Home » Modeling » MoDisco » discover Java/KDM Model programaticaly(how to discover a JavaModel from Java sourcecode programmatically)
discover Java/KDM Model programaticaly [message #553899] Thu, 19 August 2010 07:25 Go to next message
i want to write a program that can discover a Javamodel from Java sourcecode.
This is what Fred Madiot pointed out to me already:
Fred Madiot said...
Here is an example of code showing how to programmatically create a java model from java source code :
    // Create a discoverer for a Java project
    DiscoverJavaModelFromJavaProject javaDiscoverer = new DiscoverJavaModelFromJavaProject();
    // Parameters of the discoverer
    Map javaDiscoveryParameters = new HashMap();
    javaDiscoveryParameters.put(DefaultDiscoverer.PARAMETER_SILENT_MODE,true);
    javaDiscoveryParameters.put(DefaultDiscoverer.PARAMETER_BROWSE_RESULT,false);
    // Execute the discoverer (javaProject is a IJavaProject)
    javaDiscoverer.discoverElement(javaProject, javaDiscoveryParameters);
    // Get the result model
    Resource javaModel=(Resource) javaDiscoveryParameters .get(DefaultDiscoverer.PARAMETER_TARGET_RESOURCE)
If you need help, you can post your questions directly on the MoDisco forum :
http://www.eclipse.org/forums/index.php?t=thread&frm_id= 21&
August 12, 2010 1:01 AM
that is a very great hint and I got it almost to work that way, apart from a few NullPointerExceptions....
Now my question is how do I construct a IJavaProject from the sourcecode located sommewhere on my disk?
I want to build a function something like:
public IJavaProject getJavaProjectFromSource(String pathToSource);
Does anyone have an idea how to do that? Or does someone know that something like that has been done already?
I will be very pleased for every little hint on the subject.
Thanx very much in advance.
Cheers Björn
Re: discover Java/KDM Model programaticaly [message #553934 is a reply to message #553899] Thu, 19 August 2010 09:13 Go to previous messageGo to next message
Modisco Java Discoverer uses the JDT DOM Parser to visit a
org.eclipse.jdt.core.dom.CompilationUnit and transforms it to a
org.eclipse.gmt.modisco.java.Model, then you could use direclty the
org.eclipse.gmt.modisco.java.io.java.JDTVisitor and the
org.eclipse.jdt.core.dom.ASTParser to produces your wanted
I have writen a simple example below :
package test;
import java.io.File;
import java.io.FileReader;
import java.util.Collections;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.gmt.modisco.java.Model;
import org.eclipse.gmt.modisco.java.emf.JavaFactory;
import org.eclipse.gmt.modisco.java.io.java.JDTVisitor;
import org.eclipse.gmt.modisco.java.io.java.binding.BindingManager;
import org.eclipse.jdt.core.dom.AST;
import org.eclipse.jdt.core.dom.ASTParser;
import org.eclipse.jdt.core.dom.CompilationUnit;
import org.eclipse.jdt.internal.compiler.classfmt.ClassFileConstant s;
import org.eclipse.jdt.internal.compiler.impl.CompilerOptions;
public class ModiscoTests {
public static void main(String[] args) throws Exception {
File file = new File("datas/Comp111Impl.java");
ASTParser parser = ASTParser.newParser(AST.JLS3);
FileReader fileReader = new FileReader(file);
char buffer[] = new char[(int) file.length()];
fileReader.read(buffer);
parser.setSource(buffer);
parser.setResolveBindings(true);
CompilerOptions options = new CompilerOptions();
options.verbose = true;
options.complianceLevel = ClassFileConstants.JDK1_5;
options.sourceLevel = ClassFileConstants.JDK1_5;
parser.setCompilerOptions(options.getMap());
CompilationUnit compilationUnit = (CompilationUnit) parser
.createAST(null);
compilationUnit.recordModifications();
JavaFactory factory = JavaFactory.eINSTANCE;
Model model = factory.createModel();
BindingManager bindingManager = new BindingManager(factory);
String path = file.getCanonicalPath();
String javaContent = String.copyValueOf(buffer);
JDTVisitor visitor = new JDTVisitor(factory, model, bindingManager,
path, javaContent, false, false);
compilationUnit.accept(visitor);
ResourceSet resourceSet = new ResourceSetImpl();
URI javaModelURI =
URI.createFileURI(file.getName().replaceFirst("java", ".javaxmi"));
Resource resource = resourceSet.createResource(javaModelURI);
resource.getContents().add(model);
resource.save(Collections.emptyMap());
But unfortunately Modisco is tied to OSGI Runtime Model (it uses
BundleActivator to get runtime informations), then this sample isn't
usable standalone. It would be nice to have Modisco usable standalone,
by using the org.eclipse.core.runtime.Platform.isRunning() operation
when accessing BundleActivator.
