Home » Modeling » M2T (model-to-text transformation) » [Xpand] Running Xpand from Java can't find Xtend generator extension file
[Xpand] Running Xpand from Java can't find Xtend generator extension file [message #554135] Fri, 20 August 2010 05:29 Go to next message
Originally posted by: dhendriksREMOVE_THIS.tueREMOVE.THIS.nl
Hi all,
running my Xpand template with MWE is no problem:
<?xml version="1.0"?>
<workflow>
     <property name="metamodel"
value="metamodels/cif/nl.tue.cif.v2x1x1.metamodel/model/cif.ecore"/>
     <property name="model"
value="m2t/cif_cifascii/nl.tue.cif.v2x1x1.cifascii.v2x1x1/test_models/example.cifx"/>
     <property name="outputdir" value="test_models"/>
     <!-- set up EMF for standalone execution -->
     <bean class="org.eclipse.emf.mwe.utils.StandaloneSetup">
         <platformUri value="../../.."/>
         <RegisterEcoreFile value="platform:/resource/${metamodel}"/>
     </bean>
     <!-- instantiate metamodel -->
     <bean id="mm_emf"
class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel"/>
     <!-- load model and store it in slot 'model' -->
     <component class="org.eclipse.emf.mwe.utils.Reader">
         <uri value="platform:/resource/${model}"/>
         <modelSlot value="model"/>
     </component>
     <!--  generate code -->
     <component class="org.eclipse.xpand2.Generator">
         <metaModel idRef="mm_emf"/>
         <expand value="template::Template::expSpecification FOR model"/>
         <outlet name='OUT_FILE' path="${outputdir}/example.cif"/>
     </component>
</workflow>
This works fine. However, I'm trying to run the template from Java code
in a different project, without using the MWE file at all. I'm trying to
use the XpandFacade class. I have this code:
	String templateName = "expSpecification"
         String outputFolder = "xpandOutput";
         List<Object> params = new ArrayList<Object>();
         EObject targetObject = inResource.getContents().get(0);
         OutputImpl output = new OutputImpl();
         Outlet outlet = new Outlet(outputFolder);
         outlet.setOverwrite(true);
         output.addOutlet(outlet);
         Outlet outputOutlet = new Outlet("testOutput");
         outputOutlet.setName("OUT_FILE");
         output.addOutlet(outputOutlet);
         XpandExecutionContextImpl executionContext = new
XpandExecutionContextImpl(output, null);
         executionContext.registerMetaModel(new EmfRegistryMetaModel());
         org.eclipse.xtend.expression.Resource template =
executionContext.getResourceManager().loadResource("/mnt/(...anonymized...)/nl.tue.cif.v2x1x1.cifascii.v2x1x1/src/template/Template",
"xpt");
         executionContext =
(XpandExecutionContextImpl)(executionContext.cloneWithResource(template));
         XpandFacade facade = XpandFacade.create(executionContext);
         facade.evaluate2(templateName, targetObject, params);
This does indeed locate the metamodels, and the Xpand template. However,
upon execution I get:
EvaluationException : Couldn't find operation 'urgentToString(Boolean)'
for cif::Model.
	::mnt::(...anonymized..)::nl.tue.cif.v2x1x1.cifascii.v2x1x1::src::template::Template.xpt[2395,27]
on line 56 'urgentToString(this.urgent)'
	::mnt::(...anonymized..)::nl.tue.cif.v2x1x1.cifascii.v2x1x1::src::template::Template.xpt[285,65]
on line 11 'EXPAND expTopLevelDeclaration FOREACH declarations SEPARATOR
'\n''
	at
org.eclipse.internal.xtend.expression.ast.OperationCall.evaluateInternal(OperationCall.java:155)
	at
org.eclipse.internal.xtend.expression.ast.Expression.evaluate(Expression.java:50)
	at
org.eclipse.internal.xpand2.ast.ExpressionStatement.evaluateInternal(ExpressionStatement.java:45)
	at org.eclipse.internal.xpand2.ast.Statement.evaluate(Statement.java:41)
	at
org.eclipse.internal.xpand2.ast.AbstractDefinition.evaluate(AbstractDefinition.java:180)
	at
org.eclipse.internal.xpand2.ast.ExpandStatement.invokeDefinition(ExpandStatement.java:246)
	at
org.eclipse.internal.xpand2.ast.ExpandStatement.evaluateInternal(ExpandStatement.java:191)
	at
org.eclipse.internal.xpand2.ast.FileStatement.evaluateInternal(FileStatement.java:86)
	at
	at org.eclipse.xpand2.XpandFacade.evaluate2(XpandFacade.java:62)
	at
The urgentToString is located in GeneratorExtensions.ext, in the same
directory as the Template.xpt file, but Xpand can't find it. How do I
tell Xpand where to find the Xtend file?
Dennis
Re: [Xpand] Running Xpand from Java can't find Xtend generator extension file [message #554142 is a reply to message #554135] Fri, 20 August 2010 06:00 Go to previous messageGo to next message
did you import the Xtend file within you Xpand template:
«EXTENSION path::to::GeneratorExtensions»
Christian
Re: [Xpand] Running Xpand from Java can't find Xtend generator extension file [message #554180 is a reply to message #554142] Fri, 20 August 2010 08:34 Go to previous messageGo to next message
Hi Christian,
Yes, I have this in my Xpand template:
«EXTENSION template::GeneratorExtensions»
Best,
Dennis
Christian Dietrich wrote:
> Regards
> Christian
Re: [Xpand] Running Xpand from Java can't find Xtend generator extension file [message #554390 is a reply to message #554135] Sun, 22 August 2010 15:02 Go to previous messageGo to next message
Am 8/20/10 11:29 AM, schrieb Dennis Hendriks:
Make sure the template as well as the extension file is on your process'
classpath and reove the following two lines (the resource manager will
load the files from classpath) :
executionContext.getResourceManager().loadResource(" /mnt/(...anonymized...)/nl.tue.cif.v2x1x1.cifascii.v2x1x1/sr c/template/Template ",
> "xpt");
> executionContext =
> (XpandExecutionContextImpl)(executionContext.cloneWithResour ce(template));
Sven
Need professional support for Xtext or other Eclipse Modeling technologies?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : http://blog.efftinge.de
Re: [Xpand] Running Xpand from Java can't find Xtend generator extension file [message #554684 is a reply to message #554390] Tue, 24 August 2010 01:59 Go to previous message
> process' classpath
That did the trick!
Dennis
>> "xpt");
>> executionContext =
> Sven
Previous Topic:[Acceleo 3] hasStereotype
Next Topic:[Acceleo 3] Prevent elements from being parsed more than once
Current Time: Sat Jul 26 11:40:54 EDT 2025
Powered by FUDForum. Page generated in 1.27665 seconds
