Lazy is not lazy [message #555579] |
Fri, 27 August 2010 05:07  |
I am using static weaving and testing with the following code.
However, I'm not able getting the lazy fetching really lazy although I'm detaching the object after retrieving it.
What am I doing wrong?
Thanks a lot. I'm stuck...
edit: EclipseLink version is 2.1.0.
edit2: persistence.xml attached, too. Weaving is triggered through Ant and seems to work (Jar grows ~ 2 KB).
package de.ormtest;
import java.util.List;
import javax.persistence.Basic;
import javax.persistence.CascadeType;
import javax.persistence.DiscriminatorColumn;
import javax.persistence.DiscriminatorType;
import javax.persistence.DiscriminatorValue;
import javax.persistence.Entity;
import javax.persistence.FetchType;
import javax.persistence.GeneratedValue;
import javax.persistence.GenerationType;
import javax.persistence.Id;
import javax.persistence.Inheritance;
import javax.persistence.InheritanceType;
import javax.persistence.OneToMany;
import javax.persistence.OrderColumn;
@Entity
@Inheritance(strategy = InheritanceType.TABLE_PER_CLASS)
public class Foo {
private long id;
private String name;
private String descr;
private List<Bar> list;
@Id
@GeneratedValue(strategy = GenerationType.IDENTITY)
public long getId() {
return id;
public void setId(long id) {
this.id = id;
@Basic
public String getName() {
return name;
public void setName(String name) {
this.name = name;
@Basic
public String getDescr() {
return descr;
public void setDescr(String descr) {
this.descr = descr;
@OneToMany(fetch = FetchType.LAZY, cascade = CascadeType.ALL)
@OrderColumn(name = "JPA_ORDERING")
public List<Bar> getList() {
return list;
public void setList(List<Bar> list) {
this.list = list;
package de.ormtest;
@Entity
public class Bar {
private long id;
private String descr = "hallo";
@Id
return id;
this.id = id;
@Basic
return name;
this.name = name;
@Basic
return descr;
this.descr = descr;
package de.ormtest;
import java.util.LinkedList;
import javax.persistence.EntityManager;
import javax.persistence.EntityManagerFactory;
import javax.persistence.EntityTransaction;
import javax.persistence.Persistence;
import javax.persistence.PersistenceContext;
import javax.persistence.PersistenceUnit;
public class Main {
@PersistenceUnit(unitName = "ormtest")
private static EntityManagerFactory emf = Persistence
.createEntityManagerFactory("ormtest");
@PersistenceContext(unitName = "ormtest")
private static EntityManager em = emf.createEntityManager();
Foo foo = new Foo();
foo.setName("fooName");
List<Bar> bars = new LinkedList<Bar>();
for (int j = 0; j < 300; j++) {
Bar bar = new Bar();
bar.setName("barName" + j);
bars.add(bar);
foo.setList(bars);
EntityTransaction et = em.getTransaction();
et.begin();
em.persist(foo);
et.commit();
Foo result = em.find(Foo.class, 1L);
em.detach(result);
em.close();
System.out.println(result);
// Here I'm getting the wohle list, although the object is detached
System.out.println(result.getList());
System.out.println(result.getList().size());
<persistence version="1.0"
xmlns="http://java.sun.com/xml/ns/persistence" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://java.sun.com/xml/ns/persistence http://java.sun.com/xml/ns/persistence/persistence_1_0.xsd">
<persistence-unit name="ormtest">
<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
<class>de.ormtest.Foo</class>
<class>de.ormtest.Bar</class>
<properties>
<property name="javax.persistence.jdbc.driver" value="com.mysql.jdbc.Driver" />
<!-- ;create=true -->
<property name="javax.persistence.jdbc.url" value="jdbc:mysql://localhost:3306/ormtest" />
<property name="javax.persistence.jdbc.user" value="root" />
<property name="javax.persistence.jdbc.password" value="root" />
<property name="eclipselink.ddl-generation" value="drop-and-create-tables" />
<property name="eclipselink.ddl-generation.output-mode"
value="database" />
<property name="eclipselink.weaving" value="static" />
</properties>
</persistence-unit>
</persistence>
[Updated on: Fri, 27 August 2010 08:14] by Moderator
Re: Lazy is not lazy [message #556077 is a reply to message #555579] |
Mon, 30 August 2010 13:46  |
First of all, weaving is only required for LAZY OneToOne and ManyToOne. A LAZY OneToMany will work even without weaving.
Second LAZY avoids the database access. You are not seeing any database access?
You are using the same EntityManager so will get the same object that you inserted, which has its list already instantiated.
If you created a new EntityManager then you would get a non instantiated list back, but if you accessed it, then it would instantiate, so you will always get the same result. The only way you would get a different result is if you serialized the object, then you would get an exception that you were accessing a dead relation.
Also it will not access the database even in a new EntityManger as the object is still in the cache.
Not sure on what you goal is? What do you want to occur? What are you trying to do?
FUDForum. Page generated in 0.03415 seconds