I had the same problem in the past.
Best Regards.
On 19/08/2010 13:25, bjorn.t@web.de wrote:
> Hi
> sourcecode.
> Quote:
>> Fred Madiot said...
>> Hi,
>> javaDiscoveryParameters.put(DefaultDiscoverer.PARAMETER_SILE NT_MODE,true);
>> javaDiscoveryParameters.put(DefaultDiscoverer.PARAMETER_BROW SE_RESULT,false);
>> forum :
> Cheers Björn
Re: discover Java/KDM Model programaticaly [message #554108 is a reply to message #553934] Fri, 20 August 2010 03:58 Go to previous messageGo to next message
To complete Esteban response, it is true that MoDisco Java discoverer
requires a workspace in a running Eclipse instance.
So if you want to have a IJavaProject instance from your sourcepath, you
need to first import your project (from your 'pathToSource') into an
Eclipse workspace project.
Then the two following lines will do the trick :
IProject project =
ResourcesPlugin.getWorkspace().getRoot().getProject("PROJECT_NAME ");
IJavaProject javaProject = JavaCore.create(project);
(where PROJECT_NAME is the name of project in the workspace)
I don't know how much you are familiar with Eclipse plugins
developement, but here is the way to launch your application :
In order to acces to the given workspace, your client program (which
launches the java discovery) should be launched as an "Eclipse
Application" rather than an "Java Application", and the "Workspace Data
Location" should target the workspace containing the PROJECT_NAME project.
So your client program should be available through a plugin project (UI
workbench action or standalone "Eclipse Application")
Fabien.
Re: discover Java/KDM Model programaticaly [message #554365 is a reply to message #554108] Sun, 22 August 2010 08:23 Go to previous messageGo to next message
Fabien Giquel wrote on Fri, 20 August 2010 03:58
IProject project =
Fabien.
Hi Fabien,
thank you very much for this helpful information.
This got me to the point where I want to be Smile
except from the part with "...need to first import your project (from your 'pathToSource') into an Eclipse workspace project..."
Does anyone know how to do that programaticaly? I would like to import
my javasources into an Eclipse workspace project silently... only having the pathToSource and making up some PROJECT_NAME.
I am running my app as Eclipse App anyway so the workspace is available...
Thanx in advance
Cheers Björn
Re: discover Java/KDM Model programaticaly [message #554751 is a reply to message #554365] Tue, 24 August 2010 06:35 Go to previous messageGo to next message
Hello Björn,
You may find an example of how to create a project in your workspace and populate it programmatically in the tests of
MoDisco. Please have a look of tests for java discoverer specifically (SimpleBlackBoxDiscovery, etc.) in SVN.
And to retrieve MoDisco sources: http://wiki.eclipse.org/MoDisco#Getting_involved
Gabriel
>> you need to first import your project (from your 'pathToSource') into
>> IProject project =
>> Data Location" should target the workspace containing the PROJECT_NAME
>> project.
>> (UI workbench action or standalone "Eclipse Application")
>> Fabien.
> Hi Fabien,
> This got me to the point where I want to be :)
> Thanx in advance
> Cheers Björn
Re: discover Java/KDM Model programaticaly [message #557251 is a reply to message #554751] Mon, 06 September 2010 05:36 Go to previous messageGo to next message
Hi Gabriel,
thank you very much for that hint that helped me a lot!
