring UML!Property
Next Topic:[ATL] Ant task problem
Current Time: Sat Jul 26 10:58:02 EDT 2025
Powered by FUDForum. Page generated in 0.36066 seconds
