Home » Archived » BIRT » Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine
Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #554957] Tue, 24 August 2010 17:44 Go to next message
I'm using birt 2.3.1 engine api in a web service deployed to weblogic 10.x. The birt engine is instantiated properly on the first call. i keep getting 'Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine' error on subsequent calls.
I kind of following implementation example on http://wiki.eclipse.org/Servlet_Example_%28BIRT%29_2.1 because i can't find an birt 2.3 Servlet implementation example.
I appreciate any help in advance.
dash.
// code snippets
private IReportEngine getBirtEngine(ServletContext sc) {
IReportEngine re = null;
if (sc != null) {
EngineConfig ec = new EngineConfig();
ec.setLogConfig(BIRT_LOGS_PATH, Level.FINE);
ec.getAppContext().put(EngineConstants.APPCONTEXT_CLASSLOADE R_KEY, Thread.currentThread().getContextClassLoader());
ec.setEngineHome("");
IPlatformContext pc = new PlatformServletContext(sc);
ec.setPlatformContext(pc);
try {
Platform.startup(ec);
catch (BirtException be) {
e.printStackTrace();
IReportEngineFactory ref = (IReportEngineFactory) Platform.createFactoryObject(IReportEngineFactory.EXTENSION_ REPORT_ENGINE_FACTORY);
// offending line. remote debugger hangs here.
re = ref.createReportEngine(ec);
return re;
@WebMethod
public RetrieveReportResponse getReport(RetrieveReportRequest request)
throws OperationTimeoutException, OperationValidationException, OperationException
ServletContext sc = wsctx.getHttpSession().getServletContext();
IReportEngine re = getBirtEngine(sc);
if (re != null) {
// debugging code
String [] formats = re.getSupportedFormats();
if (formats != null){
for (String format: formats){
System.out.println("*****supported format:" + format);
else {
System.out.println("***** Unable to obtain birt engine");
try {
if (re != null) {
re.destroy();
re = null;
Platform.shutdown();
catch (Exception e){
// handle exception
return response;
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #554960 is a reply to message #554957] Tue, 24 August 2010 18:10 Go to previous messageGo to next message
It looks like you are trying to start-up the engine each time. Look at
the BirtEngine class in the wiki page that you referenced:
public static synchronized IReportEngine getBirtEngine
It only starts up the platform once.
Also look further down the wiki page for later version examples.
Jason
On 8/24/2010 5:44 PM, dash wrote:
> subsequent calls.
> dash.
> // code snippets
> if (sc != null) {
> try {
> return re;
> @WebMethod
> OperationException
> if (re != null) {
> // debugging code
> else {
> try {
> if (re != null) {
> re.destroy();
> re = null;
> // handle exception
> return response;
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #555204 is a reply to message #554960] Wed, 25 August 2010 15:35 Go to previous messageGo to next message
Jason,
Thanks for your prompt response. I've the birt engine issue resolved. However, I run into another issue with the birt designer when I try to preview my report. The designer keeps crashing and hanging. The datasource and dataset work fine individually.
After a bit Googling, I use the following settings to start the Ganymede. But, the issue remains.
C:\dev\ganymede\eclipse\ganymede-eclipse.exe -clean vmargs -Xms128m -Xmx512m -XX:MaxPermSize=512m
Your help is greatly appreciated!
kenny
// log
!SESSION 2010-08-25 14:17:05.880 -----------------------------------------------
eclipse.buildId=M20090211-1700
java.version=1.6.0_18
Framework arguments: vmargs -Xms128m -Xmx512m -XX:MaxPermSize=512m
Command-line arguments: -os win32 -ws win32 -arch x86 -clean vmargs -Xms128m -Xmx512m -XX:MaxPermSize=512m
!ENTRY org.eclipse.ui.workbench.texteditor 4 0 2010-08-25 14:17:17.177
!MESSAGE The 'org.eclipse.wst.jsdt.web.ui.internal.hyperlink.script.JSPJa vaHyperlinkDetector' extension from plug-in 'org.eclipse.wst.jsdt.web.ui' to the 'org.eclipse.ui.workbench.texteditor.hyperlinkDetectors' extension point will be ignored because it contains invalid attributes.