Cheers Björn
Now there is anotherproblem:
when trying to run an Java Discovery on a JavaProject I keep getting this exception:
java.lang.ExceptionInInitializerError
	at org.eclipse.gmt.modisco.java.io.java.JavaReader.readModel(JavaReader.java:158)
	at org.eclipse.gmt.modisco.java.actions.DiscoverJavaModelFromJavaProject$2.run(DiscoverJavaModelFromJavaProject.java:194)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
	at org.eclipse.gmt.modisco.java.io.java.JDTVisitorUtils.<clinit>(JDTVisitorUtils.java:61)
	... 3 more
doing right this in my code:
JavaActivator javaActivator = JavaActivator.getDefault();
		javaDiscoverer.discoverElement(this.javaProject,
it has to do with the fact that
javaActivator==null
in my code as well as in the JDTVisitorUtils line 61.
Does anyone have an idea why this could be ?
Thank you in advance
Cheers Björn
[Updated on: Mon, 06 September 2010 05:38] by Moderator
Re: discover Java/KDM Model programaticaly [message #557287 is a reply to message #554751] Mon, 06 September 2010 09:15 Go to previous messageGo to next message
Hi Gabriel,
Apart from the fact that the JavaProjectFactory uses:
which always returns NULL in my code... do you have an idea why that is the case?
Cheers Björn
	... 3 more
javaActivator==null
Cheers Björn
Re: discover Java/KDM Model programaticaly [message #557306 is a reply to message #557287] Mon, 06 September 2010 10:32 Go to previous messageGo to next message
Hello Björn,
Could you confirm that you are trying to launch your program using "Run as ... Eclipse application". It is needed to run
your program on top of osgi framework which will manage the life cycle of your plug-in ? And to be sure, have you
created your project using wizard for eclipse plug-ins ? Your previous post seems to indicate that it should be ok, let
see it as a double check ;-)
Another question, which Activator do you use ? You have to use the one you have created with your plug-in project. (Also
check your project dependencies, it should not contains a dependency to java.discoverer.tests ...)
And to use the JavaProjectFactory, last but not least, you have to copy/paste the class in your plug-in project (as it
is contextual).
If all the previous hints are not helpful, could you send us your project ?
Gabriel
> Hi Gabriel,
> the case?
> Cheers Björn
> this exception:
> at
> org.eclipse.gmt.modisco.java.io.java.JavaReader.readModel(Ja vaReader.java:158)
> at
> org.eclipse.gmt.modisco.java.actions.DiscoverJavaModelFromJa vaProject$2.run(DiscoverJavaModelFromJavaProject.java:194)
> at
> org.eclipse.gmt.modisco.java.io.java.JDTVisitorUtils.<clinit >(JDTVisitorUtils.java:61)
> ... 3 more
> javaActivator==null
> Cheers Björn
Re: discover Java/KDM Model programaticaly [message #557377 is a reply to message #557306] Tue, 07 September 2010 04:34 Go to previous messageGo to next message
Hi Gabriel,
thank you for your hints.
Yes I am starting the plugin with "Run as Eclipse App..."
Yes I did create the plugin with the wizzard, and i am using my own Activator that was generated by the wizzard.
After checking your suggestions i removed a coouple of not needed dependencies...
and now Activator.getDefault() seems to call the method inside my activator.
I copied the code from the factory in the projekt, so the Factory does work now.
Thank you very much!!!
Now I still have a problem with the discovery part:
When calling the javaDiscoverer with ...discoverElement(...) like this:
				true);
				false);
			try {
				this.javaProject.open(new NullProgressMonitor());
				// /IPackageFragmentRoot[] packageFragmentRoots =
				// this.javaProject.getAllPackageFragmentRoots();
				IPackageFragment[] packageFragment = this.javaProject
						.getPackageFragments();
				for (int i = 0; i < packageFragment.length; i++) {
					packageFragment[i].open(new NullProgressMonitor());
					System.out.println(packageFragment[i].getElementName());
			} catch (CoreException e) {
				e.printStackTrace();
		javaDiscoverer.discoverElement(this.javaProject, javaDiscoveryParameters);
I get this exception:
!ENTRY org.eclipse.core.jobs 4 2 2010-09-07 10:26:45.275
!MESSAGE An internal error occurred during: "Discovering Java model".
