Home » Language IDEs » PHP Development Tools (PDT) » problem with PDT + XDebug
problem with PDT + XDebug [message #555051] Wed, 25 August 2010 05:59 Go to next message
Hello everybody,
i use Eclipse PDT (3.6) with XDebug (2.0.5) + WAMPSERVER 2 (with PHP 5.3).
XDebug seems to be installed correctly (verify by PhpInfo()).
PROBLEM :
When i put a breakpoint in my PHP code, it doesn't stop : it goes on to the end of the code !
The log file is not created too.
and the xdebug_break() function doesn't work either.
*** the port used is "8080" (the port "80" is already used by a IIS server).
i am in localhost.
my php.ini file :
zend_extension="C:/wamp/bin/php/php5.3.0/ext/php_xdebug.dll "
xdebug.remote_enable=true
xdebug.remote_host="127.0.0.1:8080"
xdebug.remote_port=9000
xdebug.remote_handler="dbgp"
xdebug.remote_log="C:/wamp/www/gecko/xdebug.log"
xdebug.remote_mode=req
xdebug.remote_idekey="ECLIPSE_DBGP"
xdebug.remote_autostart = 1
xdebug.profiler_enable_trigger=1
xdebug.profiler_enable = 1
xdebug.profiler_output_dir = "c:/wamp/tmp/"
xdebug.collect_params = On
xdebug.show_local_vars = On
Can you help me please.
Thanks for advance.
Re: problem with PDT + XDebug [message #555065 is a reply to message #555051] Wed, 25 August 2010 06:44 Go to previous messageGo to next message
Originally posted by: dkel50.hotremovemail.com
your remote_host entry doesn't look right, set it to
xdebug.remote_host="127.0.0.1"
Dave
On 25/08/2010 10:59, KEMET wrote:
> Hello everybody,
> PROBLEM :
> server).
> i am in localhost.
> my php.ini file :
> Thanks for advance.
Re: problem with PDT + XDebug [message #555084 is a reply to message #555065] Wed, 25 August 2010 08:13 Go to previous messageGo to next message
Thanks you.
There was indeed effectively a error in xdebug.hote_remote.
2 for 3 problem were resolved :
- xdebug_break() function works well
- the log file was created too.
There is always the problem with the breakpoints with Eclipse.
They don't work !
a idea ?
Re: problem with PDT + XDebug [message #555099 is a reply to message #555084] Wed, 25 August 2010 08:39 Go to previous messageGo to next message
Several, what are the names of the files having breakpoints set in the
xdebug log file ? Do they match real physical files on your machine. If
not then the problem is with your path mapping setup.
If all looks ok, try deleting all breakpoints and recreating them. There
is a problem where workspaces from 2.1 don't correctly get persisted so
PDT 2.2 has problems.
Dave Kelsey
On 25/08/2010 13:13, KEMET wrote:
> Thanks you.
> They don't work !
> a idea ?
Re: problem with PDT + XDebug [message #555106 is a reply to message #555099] Wed, 25 August 2010 09:22 Go to previous messageGo to next message
The mapping (server <-> physical files) seems to be correct.
after deleting and recreating breakpoints, the problem persists.
so it is not possible for the moment (bug eclipse) to use breakpoints from eclipse ?
We have to content ourselves of xdebug-break() function !
Re: problem with PDT + XDebug [message #555108 is a reply to message #555106] Wed, 25 August 2010 09:26 Go to previous messageGo to next message
Could you post your log file ?
Dave
> from eclipse ?
Re: problem with PDT + XDebug [message #555109 is a reply to message #555108] Wed, 25 August 2010 09:31 Go to previous messageGo to next message
Log opened at 2010-08-25 13:28:51
-> <init xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" fileuri="file:///C:/wamp/www/gecko/index.php" language="PHP" protocol_version="1.0" appid="2400" idekey="ECLIPSE_DBGP"><engine version="2.0.5"><![CDATA[Xdebug]]></engine><author><![CDATA[Derick Rethans]]></author><url><![CDATA[http://xdebug.org]]></url><copyright><![CDATA[Copyright (c) 2002-2009 by Derick Rethans]]></copyright></init>
<- feature_set -i 113 -n show_hidden -v 1
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="feature_set" transaction_id="113" feature="show_hidden" success="1"></response>
<- feature_set -i 114 -n max_depth -v 3
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="feature_set" transaction_id="114" feature="max_depth" success="1"></response>
<- stack_get -i 115
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="stack_get" transaction_id="115"></response>
<- feature_set -i 116 -n max_children -v 31
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="feature_set" transaction_id="116" feature="max_children" success="1"></response>
<- feature_get -i 117 -n encoding
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="feature_get" transaction_id="117" feature_name="encoding" supported="1"><![CDATA[iso-8859-1]]></response>
<- feature_get -i 118 -n supports_async
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="feature_get" transaction_id="118" feature_name="supports_async" supported="1"><![CDATA[0]]></response>
<- stdout -i 119 -c 1
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="stdout" transaction_id="119" success="1"></response>
<- stderr -i 120 -c 1
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="stderr" transaction_id="120" success="0"></response>
<- breakpoint_set -i 121 -t line -f file:///http://localhost:8080/gecko/index.php -n 8
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="breakpoint_set" transaction_id="121" id="24000020"></response>
<- breakpoint_set -i 122 -t line -f file:///http://localhost:8080/gecko/index.php -n 8
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="breakpoint_set" transaction_id="122" id="24000021"></response>
<- run -i 123
-> <stream xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" type="stdout" encoding="base64">< ![CDATA[PGh0bWw+CjxoZWFkPgogIDx0aXRsZT54ZGVidWcgdGVzdDwvdGl0 bGU+CjwvaGVhZD4KPGJvZHk+Cg==]] ></stream>
-> <stream xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" type="stdout" encoding="base64"><![CDATA[ZGRkZGRkZGRkZGQx]]></stream>
-> <stream xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" type="stdout" encoding="base64"><![CDATA[ZGRkZGRkZGRkZGQy]]></stream>
-> <stream xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" type="stdout" encoding="base64"><![CDATA[PC9ib2R5Pgo8L2h0bWw+IAo=]]></stream >
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="run" transaction_id="123" status="stopping" reason="ok"></response>
<- stop -i 124
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="stop" transaction_id="124" status="stopped" reason="ok"></response>
Log closed at 2010-08-25 13:28:51
Re: problem with PDT + XDebug [message #555124 is a reply to message #555109] Wed, 25 August 2010 09:54 Go to previous messageGo to next message
Your path mapping is incorrect
is not a valid definition of a real file. It should be
Delete your path mapping entry for your server should resolve the problem
Dave
> <- stack_get -i 115
> <- run -i 123
> encoding="base64"><
> <- stop -i 124
Re: problem with PDT + XDebug [message #555125 is a reply to message #555124] Wed, 25 August 2010 10:06 Go to previous message
Surprised it's all right !
thanks you.
Previous Topic:Mark Occurrences Not Working
Next Topic:PHPUnit + Eclipse Configuration
Current Time: Wed Jul 23 13:24:44 EDT 2025
Powered by FUDForum. Page generated in 0.26405 seconds
