Home » Archived » BIRT » open "Report design" perspective when open a ".rptDesign" file(open "Report design" perspective when open a ".rptDesign" file)
open "Report design" perspective when open a ".rptDesign" file [message #556425] Wed, 01 September 2010 05:48 Go to next message
I am wondering if it is possible to open "Report design" perspective when I double click on a "rptdesign" file!
I would like the same behavoiur that does for example when creating a "new Report" with thre creation wizard!
Thanks in advance!!
Re: open "Report design" perspective when open a ".rptDesign" file [message #556463 is a reply to message #556425] Wed, 01 September 2010 08:54 Go to previous messageGo to next message
You can click on window->open perspective->Report Design.
If you have already opened it once you should be able to switch back to
it using the report perspective icon in the right corner as well.
Jason
On 9/1/2010 5:48 AM, disamistade wrote:
> Thanks in advance!!
Re: open "Report design" perspective when open a ".rptDesign" file [message #556939 is a reply to message #556463] Fri, 03 September 2010 05:10 Go to previous messageGo to next message
Thank you,
but that's not exacly what I meant,
I would like the platform to automatically switch to the perspective when I open a particular extension file, somehow the same that happens with wizard..
Greetings
Re: open "Report design" perspective when open a ".rptDesign" file [message #557014 is a reply to message #556939] Fri, 03 September 2010 11:24 Go to previous message
Understood. Right now I do not think any of the file types do this in
Eclipse. There is a Perspectives preference page under the general
properties, but switching is only available for new projects. Can you
log a bug against Eclipse, to add this option?
Jason
On 9/3/2010 5:10 AM, disamistade wrote:
> Thank you,
> with wizard..
> Greetings
Previous Topic:Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine
Next Topic:bubble charts
Current Time: Sat Jul 26 18:50:47 EDT 2025
Powered by FUDForum. Page generated in 0.18677 seconds
