| insert in tableviewer [message #55163] |
Wed, 24 October 2007 09:08   |
Eclipse User  |
Originally posted by: wen.ai.gillardon.de
I have a tableviewer in my program. I selected one row in the
tableviewer, then I tried to add this row into the next position like this:
IStructuredSelection selection =
(IStructuredSelection)viewer.getSelection();
if (selection.isEmpty()) return;
for(Object o:selection.toList()){
     viewer.insert(o, viewer.getTable().getSelectionIndex() + 1);
As result I got it, but the next row is missing. However, I got a prolem
  when I sort this tableviewer. Exactly for that, the rows in the
tableviewer can be sorted in order, but the tableviewer displays just
the old information instead of the updated information.
Many thanks.
Greetings
Wen
| Re: insert in tableviewer [message #55409 is a reply to message #55220] |
Thu, 25 October 2007 05:11    |
Eclipse User  |
thanks for your infos. But I still face to the problem, how can I add
something new in my table model or delete a row from it. I know two
methods in the ContentProvider are very important for that: getElements
and inputChanged. I'm still testing this and I can't find some examples
exactly for this thema from the google. Can anyone help?
Wen
Tom Schindl schrieb:
> Well I'm talking about JFaceViewers and expect that this is also true
> for RAP:
> 1. One instance more than once in Viewer
> TableViewer doesn't support putting the same instance more than once in
> the Table-Model. TreeViewer supports it but only under different TreePaths.
> 2. Only inserting the Object
>  From your code below I see that you are only adding the new instance to
> the Viewer but not your model, whenever the TableViewer is refreshed
> your changes are lost.
> 3. Sorting in Viewers:
> Is done using setSorter/setComparator.
> Tom
> Wen Ai schrieb:
>> Hi,
>> this:
>> prolem  when I sort this tableviewer. Exactly for that, the rows in
>> the tableviewer can be sorted in order, but the tableviewer displays
>> just the old information instead of the updated information.
>> Many thanks.
>> Greetings
>> Wen
| Re: insert in tableviewer [message #55435 is a reply to message #55409] |
Thu, 25 October 2007 05:23    |
Eclipse User  |
If Viewer#insert() / Viewer#remove() doesn't work you can do it brute
force by removing/adding the Model-Element from/to your content-model
and calling Viewer#refresh().
The best you can do to get help is to provide a standalone snippet which
we can run to see the problem. To make sure your code can work at all
I'd first test against Standard-JFace libs who are using SWT because if
it doesn't work there it won't either in RAP (I assume that JFace/SWT is
much more tested than RAP's widget libs :-).
Tom
Wen Ai schrieb:
> Wen
>> for RAP:
>> in the Table-Model. TreeViewer supports it but only under different
>> TreePaths.
>> to the Viewer but not your model, whenever the TableViewer is
>> refreshed your changes are lost.
>> Tom
>> Wen Ai schrieb:
>>> Hi,
>>> this:
>>> Many thanks.
>>> Greetings
>>> Wen
B e s t S o l u t i o n . at
Tom Schindl                                          JFace-Committer
| Re: insert in tableviewer [message #55682 is a reply to message #55435] |
Fri, 26 October 2007 03:30   |
Eclipse User  |
the problem was resolved. I have defined the table data inside the
method getElements() in the ContentProvider before. Then I change this
and put the data with viewer.setInput(getInputData()). If I delete or
add rows into the table view, just generate a new input data(or change
this data), and use the method setInput(newInputData) again. It works fine.
Thanks for all the helps :-)
Greetings
Wen
> Tom
> Wen Ai schrieb:
>> Hi,
>> getElements and inputChanged. I'm still testing this and I can't find
>> some examples exactly for this thema from the google. Can anyone help?
>> Wen
>>> for RAP:
>>> TreePaths.
>>> Tom
>>> Wen Ai schrieb:
>>>> Hi,
>>>> like this:
>>>> Many thanks.
>>>> Greetings
>>>> Wen
FUDForum. Page generated in 0.04880 seconds
