| Re: Mylar and team support (Subversion?) [message #5560] |
Sun, 10 September 2006 23:35  |
Ok, it seems to work better with Subclipse :)
Thanks again Eike.
For Mylar team (or maybe more for Subversive team) I red somewhere that the
problem was related to changeset not properly implemented in Subversive, is
it true ? Do you have any idea as to when Mylar will work with Subversive ?
Thanks a lot.
Joel.
"Joel Cheuoua" <jcheuoua@gmail.com> wrote in message
news:edts8c$40v$1@utils.eclipse.org...
> Hi Eike,
> Thanks for the tip, I will give it a try.
> Always a pleasure to hear from you :)
> Cheers.
> Joel.
> "Eike Stepper" <stepper@sympedia.de> wrote in message
> news:edtnai$v1t$1@utils.eclipse.org...
>> Hi Joel,
>> While adding configurable commit comment templates to Mylar I've seen
>> that there is a class
>> org.eclipse.mylar.internal.team.subclipse.SubclipseTeamRepos itoryProvider
>> as well. Since I don't like the Subclipse frontend very much, I did not
>> test the Mylar integration. But maybe you can simply try it?!
>> Cheers
>> /Eike
>> Joel Cheuoua schrieb:
>>> Hello folks,
>>> Great work with Mylar !
>>> I'm new to this very exciting plugin, hence I'am sorry if the question
>>> has already been mentioned here (a quick search wasn't successful)
>>> How is Mylar linked to the Eclipse Team Support framework ? Is it linked
>>> only to CVS ? is it possible/planned to extend it to other SCC like
>>> Subversion (using either subclipse or subversive) ?
>>> Thanks.
>>> Joel.
| Re: Mylar and team support (Subversion?) [message #5586 is a reply to message #5579] |
Fri, 15 September 2006 04:31   |
Hello Mik,
Thank you for these references - it's exact information, which we need. Now
we have a set of urgent tasks related with the Subversive functionality and
as soon as they will be finished, we will spend efforts to make the
integration with Mylar. We will keep community informed about the progress.
Igor Vinnykov
Subversive Team
"Mik Kersten" <mik.kersten@eclipse.org> ???????/???????? ? ????????
?????????: news:4508A1AA.2040207@eclipse.org...
> Hi Igor,
> Given that you now have change sets, it should be very straightforward to
> integrate with Mylar's automatic change set management and commit
> messages. All that's required is to make your change set implementation
> accessible to Mylar via the org.eclipse.mylar.team.providers extension
> point. I've summarized the steps and requirements here:
> http://wiki.eclipse.org/index.php/Mylar_Integrator_Reference #Integrating_Team_Providers
> If you have any questions or requests when implementing this please either
> create a new Bugzilla report and reply with the link in case others are
> interested in the discussion.
> http://www.eclipse.org/mylar/bugs.php
> Cheers,
> Mik
> Igor Vinnykov wrote:
>> Hello Joel,
>> Thank you for nice questions. Unfortunately we have no information about
>> problems with change sets implementation. Could you please let us know
>> details (or source of this information)?
>> Regarding the time when you can see Subversive integration with Mylar -
>> our team does the best in order to make it as soon as possible. First of
>> all we included change sets support into the Subversive 1.1.x stream.
>> Also we created Architecture Overview document
>> http://www.polarion.org/projects/subversive/docs/Subversive_ Architecture_Overview.pdf,
>> which describes Subversive integration features. From our point of view
>> it's enough to start discussion with Mylar about integration.
>> We asked Mik Kersten to review the Subversive infrastructure from the
>> Mylar integration point of view. I suppose to get feedback soon. In this
>> post I want to summarize points about integration and want ask someone
>> from Mylar team to address them.
>> 1. It will be great to have Subversive integrated with Mylar. Could you
>> please help us with this? What is required from our side?
>> 2. Could you please review Subversive change sets support and integration
>> features? Are they full sufficient for integration with Mylar?
>> We are looking forward to get integration with Mylar soon. Thank you.
FUDForum. Page generated in 0.04107 seconds
