Home » Eclipse Projects » Subversive » Display indicator in code editor when source has changed?
Display indicator in code editor when source has changed? [message #556488] Wed, 01 September 2010 10:45 Go to next message
Hi all.
Is it possible to configure Subversive to display an indicator in the code editor when you have made a change compared to the last (base/local) svn revision of the file?`
Intellij does this elegantly by putting a small icon in the right or left bare in the code editor. This makes it very easy to see what changes you are committing (instead of using the "compare to" feature every time..).
Re: Display indicator in code editor when source has changed? [message #556523 is a reply to message #556488] Wed, 01 September 2010 12:08 Go to previous messageGo to next message
On 09/01/2010 04:45 PM, johnrlaugh@gmail.com wrote:
> Hi all.
> every time..).
You could use Team -> Show annotations as a workaround. Of course, this will display a lot of other
changes. But you could manually set the revision to start from.
New lines are marked as having no revision.
Possibly, this could be a base for an implementation in Subversive.
Please file a feature request.
Cheers, Jörg
Re: Display indicator in code editor when source has changed? [message #556633 is a reply to message #556488] Thu, 02 September 2010 03:39 Go to previous messageGo to next message
Hi!
It seems the "Quick Diff" option is just what you need. In order to enable it please follow those steps:
1) right click on the left field of the source editor
2) choose "Show Quick Diff" menu item
Re: Display indicator in code editor when source has changed? [message #556649 is a reply to message #556633] Thu, 02 September 2010 04:30 Go to previous messageGo to next message
Ah, thanks Alexander. I know "Quick Diff" because this also displays annotations, but was not aware
of this.
The colours are quite light and not easily visible. Maybe they should be configured.
In addition, I found the "Preferences" entry for "Quick Diff" (which can easily accessed using the
same right-click and selecting "Preferences..." below):
General->Editors->Text Editors->Quick Diff
Here John can configure all its needs:
[x] Show in overview ruler (i.e scroll bar on the right side)
colors for add, delete, change (could be more intensive for me)
And most notably: Reference source:
Default is "Version on Disk", but Johns wants "SVN Working Copy Base".
For "Version on Disk" every Save clears the indicators, while "SVN Working Copy Base" gets cleared
only on commit/revert.
Anyway, thanks for your hint, which let me learn something new :-)
Cheers, Jörg
Re: Display indicator in code editor when source has changed? [message #556650 is a reply to message #556649] Thu, 02 September 2010 04:40 Go to previous message
Subversive provides support for the "Quick Diff" which means that the "SVN Working Copy Base" version should be used instead of the "Version on Disk" one.
Previous Topic:Overwrite and update doesn't replace local copy with repository copy
Next Topic:problem with SVNKit 1.3.2?
Current Time: Fri Jul 25 19:11:23 EDT 2025
Powered by FUDForum. Page generated in 0.25153 seconds