!MESSAGE The 'org.eclipse.wst.jsdt.web.ui.internal.hyperlink.script.event .JSPJavaHyperlinkDetector' extension from plug-in 'org.eclipse.wst.jsdt.web.ui' to the 'org.eclipse.ui.workbench.texteditor.hyperlinkDetectors' extension point will be ignored because it contains invalid attributes.
// accounts.rptdesign
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.17" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.3.2.r232_20090202 Build &lt;2.3.2.v20090218-0730></property>
<property name="units">in</property>
<property name="iconFile">/templates/simple_listing.gif</property>
<property name="cheatSheet"> org.eclipse.birt.report.designer.ui.cheatsheet.simplelisting </property>
<property name="bidiLayoutOrientation">ltr</property>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc" name="myDataSrc" id="27">
<property name="odaDriverClass">oracle.jdbc.OracleDriver</property>
<property name="odaURL">jdbc:oracle:thin:@ps51201:1521:DEVDB</property >
<property name="odaUser">john</property>
<encrypted-property name="odaPassword" encryptionID="base64">dWJ2YnVpbGQ=</encrypted-property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="accounts" id="28">
<list-property name="columnHints">
<structure>
<property name="columnName">ID</property>
<property name="displayName">ID</property>
</structure>
<structure>
<property name="columnName">EXTERNALACCOUNTNUMBER</property>
<property name="displayName">EXTERNALACCOUNTNUMBER</property>
</structure>
<structure>
<property name="columnName">ACCOUNTNAME</property>
<property name="displayName">ACCOUNTNAME</property>
</structure>
<structure>
<property name="columnName">STATUS</property>
<property name="displayName">STATUS</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ID</property>
<property name="dataType">decimal</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">EXTERNALACCOUNTNUMBER</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">ACCOUNTNAME</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">STATUS</property>
</structure>
</list-property>
</structure>
<property name="dataSource">myDataSrc</property>
<structure>
<property name="nativeName">ID</property>
<property name="nativeDataType">2</property>
</structure>
<structure>
<property name="nativeName">EXTERNALACCOUNTNUMBER</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">ACCOUNTNAME</property>
</structure>
<structure>
<property name="nativeName">STATUS</property>
</structure>
</list-property>
<property name="queryText">select *
from ACCOUNTS</property>
<xml-property name="designerValues"><![CDATA[<?xml version="1.0" encoding="UTF-8"?>
<model:DesignValues xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design" xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ID</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>2</design:nativeDataTypeCode>
<design:precision>19</design:precision>
<design:scale>0</design:scale>
<design:nullability>NotNullable</design:nullability>
<design:uiHints>
<design:displayName>ID</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>ID</design:label>
<design:formattingHints>
<design:displaySize>22</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>EXTERNALACCOUNTNUMBER</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>32</design:precision>
<design:uiHints>
<design:displayName>EXTERNALACCOUNTNUMBER</design:displayName >
</design:uiHints>
<design:usageHints>
<design:label>EXTERNALACCOUNTNUMBER</design:label>
<design:displaySize>32</design:displaySize>
<design:attributes>
<design:name>ACCOUNTNAME</design:name>
<design:position>3</design:position>
<design:precision>255</design:precision>
<design:uiHints>
<design:displayName>ACCOUNTNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ACCOUNTNAME</design:label>
<design:displaySize>255</design:displaySize>
<design:attributes>
<design:name>STATUS</design:name>
<design:position>4</design:position>
<design:uiHints>
<design:displayName>STATUS</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>STATUS</design:label>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="24">
