Home » Modeling » Graphiti » Undo/Redo support for non EMF based domain objects
Undo/Redo support for non EMF based domain objects [message #556346] Tue, 31 August 2010 17:41 Go to next message
It seems that if my domain objects are not EMF based, then we don't get the undo/redo support (whether it's a move feature or add feature). After some digging, I noticed that Graphiti uses GFCommandStack class which seems to replace GEF's command stack with emf's command stack.
How do I get undo/redo support if my domain objects are not EMF based? Thank you for your suggestions!
Shenxue
Re: Undo/Redo support for non EMF based domain objects [message #557283 is a reply to message #556346] Mon, 06 September 2010 08:32 Go to previous messageGo to next message
Yes, you are right. The advantage of doing it that way is that we can
completely handle undo/redo on EMF level by simply using the
RecordingCommand of EMF.
Also in a scenario with non-EMF domain objects, the part concerning the
graphical objects are handled automatically by Graphiti. Only the undo/redo
of the non-EMF domain object changes need to be implemented by you. In order
to do that you can use a GEF CommandStackEventListener that you register at
the CommandStack by
getEditDomain().getCommandStack().addCommandStackEventListen er(listener)
after the initiallization (e.g. by overriding setInput in DiagramEditor and
after calling super.setInput). There you can react to events POST_REDO and
POST_UNDO.
Hope that helps.
-Michael
"Shenxue Zhou" <shenxue.zhou@oracle.com> wrote in message
news:i5jsv9$74t$1@build.eclipse.org...
> Shenxue
Re: Undo/Redo support for non EMF based domain objects [message #557499 is a reply to message #557283] Tue, 07 September 2010 15:47 Go to previous messageGo to next message
Michael,
Thanks for your reply. I did some experiment based on your suggestion. In my editor, I overrode the setInput() method. My setInput() method looks like this:
protected void setInput(IEditorInput input)
super.setInput(input);
getEditDomain().getCommandStack().addCommandStackEventListen er(this);
But I'm registering a command stack event listener to GFCommandStack() since the default domain's GEF command stack has been replaced by GFCommandStack after super.setInput() is called. GFCommandStack doesn't seem to notify listeners about POST_REDO/POST_UNDO events.
Thoughts?
Shenxue
Re: Undo/Redo support for non EMF based domain objects [message #557655 is a reply to message #557499] Wed, 08 September 2010 08:35 Go to previous message
Shenxue,
I just had a closer look and saw that you are right. This is a gap in our
command stack implementation. After a short team discussion we also saw that
there is currently no other hook to actually undo/redo non-EMF changes.
Could you please open an enhancement request Bugzilla (Under modeling,
product GMP, component Graphiti) for this? We have a rough idea how to
implement the feature, but this needs to be detailed out.
Michael
news:i664t9$44g$1@build.eclipse.org...
> Michael,
> like this:
> @Override
> protected void setInput(IEditorInput input) {
> getEditDomain().getCommandStack().addCommandStackEventListen er(this); }
> Thoughts?
> Shenxue
Re: Undo/Redo support for non EMF based domain objects [message #567972 is a reply to message #557283] Tue, 07 September 2010 15:47 Go to previous message
Michael,
Thoughts?
Shenxue
Re: Undo/Redo support for non EMF based domain objects [message #568043 is a reply to message #567972] Wed, 08 September 2010 08:35 Go to previous message
Shenxue,
Michael
> Michael,
> like this:
> @Override
> Thoughts?
> Shenxue
Previous Topic:Hierarchical Layout and Active Status
Next Topic:Graphiti 0.7.0 RC1 available
Current Time: Thu Jul 24 21:48:01 EDT 2025
Powered by FUDForum. Page generated in 0.05113 seconds
