Home » Eclipse Projects » EclipseLink » Calculated Primary Key
Calculated Primary Key [message #555800] Sat, 28 August 2010 18:03 Go to next message
Hi all,
I want to integrate pseudonymization / depseudonymization using JPA. Imagine a one to many relationship between a customer and many orders. The order entity should contain a foreign key of type string. This foreign key is calculated from a Java implementation using fields from the customer entity. This implementation creates the foreign key value from the three fields and extracts the three fields from a given foreign key value.
The customer entity will have a compound primary key class(firstname, lastname, birthdate). The problem is that the key in customer are in this example 3 fields and the reference in the order is one calculated value of this fields. Is there a hook which I could use in EclipseLink? Or do I have to extend EclipseLink? Is this barely possible?
I don't know how to solve this problem unless I want to use the convenient @OneToMany in the customer entity.
Any ideas?
Mark
Re: Calculated Primary Key [message #556075 is a reply to message #555800] Mon, 30 August 2010 13:40 Go to previous message
EclipseLink allows you to define complex relationships based on an Expression.
See,
http://wiki.eclipse.org/EclipseLink/Examples/JPA/MappingSele ctionCriteria
You can use the fields in the expression to compute a foreign key value.
Previous Topic:Problem with DB2
Next Topic:Lazy is not lazy
Current Time: Fri Jul 25 22:09:30 EDT 2025
Powered by FUDForum. Page generated in 0.66850 seconds
