Home » Modeling » TMF (Xtext) » Resolving references changed with 1.0?
Resolving references changed with 1.0? [message #554375] Sun, 22 August 2010 12:28 Go to next message
I used to have something like
Datamodule:
	'datamodule' name=ID '{' entities+=Entity* '}';
Entity:
	'entity' name=ID ('extends' extends=[Entity])?
	 '{' properties+=Property* '}';
Property:
	'property' name=ID ':' type=[Type];
Type:
	'type' name=ID ('extends' extends=[Type])?;
in xtext 0.7 which worked fine for the example below.
With xtext 1.0 I get a "cannot resolve reference" error when trying to reference an entity from another datamodule - e.g.:
datamodule m1 {
	entity test1 {
		property p1: String
	entity test1_1 extends test1 {
		property p2: String
datamodule m2 {
	entity test2_1 extends test1 {
		property p2: Integer
What do I have to do to make it work with 1.0? Are there any other pitfalls? Is there a migration guide (already)?
--Heiko
Re: Resolving references changed with 1.0? [message #554376 is a reply to message #554375] Sun, 22 August 2010 12:54 Go to previous messageGo to next message
Hello Heiko,
with Xtext 1.0 a new default behavour for Qualified Names was introduced.
to adapt your grammar to the new behaviour the grammar has to look like this:
ModelPart:
	elements+=Datamodule*
	types+=Type*
Datamodule:
Entity:
	'entity' name=ID ('extends' extends=[Entity|FQN])?
Property:
Type:
FQN: ID ("." ID)*;
the model then will look like this
datamodule m1 {
	entity test1 {
		property p1: String
		property p2: String
datamodule m2 {
	entity test2_1 extends m1.test1 {
(note the full qualified reference m1.test1.
Or you customize the used IQualifiedNameProvider by using the old behavoiurous SimpleNameProvider
public class MyDslRuntimeModule extends org.xtext.example.mydsl.AbstractMyDslRuntimeModule {
	public Class<? extends IQualifiedNameProvider> bindIQualifiedNameProvider() {
		return SimpleNameProvider.class;
but this may lead to problems with your duplicate p2 property since the name has to be unique.
you have to switch off duplicates checks too.
//composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
or you don't use simplesameprovider but rather change the default provider
public class MyQNP extends DefaultDeclarativeQualifiedNameProvider {
	public String qualifiedName(Entity entity) {
		return entity.getName();
		return MyQNP.class;
For more background have a look at the docs
~Christian
Re: Resolving references changed with 1.0? [message #554397 is a reply to message #554375] Sun, 22 August 2010 15:32 Go to previous messageGo to next message
Hi Heiko,
the documentation contains a migration guide and detailed information
about the scoping semantics.
Sebastian
Am 22.08.10 18:28, schrieb Heiko Tappe:
> Datamodule:
> Entity:
> Property:
> Type:
> datamodule m1 {
> entity test1 {
> property p1: String
> property p2: String
> datamodule m2 {
> --Heiko
Re: Resolving references changed with 1.0? [message #554529 is a reply to message #554375] Mon, 23 August 2010 09:44 Go to previous message
Thanks Christian and Sebastian!
I must have been blind. I somehow overlooked the migration part in the documentation.
Works like a charm now Smile
--Heiko
Previous Topic:Creating Jackrabbit's CND file editor
Next Topic:Code generation from editor
Current Time: Mon Jul 21 04:41:57 EDT 2025
Powered by FUDForum. Page generated in 0.05918 seconds