<property name="fontFamily">"Verdana"</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="25">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="26">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="topMargin">0.25in</property>
<property name="leftMargin">0.25in</property>
<property name="bottomMargin">0.25in</property>
<property name="rightMargin">0.25in</property>
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="4">
<property name="width">100%</property>
<property name="dataSet">accounts</property>
<list-property name="boundDataColumns">
<structure>
<expression name="expression">dataSetRow["EXTERNALACCOUNTNUMBER"]</expression >
</structure>
<structure>
<expression name="expression">dataSetRow["ACCOUNTNAME"]</expression >
</structure>
<structure>
<expression name="expression">dataSetRow["STATUS"]</expression>
</structure>
</list-property>
<property name="pageBreakInterval">50</property>
<column id="20"/>
<column id="21"/>
<column id="22"/>
<column id="23"/>
<header>
<row id="5">
<cell id="6"/>
<cell id="7">
<label id="29">
<text-property name="text">EXTERNALACCOUNTNUMBER</text-property>
</label>
</cell>
<cell id="8">
<label id="31">
<text-property name="text">ACCOUNTNAME</text-property>
</label>
</cell>
<cell id="9">
<label id="33">
<text-property name="text">STATUS</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="10">
<cell id="11"/>
<cell id="12">
<data id="30">
<property name="resultSetColumn">EXTERNALACCOUNTNUMBER</property>
</data>
</cell>
<cell id="13">
<data id="32">
<property name="resultSetColumn">ACCOUNTNAME</property>
</data>
</cell>
<cell id="14">
<data id="34">
<property name="resultSetColumn">STATUS</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="15">
<cell id="16"/>
<cell id="17"/>
<cell id="18"/>
<cell id="19"/>
</row>
</footer>
</table>
</body>
</report>
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #555221 is a reply to message #555204] Wed, 25 August 2010 18:16 Go to previous messageGo to next message
Jason,
I've the report designer crashing issue fixed by starting the designer with -vm C:\dev\jdk1.5.0_22\bin\java.exe. I'm able to preview my report with proper data showing in the designer.
However, when I run the same report in WebLogic, the data don't show up in the generated pdf, that shows the headings and date/time. The birt log indicates that the data are returned properly, so there isn't an issue of the jdbc connection.
Any thought?
kenny
// birt log
Aug 25, 2010 4:48:56 PM org.eclipse.birt.data.engine.odaconsumer.ResultSet fetch
FINEST: Fetched next row: 1,TestComp,Testing Company,1 .
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #555245 is a reply to message #555221] Thu, 26 August 2010 00:14 Go to previous messageGo to next message
Can you post the report?
On 8/25/2010 6:16 PM, dash wrote:
> Jason,
> Any thought?
> kenny
> // birt log
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #555403 is a reply to message #555245] Thu, 26 August 2010 10:02 Go to previous messageGo to next message
Here is the report.
Thanks for your help,
kenny
<property name="iconFile">/templates/first_report.gif</property>
<property name="cheatSheet">org.eclipse.birt.report.designer.ui.cheatsheet.firstreport </property>
<template-parameter-definitions>
<template-parameter-definition name="NewTemplateParameterDefinition" id="28">
<property name="allowedType">Table</property>
<text-property name="description">Customer Listing</text-property>
<default>
<table id="29">
<column id="49"/>
<column id="50"/>
<column id="51"/>
<column id="52"/>
<header>
<row id="30">
<cell id="31">
<label id="32">
<property name="fontFamily">sans-serif</property>
<property name="fontWeight">bold</property>
<text-property name="text">Contact</text-property>
</label>
</cell>
<cell id="33">
<label id="34">
<text-property name="text">First</text-property>
</label>
</cell>
<cell id="35">
<label id="36">
<text-property name="text">Last</text-property>
</label>
</cell>
<cell id="37">
<label id="38">
<text-property name="text">Phone</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="39">
<cell id="40"/>
<cell id="41"/>
<cell id="42"/>
<cell id="43"/>
</row>
</detail>
<footer>
<row id="44">