!STACK 0
	... 3 more
it looks like
JavaActivator.getDefault()==null
in line 60 of org.eclipse.gmt.modisco.java.io.java.JDTVisitorUtils:
	private static final boolean TRACE_QN = JavaActivator.getDefault()
			.isDebugging()
			&& new Boolean(Platform.getDebugOption(JDTVisitorUtils.TRACEID_QN));
called from DiscoverJavaModelFromJavaProject (line 194) -> JavaReader.readModel (line 158) -> JDTVisitorUtils (line 60)...
does anyone have any idea what could be missing?
Thank you very much for some help!
Cheers Björn
[Updated on: Tue, 07 September 2010 04:49] by Moderator
Re: discover Java/KDM Model programaticaly [message #557636 is a reply to message #557377] Wed, 08 September 2010 07:55 Go to previous messageGo to next message
Hello Björn,
I'm glad that you were able to go through previous problem. And your code looks great.
The new problem seems to be more "strange", as it is now the JavaActivator.getDefault() which returns null. The plug-in
of java discoverer is not managed correctly ... but why ?
Could you validate the launch configuration you are using to test (to check if all needed plug-ins are available) ? And
also, could you verify if your plug-in has the same dependencies as the plug-in to test the java discoverer ?
Gabriel
> Hi Gabriel,
> dependencies...
> activator.
> work now.
> When calling the javaDiscoverer like this:
> true);
> false);
> try {
> i get this exception:
> !STACK 0
> at
> at
> at
> ... 3 more
> Cheers Björn
Re: discover Java/KDM Model programaticaly [message #557895 is a reply to message #557636] Thu, 09 September 2010 07:25 Go to previous messageGo to next message
hi,
that was again a very good advice!
I was missing "org.eclipse.gmt.modisco.java.discoverer" in the dependencies..
Thank you very much !
Re: discover Java/KDM Model programaticaly [message #575734 is a reply to message #553934] Fri, 20 August 2010 03:58 Go to previous messageGo to next message
IProject project =
Fabien.
Re: discover Java/KDM Model programaticaly [message #575766 is a reply to message #554108] Sun, 22 August 2010 08:23 Go to previous messageGo to next message
> IProject project =
> Fabien.
Hi Fabien,
Thanx in advance
Cheers Björn
Re: discover Java/KDM Model programaticaly [message #575788 is a reply to message #575766] Tue, 24 August 2010 06:35 Go to previous messageGo to next message
Hello Björn,
Gabriel
>> IProject project =
>> project.
>> Fabien.
> Hi Fabien,
> Thanx in advance
> Cheers Björn
Re: discover Java/KDM Model programaticaly [message #575891 is a reply to message #554751] Mon, 06 September 2010 05:36 Go to previous messageGo to next message
Hi Gabriel,
Cheers Björn
at org.eclipse.gmt.modisco.java.io.java.JavaReader.readModel(Ja vaReader.java:158)
at org.eclipse.gmt.modisco.java.actions.DiscoverJavaModelFromJa vaProject$2.run(DiscoverJavaModelFromJavaProject.java:194)
at org.eclipse.gmt.modisco.java.io.java.JDTVisitorUtils.<clinit >(JDTVisitorUtils.java:61)
... 3 more
does anyone have an idea why this could be ?
Cheers Björn
Re: discover Java/KDM Model programaticaly [message #575915 is a reply to message #554751] Mon, 06 September 2010 09:15 Go to previous messageGo to next message
Hi Gabriel,
Cheers Björn
... 3 more
javaActivator==null
Cheers Björn
Re: discover Java/KDM Model programaticaly [message #575935 is a reply to message #575915] Mon, 06 September 2010 10:32 Go to previous messageGo to next message
Hello Björn,
is contextual).
