Home » Archived » Buckminster » Updating workspace
Updating workspace [message #554955] Tue, 24 August 2010 17:36 Go to next message
When I run the build components that are already in the workspace are not being updated. I found a post that discusses tthis issue http://dev.eclipse.org/mhonarc/lists/buckminster-dev/msg0071 1.html, and added advisor node to cquery, but still components are not being updated. This is what I did:
<cq:advisorNode namePattern="^com\.iwaysoftware(\..+)?" useMaterialization="false" useWorkspace="false"/>
What can I check to see why update is not being executed?
thanks,
Alex
[Updated on: Tue, 24 August 2010 17:38] by Moderator
Re: Updating workspace [message #554970 is a reply to message #554955] Tue, 24 August 2010 20:57 Go to previous messageGo to next message
Materialization is only performed when a query is executed. Are you
rerunning the query?
- henrik
On 8/24/10 11:36 PM, Alex wrote:
> thanks,
> Alex
Re: Updating workspace [message #554971 is a reply to message #554970] Tue, 24 August 2010 22:03 Go to previous messageGo to next message
Yes, locally in cquery I execute resolve and materialize but no incoming changes in bundles are updated.
I do see this in the log
com.iwaysoftware.logging:osgi.bundle: Rejecting provider local(materialized): Materializations disabled in query
com.iwaysoftware.logging:osgi.bundle: Rejecting provider local(workspace): Workspace disabled in query
com.iwaysoftware.logging:osgi.bundle: Trying provider local(target)
com.iwaysoftware.logging:osgi.bundle: Found match 0.1.0.qualifier
com.iwaysoftware.logging:osgi.bundle: Found match com.iwaysoftware.logging:osgi.bundle$0.1.0.qualifier
How can my plugins be found in target platform? Also, if I only leave Resolution Service to be searched, I see that match is found remotely via rmap, but then I get exceptions because dependencies that are in eclipse repositories are not found.
thanks,
Alex
Re: Updating workspace [message #554985 is a reply to message #554955] Wed, 25 August 2010 01:50 Go to previous messageGo to next message
On 08/24/2010 11:36 PM, Alex wrote:
> ... This is what I did:
Only the first advisor node that matches is used. Do you have some other node that is placed before this one that match
the same components?
- thomas
Re: Updating workspace [message #555077 is a reply to message #554985] Wed, 25 August 2010 07:53 Go to previous messageGo to next message
There is no other node before this one except root. Also, advisor will match across different types as well, or do I have to specify the type?
thanks,
Alex
Re: Updating workspace [message #555151 is a reply to message #555077] Wed, 25 August 2010 11:45 Go to previous messageGo to next message
No. If no type is specified, all types are matched.
- thomas
Re: Updating workspace [message #555160 is a reply to message #555151] Wed, 25 August 2010 12:10 Go to previous messageGo to next message
Thanks Thomas,
I did notice something else, one of the features contains cspec - it's an update site feature, and this gets updated every time. I also have this feature listed as dependency in the cspex of the build project so that buckminster materializes it during cquery import. Now, I tried doing same for another feature that does not get updated (create cspec in the feature, add it as dependency in cspex), but this does not work. Besides, even if it did, it would mean I need to add all dependencies in the cspex?
I also remember that Henrik mentioned that buckminster 3.5 needs mspec to perform materialization, but I am not sure if I needed it in my case.
thanks,
Alex
Re: Updating workspace [message #555173 is a reply to message #555160] Wed, 25 August 2010 13:11 Go to previous messageGo to next message
Something else I noticed. If I use buckminster 3.5, then update site project updates fine, however if I use buckminster 3.6 it does not.
Re: Updating workspace [message #555176 is a reply to message #555160] Wed, 25 August 2010 12:52 Go to previous messageGo to next message
A cspex is a decoration on the automatically generated cspec - so there
is no need to restate what has already been discovered and translated by
buckminster.
If a component is treated as a native buckminster component, it can have
just a cspec (since there is no discovery, and hence nothing to decorate).
An mspec is needed in 3.5 if materialization should go to different places.
- henrik
On 8/25/10 6:10 PM, Alex wrote:
> Thanks Thomas,
> the cspex?
> thanks,
> Alex
Re: Updating workspace [message #555177 is a reply to message #555176] Wed, 25 August 2010 13:22 Go to previous messageGo to next message
Thanks Henrik,
Then this has no affect during update as components are already where they need to be. I don't understand why local provider is chosen during materialization when advisor excludes it.
Alex
Re: Updating workspace [message #555209 is a reply to message #555173] Wed, 25 August 2010 16:25 Go to previous messageGo to next message
If that's the case, then it's a regression that deserves a bugzilla.
- thomas
Re: Updating workspace [message #555211 is a reply to message #555209] Wed, 25 August 2010 16:45 Go to previous messageGo to next message
Should bugzilla only include 3.5 to 3.6 regression, or do you think there might be something wrong with updating of materialized components as well?
Re: Updating workspace [message #555216 is a reply to message #555211] Wed, 25 August 2010 17:35 Go to previous messageGo to next message
Alex wrote on Wed, 25 August 2010 16:45
What I meant was the update happens only for component of type buckminster in 3.5, so should I open bugzilla as that or open it to updating in general - for all component types?
thanks,
Alex
Re: Updating workspace [message #555345 is a reply to message #555216] Thu, 26 August 2010 07:41 Go to previous message
Just describe what you were able to figure out.
- henrik
>> components as well?
> thanks,
> Alex
Previous Topic:Compile JET templates during a Buckminster PDE Build
Next Topic:Build for TP 3.5 contains 3.6 plugins
Current Time: Fri Jul 18 19:00:01 EDT 2025
Powered by FUDForum. Page generated in 0.06893 seconds
