Export to PNG and Problems with class diagrams [message #554706] |
Tue, 24 August 2010 03:20  |
i have to use Eclipse with Papyrus in my practical semester.
No I've got some problems.
First, i wish there would be a step by step tutorial for Papyrus, because i spent a lot of time by learning how this modelling tool works....
My next Point is that i haven't found an option to export my created diagrams into png or something else...
And last, i can't add on class diagrams return parameters.
Can someone help me?
Re: Export to PNG and Problems with class diagrams [message #556249 is a reply to message #554743] |
Tue, 31 August 2010 09:18   |
Angi wrote on Tue, 24 August 2010 06:10 | There is no print symbol, no print in the menu, oder something like save as image.
Maybe you misunderstood Patrick?
The option to export images can be found in the context menu. You have to click into the diagram with the right button of your mouse.Then the context menu appears next to your mouse pointer. The option can not be found in the menu at the top of the window!
In the context menu there are several items starting with "Filter views...", "Add", "Navigate", and the fourth item is "File". Inside "File" you can find "Save As Image File...". You can choose between several formats like GIF, PNG, SVG, and PDF in the dialog. Though PDF is not working for me.
EDIT: The context menu can have different items, depending on where on your diagram you click. The items I listed appear if you right click somewhere into the diagram where no element is placed. If you do right click on an element some items are missing. But "File" is always there.
[Updated on: Tue, 31 August 2010 09:25] by Moderator
FUDForum. Page generated in 0.07815 seconds