<cell id="45"/>
<cell id="46"/>
<cell id="47"/>
<cell id="48"/>
</row>
</footer>
</table>
</default>
</template-parameter-definition>
<template-parameter-definition name="NewTemplateParameterDefinition1" id="78">
<text-property name="description">Customer Listing Table</text-property>
<default>
<table id="79">
<property name="refTemplateParameter">NewTemplateParameterDefinition </property>
<column id="99"/>
<column id="100"/>
<column id="101"/>
<column id="102"/>
<header>
<row id="80">
<cell id="81">
<label id="82">
</label>
</cell>
<cell id="83">
<label id="84">
</label>
</cell>
<cell id="85">
<label id="86">
</label>
</cell>
<cell id="87">
<label id="88">
</label>
</cell>
</row>
</header>
<detail>
<row id="89">
<cell id="90"/>
<cell id="91"/>
<cell id="92"/>
<cell id="93"/>
</row>
</detail>
<footer>
<row id="94">
<cell id="95"/>
<cell id="96"/>
<cell id="97"/>
<cell id="98"/>
</row>
</footer>
</table>
</default>
<template-parameter-definition name="NewTemplateParameterDefinition2" id="132">
<default>
<table id="133">
<property name="refTemplateParameter">NewTemplateParameterDefinition1 </property>
<column id="157"/>
<column id="158"/>
<column id="159"/>
<column id="160"/>
<header>
<row id="134">
<cell id="135">
<label id="136">
</label>
</cell>
<cell id="137">
<label id="138">
</label>
</cell>
<cell id="139">
<label id="140">
</label>
</cell>
<cell id="141">
<label id="142">
</label>
</cell>
</row>
</header>
<detail>
<row id="143">
<cell id="144">
<data id="145"/>
</cell>
<cell id="146">
<data id="147"/>
</cell>
<cell id="148">
<data id="149"/>
</cell>
<cell id="150">
<data id="151"/>
</cell>
</row>
</detail>
<footer>
<row id="152">
<cell id="153"/>
<cell id="154"/>
<cell id="155"/>
<cell id="156"/>
</row>
</footer>
</table>
</default>
</template-parameter-definitions>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc" name="devDataSource" id="248">
<property name="odaURL">jdbc:oracle:thin:@devdb.lab.com:1521:DEVDB</property >
<property name="odaUser">devuser</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="accounts" id="249">
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<property name="devDataSource">devuser</property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
from APPACCOUNT</property>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="110">
</style>
<style name="crosstab-cell" id="246">
</style>
<style name="crosstab" id="247">
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
</text>
</page-footer>
</page-setup>
<body>
<label id="245">
<property name="fontSize">x-large</property>
<property name="textAlign">center</property>
<text-property name="text">Customer Listing</text-property>
</label>
<table id="163">
<property name="refTemplateParameter">NewTemplateParameterDefinition2 </property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
<expression name="expression">dataSetRow["ID"]</expression>
</structure>
</list-property>
<column id="187"/>
<column id="188"/>
<column id="189"/>
<column id="190"/>
<header>
<row id="164">
<cell id="165">
<label id="166">
<text-property name="text">Account Name</text-property>
</label>
</cell>
<cell id="167">
<label id="168">
<text-property name="text">Ext Name</text-property>
</label>
</cell>
<cell id="169">
<label id="170">
</label>
</cell>
<cell id="171">
<label id="172">
</label>
</cell>
</row>
</header>
<detail>
<row id="173">
<cell id="174">
<data id="250">
<structure>
</structure>
</list-property>
</data>
</cell>
<cell id="176">
<data id="251">
<structure>
</structure>
</list-property>
</data>
</cell>
<cell id="178">
<data id="252">
</data>
</cell>
<cell id="180">
<data id="253">
<property name="resultSetColumn">ID</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="182">
<cell id="183"/>
<cell id="184"/>
<cell id="185"/>
<cell id="186"/>
</row>
</footer>
</table>
</body>
</report>
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #555459 is a reply to message #555403] Thu, 26 August 2010 12:30 Go to previous messageGo to next message
Kenny,
If you create a report off the sample db does it work?
Jason
On 8/26/2010 10:02 AM, dash wrote:
> Here is the report.
