AdapterException: The data source of this data set can not be null. [message #555465] |
Thu, 26 August 2010 12:56  |
hi there,
hope you can help me with a problem that is bugging me...
I just created a report that uses scripted datasources fetching data from some pojos. no big deal, works fine in eclipse report designer!
now I want to have it all in a servlet. Basically I followed the instructions in the wiki ( http://wiki.eclipse.org/Servlet_Example_%28BIRT%29_2.1 ) and try to make it run in tomcat using wtp. after some minor adaptations the platform and engine started and the report was found.
But: during task.run() I got lots of exceptions, all of them like
An exception occurred during processing. Please see the following message for details:
org.eclipse.birt.report.data.adapter.api.AdapterException: An exception occurred during processing. Please see the following message for details:
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.prepare(DataRequestSessionImpl.java:526)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.doPrepareQuery(AbstractDataEngine.java:208)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.prepare(AbstractDataEngine.java:172)
at org.eclipse.birt.report.engine.executor.ReportExecutor.execute(ReportExecutor.java:118)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportExecutor.execute(WrappedReportExecutor.java:59)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplciateReportExecutor.execute(SuppressDuplciateReportExecutor.java:51)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:149)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:72)
Obviously the engine cannot find the datasources? do I have to configure the engine to use scripts embedded in the report?
I'm using an IRunAndRenderTask.
this is the birtengine's properties as displayed by the debugger:
[org.eclipse.birt.report.engine.api.EngineConfig.scriptObjects={PARENT_CLASSLOADER=WebappClassLoader
delegate: false
repositories:
/WEB-INF/classes/
----------> Parent Classloader:
org.apache.catalina.loader.StandardClassLoader@e1899b
}, BIRT_HOME=C:\seu2\tomcat\6.x\wtpwebapps\EWO-Druck\WEB-INF\platform, logLevel=FINEST, PLATFORM_CONTEXT=org.eclipse.birt.core.framework.PlatformServletContext@12a642, org.eclipse.birt.report.engine.api.EngineConfig.emitterConfigs={html=org.eclipse.birt.report.engine.api.HTMLEmitterConfig@615f19}, org.eclipse.birt.report.engine.api.EngineConfig.statusHandler=org.eclipse.birt.report.engine.api.DefaultStatusHandler@1a8e0bd, logDest=c:/temp]
I also had BIRT_HOME=C:\seu2\tomcat\6.x\wtpwebapps\EWO-Druck without any changes...
the pojos for the datasources are within the classpath...
At the moment I'm too blind to see the problem
any help is highly welcome
thanx in advance!
nils
[Updated on: Thu, 26 August 2010 13:01] by Moderator
Re: AdapterException: The data source of this data set can not be null. [message #555471 is a reply to message #555465] |
Thu, 26 August 2010 13:05   |
You need to set the scriptlib directory that the engine is searching for
the pojos. It also searches this directory if you implemented your
event handlers in java.
config.getAppContext().put("webapplication.projectclasspath ",
"c:/test/myclasspathentry1.jar;c:/tmp/myjar2.jar" );
Jason
On 8/26/2010 12:56 PM, nils.buntenbeck@bluecarat.de wrote:
> hi there,
> at
> org.eclipse.birt.report.data.adapter.impl.DataRequestSession Impl.prepare(DataRequestSessionImpl.java:526)
> at
> org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.d oPrepareQuery(AbstractDataEngine.java:208)
> at
> org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.p repare(AbstractDataEngine.java:172)
> at
> org.eclipse.birt.report.engine.executor.ReportExecutor.execu te(ReportExecutor.java:118)
> at
> org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportExecutor.execute(WrappedReportExecutor.java:59)
> at
> org.eclipse.birt.report.engine.internal.executor.dup.Suppres sDuplciateReportExecutor.execute(SuppressDuplciateReportExec utor.java:51)
> at
> at
> org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:149)
> at
> org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:72)
> [org.eclipse.birt.report.engine.api.EngineConfig.scriptObjec ts={PARENT_CLASSLOADER=WebappClassLoader
> delegate: false
> repositories:
> /WEB-INF/classes/
> }, BIRT_HOME=C:\seu2\tomcat\6.x\wtpwebapps\EWO-Druck\WEB-INF\pl atform,
> logLevel=FINEST,
> org.eclipse.birt.report.engine.api.EngineConfig.emitterConfi gs={html=org.eclipse.birt.report.engine.api.HTMLEmitterConfig@615f19},
> org.eclipse.birt.report.engine.api.EngineConfig.statusHandle r=org.eclipse.birt.report.engine.api.DefaultStatusHandler@1a8e0bd,
> logDest=c:/temp]
> changes...
> At the moment I'm too blind to see the problem :(
> any help is highly welcome :)
> thanx in advance!
