Edapt - Status? [message #554404] |
Sun, 22 August 2010 16:06  |
Hi all,
I'll have to build something to upgrade EMF-based models to a new version of
the metamodel soon. Searching for frameworks in this area, I found
http://www.eclipse.org/proposals/edapt However, although the page states that
the project has been created, this page only links back to itself. I haven't
found any trace of Edapt on the EMFT project page or in the CVS
repository. Can anyone tell me what the current status is and if there are
already artifacts to take a look at?
Volker Wegert
* Volker Wegert * http://www.volker-wegert.de/contact *
Failure is not an option. It comes bundled with your Microsoft product.
Re: Edapt - Status? [message #554852 is a reply to message #554404] |
Tue, 24 August 2010 10:39   |
Hi Volker,
I can give you an update on the operation-based part of Edapt which is based on COPE. COPE is already available on its own website (http://cope.in.tum.de) which is also linked from the proposal. The plan is to transfer COPE to Edapt. In the meantime, you can use COPE from its own website. You can even look at the source code if you want.
Sorry, for taking so long to transfer COPE to Edapt, but when I started the parallel IP process a half year ago, some IP issues popped up. Unfortunately, it took some time to resolve these IP issues. The IP issues will be solved in 1 to 2 weeks and then I will start the parallel IP process again. Depending on how long the process takes, COPE will be transfered to Edapt in the near future.
Concerning the state-based part of Edapt, you have to ask Moritz Eysholdt.
Thank you for you interest in Edapt.
Markus
Re: Edapt - Status? [message #623154 is a reply to message #554404] |
Hi Volker,
Markus
Re: Edapt - Status? [message #629733 is a reply to message #623154] |
Wed, 29 September 2010 07:55  |
FYI: The IP issues have been resolved and COPE is in the parallel IP
process again:
http://dev.eclipse.org/ipzilla/show_bug.cgi?id=3642
Am 24.08.2010 16:39, schrieb Markus Herrmannsdoerfer:
> Hi Volker,
> Cheers,
> Markus
FUDForum. Page generated in 0.11668 seconds