> kenny
> id="1">
> 2.3.2.r232_20090202 Build <2.3.2.v20090218-0730></property>
> <property
> </property>
> id="28">
> <default>
> <table id="29">
> <column id="49"/>
> <column id="50"/>
> <column id="51"/>
> <column id="52"/>
> <header>
> <row id="30">
> <cell id="31">
> <label id="32">
> </label>
> </cell>
> <cell id="33">
> <label id="34">
> </label>
> </cell>
> <cell id="35">
> <label id="36">
> </label>
> </cell>
> <cell id="37">
> <label id="38">
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="39">
> <cell id="40"/>
> <cell id="41"/>
> <cell id="42"/>
> <cell id="43"/>
> </row>
> </detail>
> <footer>
> <row id="44">
> <cell id="45"/>
> <cell id="46"/>
> <cell id="47"/>
> <cell id="48"/>
> </row>
> </footer>
> </table>
> </default>
> id="78">
> <default>
> <table id="79">
> </property>
> <column id="99"/>
> <column id="100"/>
> <column id="101"/>
> <column id="102"/>
> <header>
> <row id="80">
> <cell id="81">
> <label id="82">
> </label>
> </cell>
> <cell id="83">
> <label id="84">
> </label>
> </cell>
> <cell id="85">
> <label id="86">
> </label>
> </cell>
> <cell id="87">
> <label id="88">
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="89">
> <cell id="90"/>
> <cell id="91"/>
> <cell id="92"/>
> <cell id="93"/>
> </row>
> </detail>
> <footer>
> <row id="94">
> <cell id="95"/>
> <cell id="96"/>
> <cell id="97"/>
> <cell id="98"/>
> </row>
> </footer>
> </table>
> </default>
> id="132">
> <default>
> <table id="133">
> </property>
> <column id="157"/>
> <column id="158"/>
> <column id="159"/>
> <column id="160"/>
> <header>
> <row id="134">
> <cell id="135">
> <label id="136">
> </label>
> </cell>
> <cell id="137">
> <label id="138">
> </label>
> </cell>
> <cell id="139">
> <label id="140">
> </label>
> </cell>
> <cell id="141">
> <label id="142">
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="143">
> <cell id="144">
> <data id="145"/>
> </cell>
> <cell id="146">
> <data id="147"/>
> </cell>
> <cell id="148">
> <data id="149"/>
> </cell>
> <cell id="150">
> <data id="151"/>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="152">
> <cell id="153"/>
> <cell id="154"/>
> <cell id="155"/>
> <cell id="156"/>
> </row>
> </footer>
> </table>
> </default>
> <data-sources>
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> encoding="UTF-8"?>
> <model:DesignValues
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <label id="245">
> </label>
> <table id="163">
> </property>
> <structure>
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <column id="187"/>
> <column id="188"/>
> <column id="189"/>
> <column id="190"/>
> <header>
> <row id="164">
> <cell id="165">
> <label id="166">
> </label>
> </cell>
> <cell id="167">
> <label id="168">
> </label>
> </cell>
> <cell id="169">
> <label id="170">
> </label>
> </cell>
> <cell id="171">
> <label id="172">
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="173">
> <cell id="174">
> <data id="250">
> <structure>
> </structure>
> </list-property>
> </data>
> </cell>
> <cell id="176">
> <data id="251">
> <structure>
> <expression
> </structure>
> </list-property>
> </data>
> </cell>
> <cell id="178">
> <data id="252">
> </data>
> </cell>
> <cell id="180">
> <data id="253">
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="182">
> <cell id="183"/>
> <cell id="184"/>
> <cell id="185"/>
> <cell id="186"/>
> </row>
> </footer>
> </table>
> </body>
> </report>
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #555485 is a reply to message #555459] Thu, 26 August 2010 14:05 Go to previous messageGo to next message
Jason,
I haven't done that, but why would it make a difference? The report runs properly in the designer.
kenny
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #555657 is a reply to message #555485] Fri, 27 August 2010 10:03 Go to previous messageGo to next message
I am wondering if something in the data/datasource may be causing the
issue. The designer does not return all data.