> nils
Re: AdapterException: The data source of this data set can not be null. [message #556067 is a reply to message #556058] |
Mon, 30 August 2010 13:18   |
Can you try creating this class:
package my.event.handlers;
import org.eclipse.birt.report.engine.api.script.IUpdatableDataSetR ow;
import
org.eclipse.birt.report.engine.api.script.eventadapter.Scrip tedDataSetEventAdapter;
import org.eclipse.birt.report.engine.api.script.instance.IDataSetI nstance;
public class MyScriptedDataSet extends ScriptedDataSetEventAdapter {
private Integer cnt=0;
private Integer cntT=3;
public boolean fetch(IDataSetInstance dataSet, IUpdatableDataSetRow row) {
//dataSet.getInputParameterValue(arg0);
if( cnt < cntT){
try{
row.setColumnValue("col1", new Integer(cnt));
row.setColumnValue("col2", "hello");
cnt++;
return true;
}catch (Exception e){
return false;
Jar it and create a scriptlib directory under your app context and put
the jar in there. then add the webapp setting back specifying the full
path to the jar you created and then run the attached report?
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21"
id="1">
<property name="comments">Copyright (c) 2007 <<Your Company
Name here>></property>
<property name="createdBy">Eclipse BIRT Designer Version
2.5.2.v20100208 Build <2.5.2.v20100210-0630></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<property name="units">in</property>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="layoutPreference">auto layout</property>
<data-sources>
<script-data-source name="Data Source" id="6">
<property name="newHandlerOnEachEvent">true</property>
</script-data-source>
</data-sources>
<data-sets>
<script-data-set name="Data Set" id="7">
<property
name="eventHandlerClass">my.event.handlers.MyScriptedDataSet </property>
<list-property name="resultSetHints">
<structure>
<property name="position">1</property>
<property name="name">col1</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">col2</property>
<property name="dataType">string</property>
</structure>
</list-property>
<list-property name="columnHints">
<structure>
<property name="columnName">col1</property>
</structure>
<structure>
<property name="columnName">col2</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
</script-data-set>
</data-sets>
<styles>
<style name="crosstab" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="5">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="topMargin">1in</property>
<property name="leftMargin">1.25in</property>
<property name="bottomMargin">1in</property>
<property name="rightMargin">1.25in</property>
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="33">
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<text-property name="displayName">col1</text-property>
<expression name="expression"
type="javascript">dataSetRow["col1"]</expression>
</structure>
<structure>
<text-property name="displayName">col2</text-property>
type="javascript">dataSetRow["col2"]</expression>
</structure>
</list-property>
<column id="47"/>
<column id="48"/>
<header>
<row id="34">
<cell id="35">
<label id="36">
<text-property name="text">col1</text-property>
</label>
</cell>
<cell id="37">
<label id="38">
<text-property name="text">col2</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="39">
<cell id="40">
<data id="41">
<property
name="resultSetColumn">col1</property>
</data>
</cell>
<cell id="42">
<data id="43">
<property
name="resultSetColumn">col2</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="44">
<cell id="45"/>
<cell id="46"/>
</row>
</footer>
</table>
</body>
</report>
On 8/30/2010 1:11 PM, Nils wrote:
> hi jason,
> thanks for your help. I'm sorry to say that I still did not get it
> running...
> I tried to make it run in the example birt-viewer, which finally worked
> :) I tried to make it run as a servlet and failed again...
> all jars containing datasource-classes are in the right place, that is
> web-inf/classes and web-inf/lib.
> the classloader knows all relevant classes.
> I removed the setting of webapplication.classpath and set the
> engine-home to the web-inf/platform directory
> platform starts, loads the report, creates a task and... fails!
> again complaining that the datasource can not be null!
> what am I doing wrong?
> thank you for your help!
> nils
> Jason Weathersby wrote on Fri, 27 August 2010 09:44
>> Are all the jars needed by the pojo in the classpath?
>> Also when setting the classloader key can you use
>> NameOfYourClass.class.getClassLoader( ) ?
>> If the pojos are are in the web-inf/lib or web-inf/classes you should
>> not need to set the webapplication.projectclasspath to that directory.
>> This may cause an issue. Try moving the classes into a jar and put
>> them in another directory.
>> Jason
Re: AdapterException: The data source of this data set can not be null. [message #556293 is a reply to message #556292] |
Tue, 31 August 2010 11:34  |
One other thing to check. Can you try setting the locale in the RE API?
task.setLocale(new Locale("en", "US"));
before the report is executed?
Jason
On 8/31/2010 11:32 AM, Jason Weathersby wrote:
> Can you email me the report? jasonweathersby at windstream dot net
> On 8/31/2010 11:18 AM, Nils wrote:
>> I just meant, that I have my handlers written in javascript, the code is
>> in the rptdesign-file, that's all.
>> it still gives me the same error :(
FUDForum. Page generated in 0.06965 seconds
