Home » Archived » Buckminster » Multiphase creation of update site?
Multiphase creation of update site? [message #547369] |
Fri, 16 July 2010 09:18  |
Originally posted by: dhendriksREMOVE_THIS.tueREMOVE.THIS.nl
For my QVTo project, I would like to create a p2 update site. The QVTo
file cannot be parsed if I don't have the metamodel it depends on
installed. Also, it requires a blackbox library, provided by an other
Java plug-in. Note that it is not enough to have the projects in the
workspace, I actually need the distributed jars installed into headless
Buckminster.
What I do now, is create an update site for the metamodel/EMF project,
and the blackbox library Java plug-in project. Then install those
plug-ins into headless Buckminster. Then I create an update site for the
QVTo project, together with the other two projects.
This requires multiple phases, and multiple intermediate/temporary
update sites. I needed to create a shell script and invoke Buckminster
with various commands, and different rmaps/cqueries for the multiple
phases. Is there any way to avoid this, that is, to automatically have
this resolved etc? I think it would be within the goal of Buckminster to
automatically do this for me, right?
Dennis
Re: Multiphase creation of update site? [message #547408 is a reply to message #547369] |
Fri, 16 July 2010 12:27   |
this is one of the goals of Eclipse b3 as it has a lot more
compositional flexibility, and has unified all of the artifacts used by
Buckminster into one.
Don't think this will be supported directly in Buckminster even when
used as an engine behind the scenes.
- henrik
On 7/16/10 3:18 PM, Dennis Hendriks wrote:
> Hello,
> Buckminster.
> Dennis
Re: Multiphase creation of update site? [message #556383 is a reply to message #547408] |
Wed, 01 September 2010 02:23   |
Hello all,
After being redirected to b3 from Buckminster, my question is whether
the scenario I presented (see below) is supported by b3. That is, does
(or will) b3 support automation of multi-phase build processes?
If so, what is the status of the implementation; is it ready for use in
real-life projects (as I read that b3 is still in the proposal phase:
http://wiki.eclipse.org/PDE/Incubator/b3/Proposal)
Dennis
Henrik Lindberg wrote:
> Regards
> - henrik
>> Hello,
>> Buckminster.
>> Dennis
Re: Multiphase creation of update site? [message #556511 is a reply to message #556383] |
Wed, 01 September 2010 11:33   |
The b3 project is found here: http://www.eclipse.org/modeling/emft/b3/
The original proposal was that b3 was to be a sub-project to PDE, but
since the ambitions goes beyond PDE, it was decided that modeling was a
better home. The PDE incubation part is still valid to contain
changes/support for b3 from a PDE perspective.
The part of b3 that is ready for use is the b3 aggregator - which helps
with part of the problem - that of performing operations on p2
repositories (aggregating, filtering, re-authoring, etc).
Don't know if the aggregator will help you all that much, as in your
problem there are building steps inbetween where the buckminster queries
and commands etc. are now executed.
What you want to achieve is not directly supported (as you found out)
and is typically performed with several phases orchestrated by a script
or using Hudson. I agree that it would be really nice to be able to do
all of the required steps "at once", and support declarative
specification of such a flow directly in b3 - i.e. the result of one
build operation is a "processor/compiler" in subsequent operations. Will
log an enhancement request for that for b3.
- henrik
>>> Buckminster.
>>> Dennis
Re: Multiphase creation of update site? [message #556637 is a reply to message #556511] |
Thu, 02 September 2010 03:38  |
Hello Henrik,
I guess I'll stick to Buckminster for now and do a manual two phase
build from a Linux shell script.
Thanks for the detailed explanation!
Dennis
> Regards
> - henrik
>>>> Buckminster.
>>>> the
>>>> Buckminster to
>>>> Dennis
Current Time: Sat Jul 26 11:06:55 EDT 2025
Powered by FUDForum. Page generated in 0.26495 seconds