Jason
On 8/26/2010 2:05 PM, dash wrote:
> Jason,
> kenny
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #555682 is a reply to message #555657] Fri, 27 August 2010 11:45 Go to previous messageGo to next message
Jason,
I'm not sure that I understand your comment. The report, running in the designer, does return all the data requested by the query. I verify the result against the db table.
Are you saying that the result set might not contain all the data, that should be fetched by the query, all the time in the designer? If yes, what would be the cause for the designer not fetching all the data requested by the query? Is there a fix for that?
On the other hand, do you have any suggestion where I should debug the run-time report issue? I'm kind of stuck at this point...
kenny
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #556000 is a reply to message #555682] Mon, 30 August 2010 10:08 Go to previous messageGo to next message
Hi Jason,
Any pointers to debug the missing data issue?
kenny
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #556055 is a reply to message #556000] Mon, 30 August 2010 12:53 Go to previous messageGo to next message
Kenny,
I meant that in the designer, there is a preference that determines how
many rows to return. When deployed the engine retrieves all the data.
What I am wondering is if something in the full data is causing the
issue. If you run a report against the sample db we can eliminate so
possible causes.
Jason
On 8/30/2010 10:08 AM, dash wrote:
> Hi Jason,
> kenny
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #556088 is a reply to message #556055] Mon, 30 August 2010 14:22 Go to previous messageGo to next message
Jason,
My test table only has 5 rows of data. I can preview all 5 rows of data in the designer. But, there isn't a single row showing at run-time even though all the data shows up in the birt log.
The headings and data and time do get rendered properly in the PDF report. Just the data are missing...
> // birt log
I don't think the size of the dataset is the issue if it's what you meant. Can you think of any other area that I can dig around?
kenny
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #556097 is a reply to message #556088] Mon, 30 August 2010 14:56 Go to previous messageGo to next message
Kenny,
I checked your report again and noticed your dataset did not have a
datasource property.
Jason
On 8/30/2010 2:22 PM, dash wrote:
> Jason,
>> // birt log
> kenny
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #556115 is a reply to message #554957] Mon, 30 August 2010 16:53 Go to previous messageGo to next message
Jason,
The data set has a property element pointing to the data-source element in the template. The birt log indicates that the data are fetched from the test table. I'm not quite sure what you meant...
kenny
<data-sources>
> <property
> </oda-data-source>
> </data-sources>
</data-sources>
> <data-sets>
> <oda-data-set
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #556272 is a reply to message #556115] Tue, 31 August 2010 10:38 Go to previous messageGo to next message
When you look at the xml view do any errors show up? Can you try
rebuilding the report without the template?
On 8/30/2010 4:53 PM, dash wrote:
> Jason,
> kenny
> <data-sources>
>> <property
>> </oda-data-source>
>> </data-sources>
> </data-sources>
>> <data-sets>
>> <oda-data-set
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #556353 is a reply to message #554957] Tue, 31 August 2010 18:41 Go to previous messageGo to next message
Jason,
The xml looks good. I'm trying to build a blank report without any template being used if that is what you meant. However, the designer keeps crashing again. I get java.lang.OutOfMemoryError: PermGen space error after a few operations such as previewing report, switching between layout and xml source views.
I've tried different jvm startup settings for the designer without much luck. Any suggestion?
C:\dev\ganymede\eclipse\ganymede-eclipse.exe -clean -vm C:\dev\jdk1.5.0_22\bin\java.exe vmargs -Xms128m -Xmx512m -XX:PermSize=512m -XX:MaxPermSize=1024m
kenny
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #556355 is a reply to message #556353] Tue, 31 August 2010 19:29 Go to previous messageGo to next message
Can you try the helios allinone download?
