Home » Archived » M2M (model-to-model transformation) » [QVTo] Dictionary Configuration Properties
[QVTo] Dictionary Configuration Properties [message #555632] Fri, 27 August 2010 09:06 Go to next message
I need a Dict as a global variable. I read that I have to use config properties as global variables, but they don't seem to accept Dict as their type. What should I do instead?
Re: [QVTo] Dictionary Configuration Properties [message #555637 is a reply to message #555632] Fri, 27 August 2010 09:13 Go to previous messageGo to next message
Originally posted by: dhendriksREMOVE_THIS.tueREMOVE.THIS.nl
Hello Al,
Configuration properties are for transformation options, that are
configurable by the user of the transformation. I would not use them for
internal, global variables.
there are some bugs in the Helios release of Eclipse related to
dictionaries (also in combination with properties). I reported them and
they were recently fixed. See:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=322756
and
https://bugs.eclipse.org/bugs/show_bug.cgi?id=322758
Maybe these fixes also solve your problems?
Dennis
Re: [QVTo] Dictionary Configuration Properties [message #555698 is a reply to message #555637] Fri, 27 August 2010 13:12 Go to previous messageGo to next message
Thanks Dennis,
I agree that configuration properties are not meant to be used as global vars, however I am not aware if any other Qvto feature that is.
On a related note, is the call semantics of Qvt call-by-value? Is it possible to have call by reference instead?
Al
Re: [QVTo] Dictionary Configuration Properties [message #555706 is a reply to message #555698] Fri, 27 August 2010 13:25 Go to previous messageGo to next message
Hi Al
I have successfully passed a Dictionary by reference to gather results
during one transformation pass.
Ed Willink
On 27/08/2010 18:12, Al wrote:
> Thanks Dennis,
> Thanks
> Al
Re: [QVTo] Dictionary Configuration Properties [message #555893 is a reply to message #555698] Mon, 30 August 2010 02:16 Go to previous messageGo to next message
Hello Al,
> global
QVTo has both configuration and non-configuration properties. Instead of
"configuration property <name> : <type> = <value>" just use "property
<name> : <type> = <value>"...
Dennis
Al wrote:
> Thanks Dennis,
> Thanks
> Al
Re: [QVTo] Dictionary Configuration Properties [message #555894 is a reply to message #555698] Mon, 30 August 2010 02:18 Go to previous messageGo to next message
Hello Al,
Are you asking about mappings, or helpers, or both? For mappings, you
can control this by using in/out/inout, I think.
Dennis
Al wrote:
> Thanks Dennis,
> Thanks
> Al
Re: [QVTo] Dictionary Configuration Properties [message #555900 is a reply to message #555893] Mon, 30 August 2010 03:05 Go to previous message
Hello Al,
oh wait, configuration properties don't have values... But
non-configuration ones do! Anyway, just omit the "configuration" keyword
and you have 'normal' properties.
Dennis
Dennis Hendriks wrote:
> Hello Al,
> > global
> Best regards,
> Dennis
> Al wrote:
>> Thanks Dennis,
>> Thanks
>> Al
Previous Topic:Batch transformation
Next Topic:[QVTo] Executing transformation on dynamic input model
Current Time: Wed Jul 23 20:34:43 EDT 2025
Powered by FUDForum. Page generated in 0.03975 seconds