Gabriel
> Hi Gabriel,
> the case?
> Cheers Björn
> this exception:
> at
> at
> at
> ... 3 more
> javaActivator==null
> Cheers Björn
Re: discover Java/KDM Model programaticaly [message #575960 is a reply to message #557306] Tue, 07 September 2010 04:34 Go to previous messageGo to next message
Hi Gabriel,
true);
false);
try {
!STACK 0
... 3 more
Cheers Björn
Re: discover Java/KDM Model programaticaly [message #576039 is a reply to message #575960] Wed, 08 September 2010 07:55 Go to previous messageGo to next message
Hello Björn,
Gabriel
> Hi Gabriel,
> dependencies...
> activator.
> work now.
> true);
> false);
> try {
> !STACK 0
> at
> at
> at
> ... 3 more
> Cheers Björn
Re: discover Java/KDM Model programaticaly [message #576058 is a reply to message #557636] Thu, 09 September 2010 07:25 Go to previous messageGo to next message
hi,
Re: discover Java/KDM Model programaticaly [message #629289 is a reply to message #553899] Mon, 27 September 2010 12:50 Go to previous messageGo to next message
when running the MoDisco PlugIn discovering a javamodel from javacode and a kdmmodel from javamodel, I get the following errors on the console:
when starting as eclipse app including modisco:
** (Eclipse:5008): CRITICAL **: murrine_style_draw_box: assertion `height >= -1' failed
later when running the
DiscoverKdmModelFromJavaModel.discoverElement(model, parameters);
method I get this error:
Cannot set feature comment to value [org.eclipse.gmt.modisco.java.emf.impl.LineCommentImpl@7d869bc7 (content: // asdf, enclosedByParent: false, prefixOfParent: true)], inter-model references are forbidden. Configure launching options to allow them.
Cannot set feature comment to value [org.eclipse.gmt.modisco.java.emf.impl.LineCommentImpl@5aa86d82 (content: // asdfasdf, enclosedByParent: false, prefixOfParent: true)], inter-model references are forbidden. Configure launching options to allow them.
Cannot set feature comment to value [org.eclipse.gmt.modisco.java.emf.impl.JavadocImpl@5c594008 (content: /**
 * Componente: ERSTECOMPONENTE
 * @component ERSTECOMPONENTE
Cannot set feature comment to value [org.eclipse.gmt.modisco.java.emf.impl.JavadocImpl@18815832 (content: /**
Cannot set feature comment to value [org.eclipse.gmt.modisco.java.emf.impl.JavadocImpl@1804686d (content: /**
why is the line comment a inter model reference and how do i configure launching?
does anyone have an idea where these two come from?
it looks like the transformation from javamodel to kdmmodel fails, since the are comments to be found in the javamodel but none in the kdmmodel.
Where do i need to look to fix that ?
Thanx in advance!
Cheers Björn
[Updated on: Mon, 27 September 2010 13:50] by Moderator
Re: discover Java/KDM Model programaticaly [message #629420 is a reply to message #629289] Tue, 28 September 2010 03:53 Go to previous messageGo to next message
First message seems to be e4 related, do you use it or have tried it ? And basically it is not as important as it seems.
The second message is an indicator of elements that could not be translated from java model to kdm model. It means there
is some comments that are not translated, so you could fill a bug and we will fix it asap (it would be better if you
could attach also the project or an example of code to reproduce this bug).
Gabriel
Björn wrote:
> discoverJavaModelFromJavaProject.discoverElement(javaProject ,
> parameters);
> allow them.
> allow them.
> /** * Componente: ERSTECOMPONENTE
> Thanx in advance!
> Cheers Björn
Re: discover Java/KDM Model programaticaly [message #629866 is a reply to message #629420] Wed, 29 September 2010 15:09 Go to previous messageGo to next message
thank you for the reply.
I also believe that there is a problem with the transformation from javamodel to kdmmodel.
I filed a bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=326584
Can someone tell me where to look ? Would that be in the "javaToKdm.atl" ?
Thanx!