On 8/31/2010 6:41 PM, dash wrote:
> Jason,
> kenny
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #556558 is a reply to message #556355] Wed, 01 September 2010 14:28 Go to previous messageGo to next message
Jason,
I pull down 2.5.2 because I don't have the appetite to try helios, the greatest and latest, yet. The 252 designer works like a champ, so far. However, I get the following error at run-time. Any idea?
I assume the deployment structure between the 231 and 252 is the same, right?
The documentation on the birt site seems to be for the older versions. Does 252 have its own documentation? If yes, can you please send me a pointer?
kenny
Sep 1, 2010 1:15:39 PM org.eclipse.birt.core.internal.plugin.ScriptEngineFactoryMan agerImpl createFactory
SEVERE: Plug-in org.eclipse.birt.report.engine.script.javascript was unable to load class org.eclipse.birt.report.engine.javascript.JavascriptEngineFa ctory.
org.eclipse.core.runtime.CoreException: Plug-in org.eclipse.birt.report.engine.script.javascript was unable to load class org.eclipse.birt.report.engine.javascript.JavascriptEngineFa ctory.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:180)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:162)
at org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:874)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #556559 is a reply to message #556558] Wed, 01 September 2010 14:34 Go to previous messageGo to next message
Kenny,
Can you verify that you do not have js.jar in your cp at runtime. If
you do this could conflict with the version that BIRT uses.
Jason
On 9/1/2010 2:29 PM, dash wrote:
> Jason,
> right?
> pointer?
> kenny
> createFactory
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #556562 is a reply to message #556559] Wed, 01 September 2010 14:53 Go to previous messageGo to next message
Jason,
Thanks for your prompt response. Yes, there is a js.jar, shared by multiple WARs, in myApp.ear/APP-INF/lib/. The birt js.jar is deployed in myReport.war/WEB-INF/lib/. myReport.war is one of many WARs in the myApp.ear. I cannot move the myReport.war out from the ear because myReport.war uses bunch of stuff in the ear.
I didn't run into this issue when deploying 231... What would be your suggestion to resolve this conflict? Remove the js.jar in myReport.war/WEB-INF/lib/, perhaps?
kenny
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #556720 is a reply to message #554957] Thu, 02 September 2010 08:51 Go to previous messageGo to next message
Jason,
Thanks for all your help. The run-time is working fine now. The documentation and samples on the birt site seem to be for older versions. I wonder whether there is documentation for the version 252. If yes, can you please send me a pointer?
kenny
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #556782 is a reply to message #556720] Thu, 02 September 2010 10:56 Go to previous messageGo to next message
Kenny,
Glad you have it working. What did you need to do?
What specific documentation are you referring to. A lot of the
development examples are older, but should still work. The deployment
instructions should also work. We have a lot on the FAQ for deployment
as well. We need to go through the site and add some content, so
getting your feedback would be much appreciated.
Jason
On 9/2/2010 8:51 AM, dash wrote:
> Jason,
> kenny
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #556884 is a reply to message #556782] Thu, 02 September 2010 23:02 Go to previous messageGo to next message
Jason,
I added <container-descriptor>
<prefer-web-inf-classes>true</prefer-web-inf-classes>
</container-descriptor> to the weblogic.xml in the WEB-INF of our war file. Instead of loading the js.jar from the ear's APP-INF/lib, the js.jar in the WEB-INF/lib gets loaded.
I'm looking for general documentation because I'm still learning different aspects of the BIRT.
I'm more than happy to contribute what I've learned back to the commnuity. Please send me a pointer.
kenny
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #557003 is a reply to message #556884] Fri, 03 September 2010 11:09 Go to previous message
Kenny,
can you look under http://wiki.eclipse.org/BIRT/FAQ and add an entry
under deployment.
Jason
On 9/2/2010 11:02 PM, dash wrote:
> Jason,
> kenny
Previous Topic:Filling array in BIRT
Next Topic:open "Report design" perspective when open a ".rptDesign" file
Current Time: Thu Jul 24 18:52:45 EDT 2025
Powered by FUDForum. Page generated in 0.05909 seconds
