Re: line break in button text and image under button text [message #555343 is a reply to message #555340] |
Thu, 26 August 2010 07:49  |
Yes... this is true. Another solution will be to create a custom
widget (Button) with all the functionalities that you need.
See
http://help.eclipse.org/helios/topic/org.eclipse.rap.help/he lp/html/advanced/custom-widget.html
Best,
Ivan
On 08/26/2010 2:40 PM, Steffen wrote:
> Ivan Furnadjiev wrote on Thu, 26 August 2010 06:22
>> Hi Steffen,
>> I'm sorry to say, but this is not possible in both SWT. As RAP (RWT)
>> is trying to be as close as possible to SWT, this is not possible in
>> RAP too. One possible workaround is to create a button with image
>> only (without text) and put the text in the image itself.
>> Best,
>> Ivan
> Thank you for your reply. Putting the text in the image itself
> produces the sideffect that you are no longer able to manage
> multi-language moreover every text change has to be made in the image.
FUDForum. Page generated in 0.08432 seconds
