| RAServer failed to start [message #54965] |
Sun, 26 February 2006 07:44  |
Hi Group,
I've problems to get the Agent Controller to start. I'm using linux and
followed the instructions. I set the LD_LIBRARY_PATH variable and set the
bin folder to PATH. Then I run the configuration.
The next would be to start the controller with RAStart.sh but it always
tells me: "RAServer failed to start".
Without any other information.
As I looked into the servicelog I found the following error log:
"Cannot create master named pipe: ramaster. Make sure the named pipe is free
and no other Agent Controller is using the same named pipe."
So I tried to delete the /tmp/IBMRAC/ramaster and start the RAStart.sh
again, but with the same result.
Whats going wrong?
Please help me, I ran out of ideas.
Andreas
| Re: RAServer failed to start [message #55349 is a reply to message #55019] |
Tue, 28 February 2006 03:47   |
thanks for your answer.
You asked for the following:
> 1. If "/tmp/IBMRAC" writable by all user (mode 777)
Yes, it is.
> 2. If "/tmp/IBMRAC/ramaster" is recreated after you run "RAStart.sh" the
> second time
Yes, ramaster is recreated after I run RAStart.sh the second time.
> 3. You Linux distribution and kernel version
I use an Fedora Core 4 with a self compiled kernel 2.6.12.1.
The log tells:
"Cannot resolve the host name of the local machine. Ensure the fully
qualified host name of the local machine is registered with the Domain Name
Server (DNS)."
and
The other log entries are no error messages, as far as I can see.
Andreas
Samson Wai wrote:
> Can you check the following?
> second time
> You can generate a detailed log by editing the Agent Controller's
> "config/serviceconfig.xml" file and change the "loggingLevel" attribute
> to "DEBUG". Rerun "RAStart.sh" and you can check the log for more
> detailed information.
> Regards,
> Samson
> Andreas Heinecke wrote:
>> Hi Group,
>> free and no other Agent Controller is using the same named pipe."
>> Whats going wrong?
>> Andreas
| Re: RAServer failed to start [message #55454 is a reply to message #55349] |
Tue, 28 February 2006 07:47   |
This still doesn't work. Why is it so complicated to get this thing running?
I recently read about IAC. How can I use this? Am I right, that using IAC
will keep me from using RAC, if profiling on the same machine?
The problem is now that I dont know how to configure TPTP to use the IAC
instead of the RAC.
Andreas
> Yes, it is.
>> second time
> The log tells:
> Name Server (DNS)."
> and
> Andreas
> Samson Wai wrote:
>> Hi,
>> second time
>> Regards,
>> Samson
>>> Hi Group,
>>> the bin folder to PATH. Then I run the configuration.
>>> Whats going wrong?
>>> Andreas
| Re: RAServer failed to start [message #55780 is a reply to message #55537] |
Wed, 01 March 2006 02:55  |
thank you very much for your help. Finally I solved the problem.
@Samson: The problem was a misconfiguration of my hostname. My hostname
couldn't be resolved by /etc/hosts, because it wasn't listed there. After
fixing this the Agent started.
@Thay: Thank you for your help in getting the IAC to run. This works, too.
Andreas
Thay Shanmugaratnam wrote:
> The IAC itself does not require any configuration at all. Unlike the Agent
> Controller, which requires the user to enter information such as the path
> for the Java executable, the IAC will determine the required information
> from Eclipse workbench during startup.
> To use the IAC:
> 1) Run --> Profile --> External Java Application
> 2) In the host tab select: Local Direct Connection rather than localhost
> 3) Specify the Class name, Class path under the Main tab
> 4) Profile
> Regards
> Thay
FUDForum. Page generated in 0.05534 seconds