Cheers
Björn
Re: discover Java/KDM Model programaticaly [message #630223 is a reply to message #629866] Fri, 01 October 2010 03:56 Go to previous messageGo to next message
Hi Bjorn,
you are right, there are some trouble with comment translation to kdm.
Yes, the file to fix is "java2kdm.atl". This work must be done in having
a look at the related "kdm2uml.atl" transformation (java->kdm->uml
chain). I am currently working on this problem and you will have some
information through the bugzilla 326584.
Fabien.
Re: discover Java/KDM Model programaticaly [message #630493 is a reply to message #630223] Sun, 03 October 2010 07:05 Go to previous messageGo to next message
thanx for the help !
I have another problem running modisco from an simple plain old java-project "Main":
Within which I have a main-method that starts an instance and a method from the modisco plugin class KDMSourceDiscoverer.
When doing so, after adding all the dependencies to my Main-project, I keep getting this NullPointerException using the KDMSourceDiscoverer:
Exception in thread "main" java.lang.NullPointerException
    at org.eclipse.gmt.modisco.kdm.source.discoverer.KDMSourceDiscoverer.<init>(KDMSourceDiscoverer.java:60)
the problem seem to be that in line 60:
private IContentType textContentType = this.contentTypeManager
            .getContentType(Activator.PLUGIN_ID + ".textFile");
Activator is null!
How would I need to configure my "Main" java-project to be able to run methods from a (the modisco-) plugin without writing a plugin myself?
Thanx for some hints!
Cheers
Björn
[Updated on: Sun, 03 October 2010 07:07] by Moderator
Re: discover Java/KDM Model programaticaly [message #630574 is a reply to message #630493] Mon, 04 October 2010 04:41 Go to previous messageGo to next message
Hi Bjorn,
sorry but the kdm source discoverer does not work when called from a plain old java project "Main".
Well, i suppose some refactoring would make it working so, but more generally the MoDisco components have been designed to work on top of an OSGI/Eclipse framework, since it makes a wide use of workspace resources management and also extension points mechanism.
More precisely, the problem here is that the discoverer uses the Platform content type manager, to have information about files content. Such a manager is initialized only within a running OSGI/Eclipse instance.
Re: discover Java/KDM Model programaticaly [message #630815 is a reply to message #630223] Tue, 05 October 2010 03:44 Go to previous messageGo to next message
Fabien Giquel wrote on Fri, 01 October 2010 03:56
Hi Bjorn,
Fabien.
thanx for fixing the "java2kdm.atl" it works now Smile
I want to take some action-elements from the java modell and add them to the kdm model (e.g. actionflow).
Where and how would be the point to start changing the "java2kdm.atl" to be able to do that?
For some hints I would be very thankful.
Cheers
Björn
Re: discover Java/KDM Model programaticaly [message #630853 is a reply to message #630815] Tue, 05 October 2010 06:23 Go to previous message
Hi Bjorn,
to update the java2kdm.atl file, please follow the steps :
- checkout from ou SVN the sources of project
" https://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.mod isco/plugins/trunk/org.eclipse.gmt.modisco.java.discoverer"
- add the "Atl" nature to project in modifying the .project by adding :
<buildCommand>
<name>org.eclipse.m2m.atl.adt.builder.atlBuilder</name>
<arguments>
</arguments>
</buildCommand> <nature>org.eclipse.m2m.atl.adt.builder.atlNature</nature>
- update the "java2kdm.atl"
- refer to the official ATL documentation from Help contents
- use the MoDisco button in toolbar "open a model from the EMF Package
registry" to have informations about the metamodels involved "kdm.code"
and "java"
-> the java2kdm.asm (compiled transformation) will be regenerated for
each modification
- Start a second instance of Eclipse from your workspace which will take
in account your workspace "java.discoverer" fork project in order to
test it.
Regards.
Previous Topic:Problem with SVN
Next Topic:Discovering KDM Model from a Java Project
Current Time: Sun Jul 27 22:59:49 EDT 2025
Powered by FUDForum. Page generated in 0.07123 seconds
